11-26-2021, 05:56 AM | #133 |
Rep 922
Been thinking....
How many xDrive vehicles do BMW sell in a year? How many people are religious about star marked? How many problems are reported? A lot. Possibly not a huge number. A few. And let's face it, if it was a common issue, you'd be mad to buy a used xDrive if you have no idea what tyres have been on it. Is there a big caveat about buying used xDrives?
11-26-2021, 06:07 AM | #134 | |
Rep 15,858
Tyre sizing mentioned today, definitely opens up the 'technical' debate for sure.
I try to keep up with the developments at BMW, but find the latest tyre observations and fitments do appear to contradict on many fronts. Will need to re-read some of the data and technical details. Issues it raises for me, is not just xDrive, but functions like DSC and ABS as well. (I remember the time when odd tyre treads, across an axle, could mess with DSC and AT gear change function). The concept of xDrive is for variable 'front to rear' torque transfer. If the tyres are outside the 1% allowed for "tyre tolerance logic", it does pose the question what's the normal running state? How is the sensitivity of xDrive controlled with possibly wider limits? Quote:
Also DSC sensitivity... do BMW have to reprogram for the different tyre sets? The understanding is, all four wheels have/require a "baseline", (same for ABS), from which any deviation triggers intervention. To me, the tyre options observed, (and as options) do muddy the waters. Definitely requires more understanding. I'm not seeing (at present) where BMW are getting the 'slack', with such sensitive systems. For example, with different RC, front to rear, either the transfer clutch is open much more, (with the inherent heat management issues) or the tyres micro scuff. Perhaps BMW are confident in their latest ATC13 transfer box oil flow and heat management improvements, to move to wider tolerances. |
11-26-2021, 06:27 AM | #135 | |
Lateral grip estimator
957
Rep 1,390
And of course it has a steering angle sensor too so can do the maths for different rotations depending on cornering radius. Oh, and the M sport pro pack on the M240i (with the different wheels and tyres) does also mention additional transmission cooling actually...
HighlandPete6658.50 |
11-26-2021, 06:34 AM | #136 | |
Rep 15,858
Interesting comment on the M240i, will try and get to the technical data. |
11-26-2021, 06:51 AM | #137 |
Rep 922
There was an option for Winter/All-season and summer. I put Cross Climates as sumemr, but maybe I should have put in All Season!
11-26-2021, 11:41 AM | #138 |
Rep 2,176
11-26-2021, 11:52 AM | #139 |
Rep 922
Yes but when you go and set the tyres, their is no 19" option for Winter?All-Season. Frankly this topic is just shambolic by BMW.
11-27-2021, 08:30 AM | #140 |
Rep 2,176
11-27-2021, 10:49 AM | #141 | |
Rep 15,858
I'm working through some of the technical data (when I've got a few minutes spare). BMW are continuously improving the designs (as I've previously commented on) and are clearly changing the xDrive working parameters.
I've not got the complete picture across the models, but some of the M-Lite and M-cars (even in AWD mode) are definitely not using xDrive in the same way it was used in past generations of vehicles. Still piecing together how this is implemented in other xDrive models. Just one example, which indicates how BMW can offer what appears 'odd' wheel combinations, is the new F42 M240i: Quote:
11-27-2021, 03:03 PM | #142 | |
Rep 2,176
11-27-2021, 03:29 PM | #143 | |||||||||
Rep 15,858
More to follow on heat control, and the ability to have an open clutch pack, in more driving situations. |
11-27-2021, 03:38 PM | #144 |
Rep 2,176
I think so!........The current xDrive systems under 'normal' everyday driving conditions are operating the car as a RWD in effect and only when certain criteria are met due to changing conditions then the FWD capability is brought in to play?
Presumably meaning that the concerns regarding transfer boxes being destroyed as a consequence of unapproved tyre choices are becoming more and more infrequent? |
JNW13122.00 |
11-27-2021, 04:19 PM | #145 | ||
Rep 15,858
It is clear with the G12 transfer box (ATC13) advances, and applying them to the F90 M5. requiring xDrive with a RWD (only) mode, BMW have tested the waters for running an open clutch pack in many more driving situations. This is possible with the design changes to heat management in the transfer box, 2-part oil reservoir, lower churning losses and much better heat control. The open or 'over-open' clutch pack as mentioned by BMW, appears to enable a greater rolling tolerance in motion, in many more driving situations. Although BMW still add the caveat in many technical documents, describing the improvements, with something like... Quote:
11-27-2021, 11:54 PM | #146 | |
Rep 2,176
I reckon the point you make about the M5 is very valid. With that car, traditionally a ‘dyed in the wool’ RWD to be given AWD capability, much to the understandable horror of ‘M’ car purists, clearly required BMW to make a change in the way they thought about xDrive and approach it from a different direction. In other words not “how do we make an AWD feel like a RWD” but rather a case of “how do give a RWD car an AWD capability as well”? |
11-28-2021, 04:22 AM | #148 |
Rep 146
As someone new to the forum I just wanted to give a big shout out to everybody who contributes to these threads and posts.
I am a complete layman in terms of my technical and mechanical knowledge, and I guess would be your typical consumer buying a car having read several reviews and maybe having test drove the model I’m interested in. Certainly this forum has thrown up some questions that I would never have known to even think about, let alone try and find answers too, from star or non star marked tyres to the mechanicals of the xdrive system to over the air updates. Obviously a very knowledgeable bunch and it’s refreshing being on a forum where all levels of knowledge and ability can post freely and get involved in the discussions. To everybody who posts, keep it up and to those ( you know who you are) that generally go above and beyond researching topics in their own time then a big thankyou. |
bmnut813.50 HighlandPete6658.50 |
11-28-2021, 05:55 AM | #149 | |
Rep 922
Looking at the 2 sentences of the quote..... The first one is partly meaningless. We all know that the general advice is to use same tyres on both axels (and especially so on individual axles). I do wonder about tyre wear on a RWD bias xDrive, though maybe things even themselves out with steering/weight on the fronts. Not had the car long enough to find out. Would it be too much reading into the use of the word "recommended" on my part? Star marked = approved, so what are "recommended" tyres?
11-28-2021, 06:13 AM | #150 | |
Rep 2,176
11-28-2021, 07:26 AM | #152 | |
Rep 15,858
What also appears possible, is different software adaptations for different models. When I read comments that Sport and Sport+ can also reduce transferring torque to the front wheels on some models, makes it difficult to know exactly what 'finer' functions do exist on a given model. M240i, data spells out the limited front wheel drive connection in normal driving. RWD bias is being emphasised. M-cars, definitely have reduced AWD function, even the switch to 2WD Current M-cars (for example, the G80/2 M3/M4) are getting a technically revised version of the ATC13, with added oil control/cooling features. These improvements also indicate the 'weak link' is still controlling heat and wear in the multi-clutch pack. I'll keep digging. |
bmnut813.50 verysideways956.50 |
11-28-2021, 07:29 AM | #153 |
Rep 15,858
