bimmerpost/
BMW M2 and 2-Series Coupe
home
BMW M2 Forums 2023+ (G87) BMW M2 G87 General Topics
      04-23-2024, 12:43 AM   #133
Liosandro
Drives: G87 M2
Originally Posted by M2Jorge View Post
Got me an ABS honey comb sheet off amazon which I cut to fit and secured with zip ties behind the trim piece so you can’t even see the zip ties at all.
Looks OEM and it clears my ACC module so that’s all I cared about.
Attachment 3423486
Attachment 3423487
Nice job.
Can you please share the size of the cut you made?
Thanks
Ale
M2Jorge789.50
      04-23-2024, 11:57 AM   #134
bmhewett
Drives: 3012 328i sport 6 speed MT.
Originally Posted by bhutch View Post
Yes I would also like to know the brand of this screen.
Yes, is this one
https://www.radiatorgrillstore.com/b...hoCjBIQAvD_BwE
I higly recommend
      04-23-2024, 11:59 AM   #135
bmhewett
If you remove a few screws you can do a cleaner look, no plastic belt is vissible
      04-24-2024, 02:44 AM   #136
M2Jorge
M2Jorge's Avatar
Drives: G87 M2
Originally Posted by Liosandro View Post
Nice job.
Thanks
Ale
My final measurements were 57cm x 16 cm
      04-24-2024, 10:41 AM   #137
Danman5666
Drives: 24 M2
Originally Posted by bmhewett View Post
It's much more inexpensive than ZunSport, but I do not like how it's zip tied. I wonder how long it'll last this way.
      04-24-2024, 03:27 PM   #138
bmhewett
look, this grill will last for years in place for sure, these are some advantages i see among other grills:
1.- light weight, made of plastic just like oem radiator grills, forget about heavy metal grills or complicated installation with screws or even drilling holes.
2.- even better than OEM lower radiator grill because that one trends to accumulate leaves between grill and radiator.
3.- it actually looks cool and grill pattern matches G87 character
4.-very easy to install, it took me less than 20 mins. just loose lower bumper and install plastic belts surrounding inner frame
5.- protect both radiators (lower and horizontal)
6.- super easy to remove in case you need radiator maintenance
      04-24-2024, 03:37 PM   #139
bmhewett
clear look, OEM style, at very low cost..
      04-24-2024, 03:45 PM   #140
aerobod
Car Geek
aerobod's Avatar
3721
Drives: Caterham R500, M2-G87, Macan S
It's a lot cheaper to just buy the material on eBay (such as https://www.ebay.ca/itm/204416556798...iABEgKwDPD_BwE) than paying a markup from www.radiatorgrillstore.com/bmw for the same or similar material and a few zip ties, if you don't mind the visible zip ties and the likely scuffing of the black plastic finish they will cause.
      04-24-2024, 10:03 PM   #141
bmhewett
yea, i agree but this grill comes in the perfect size.
      04-25-2024, 12:10 AM   #142
ModernAngel
Drives: 2023 M2
Yup. Got this same grill protector. Super easy install. Almost impossible to notice the black zip ties.
Literally can’t care less about any potential scratches or marks the zip ties might make down there. For one, I’ll likely never remove them, two, that area gets hit by little pebbles and road debris anyway and three nobody is going to care or look for scratches down there whenever I get around to trading or selling the car. Certainly no dealer is gonna give a hooey looking for tiny scratches in plastic bumper parts 8 inches off the ground to lower my trade-in value.
Gonna drive my car and enjoy the cheap, decent looking and super easy to install protection and get on with my life.
      04-28-2024, 07:52 PM   #143
bmhewett
      05-02-2024, 01:53 AM   #144
Liosandro
Drives: G87 M2
Thanks!
Will do something on mine in the next days!
Ciao
Ale
      05-02-2024, 03:48 PM   #145
Dbimmer
Dbimmer's Avatar
Drives: M2 Frozen Pure Grey
2024 BMW M2 G87  [9.00]
Originally Posted by RootsTootsMagoots View Post
Ordered 17119882366 from ECS. It looks like it's the smaller size and I'm praying I can just slide it in.
How did it go for you
      05-02-2024, 07:39 PM   #146
RootsTootsMagoots
Drives: G87 M2
Unfortunately, ECS has took forever to ship. It was supposed to arrive today, but it did not. Hopefully it shows up tomorrow, and I can put it in this weekend. I'll report back when I do.
      05-02-2024, 08:10 PM   #147
exmowner
exmowner's Avatar
684
Drives: 22 M3X / 14 GTR
I just received mine yesterday. Are you planning to remove the bumper ?
If there is a simpler way to install it do you mind sharing.
2022-G80 Xdrive BG
2014-GTR BE FBO
2016-HURACAN 610-4 (SOLD)
2021-G82 BASE (SOLD)
      05-05-2024, 01:32 PM   #148
RootsTootsMagoots
Drives: G87 M2
I just did it this afternoon. Pics attached. I took tin snips to the top two tabs. I also snipped just one side of the flanges. I chose the short one. It wouldn't fit with both of those. I found it easiest to get it in by starting on the passenger side. I slowly fed it through. It's a very tight fit. I had some long zip ties which were a PITA to fish behind the radiator. I did two on bottom and two up top.
I realized afterwards that I installed it backwards. Oh well.
      05-05-2024, 04:05 PM   #149
RootsTootsMagoots
Drives: G87 M2
OK, an update. I reinstalled it the correct way this time. Didn't take pictures since it started to drizzle. It definitely looks better the correct way. Make sure the flat side is facing the radiator. I nicked my radiator in a few spots so be more careful than me. It's nice having something "OEM-ish" protecting it.
Edit: Also, to put it in the correct way, you'll need to take tin snips to the protruding ends on either side. I didn't make it flush, but it was pretty close. I took 80 grit sandpaper and sanded the rough edges down because you can definitely scratch your paint/PPF with the sharp edges.
Last edited by RootsTootsMagoots; 05-05-2024 at 04:29 PM.. Reason: Added instructions
      05-06-2024, 08:22 PM   #150
Dbimmer
Dbimmer's Avatar
Agreed. Looks OEM with those. Rather have that and have leaves coming in than putting the aftermarket ones
      05-11-2024, 01:04 PM   #151
*bimmervibe
*bimmervibe's Avatar
Drives: G87 M2
I just got my g87 AT. Considering going this route or the stradale grill. What part of the radiator did you zip tie to? Do you have a picture?
      05-11-2024, 05:00 PM   #152
MADBMWX5MC
MADBMWX5MC's Avatar
1024
Drives: 2023 BMW X5MC
Partner, that looks great.
2021 Jeep Grand Cherokee SRT Black
2006 Ford Mustang GT Convertible (show car)
      05-12-2024, 07:11 PM   #153
Mr. Hankey
Christmas Poo
Mr. Hankey's Avatar
1173
Drives: 2024 G87 6MT
Made my own using a black powder coated honeycomb aluminum mesh:
Drive the Manual - 2024 G87 - Mr. Hankey's M2 Build Thread
Ronin76869.00
      05-12-2024, 08:16 PM   #154
Zirenz2006
Zirenz2006's Avatar
Drives: G80 M3 Comp IOMG
Can you post a close up picture please? Did you attach it with zip ties?
Current: 2021 ///M3 Competition Isle of Man Green
Ordered: 2024 ///M2 Zandvoort Blue
Past: 2018 X3 ///M40i | 2012 328i | 2009 335i | 2007 335i Coupe | 2005 545i | 2001 325i
Mr. Hankey1172.50
g87
