2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions Vibration at 55mph after brake pads replacement?
      11-25-2023, 10:55 AM   #1
bfiv8
bfiv8's Avatar
Drives: '20 M340i, '18 971 4S
Hello everyone,
I've replaced both brake pads last week and I'm experiencing a noticeable vibration at a constant speed between 55 and 65mph right after the front brake pads replacement. Didn't notice any vibration when I left my car at the shop to let them perform a replacement of rear brake pads in which I'm assuming that something went wrong during front pads replacement (because fronts were replaced the next business day). Even the rear seat passengers can feel the vibration, although it is more prominent on the front seats. This happens with no pedal engagement, so basically the vibration is present during coasting at a constant speed. Going beyond 65mph or below 55mph gives no problem at all, but the vibration is present at 55mph the most and gradually goes down until it hits 65mph when it disappears.
I did some research over this week and it seems like the existing problem corresponds to the brakes (either it be warped rotors or calipers not engaging properly. I also found out that the car might need re-balancing of the wheels/tires to let the vibration go away but it was quite odd given that mine was performed with a road-force balancing last week along with replacement of rear brake pads. Maybe low thread on rear tires, but I doubt it'll be the case since the vibration suddenly came up after the replacement of front brake pads.
I need some insights from you guys. What might be some culprits? Any help would be greatly appreciated 🙏🏻 Happy belated thanksgiving yall!
'20 M340i
DAW Gen 2 Flow Max
93 oct custom tuned by Shoup
      11-25-2023, 11:44 AM   #2
jpowers36
jpowers36's Avatar
Drives: 2020 BMW M340i xDrive
How many miles on it?
2008 Infiniti G37S Coupe 6MT - Black/Black
IG: jpowers36
      11-25-2023, 02:52 PM   #3
Stag77
Stag77's Avatar
94
Drives: '24 M340i XDrive
It could be a lot of things, unfortunately, like worn tires or poor alignment. My first guess would be the tires being unbalanced, but you've just had them balanced. Maybe have the balance checked to make sure it was performed properly?
I highly doubt it's your rotors, as you'd have felt them long before switching pads. I'd say your best bet is to bring it back to the shop and raise your concerns with them.
      11-25-2023, 03:03 PM   #4
bfiv8
bfiv8's Avatar
Hey dude, got 34k miles on it!
      11-25-2023, 03:05 PM   #5
bfiv8
bfiv8's Avatar
Will definitely check with the shop on monday! It was super weird as all the vibration suddenly came up after front brake pad replacement
      11-26-2023, 06:55 AM   #6
Bc2005
Drives: 2021 M340i
Have them also check the tires over very carefully.
Had a similar problem once after BMW service and it turned out to be a large diameter screw/bolt that one tire picked up from the service bay floor. It wasn’t long enough to cause a puncture, but big enough to put the tire out of balance.
balancing, brake pads, brakes, caliper, g20, m340i, rotors, vibration, wheels
