06-30-2020, 05:00 PM | #1 |
Rep 14
330e Exhaust Flaps
Hi All,
I have been reading online / you tube etc that it may be possible to unplug an exhaust flap actuator on some models of car for an improved exhaust note. Has anyone done this with a G20 330e ? Did it work ? Any Change improvement ? |
07-01-2020, 06:29 AM | #2 |
Rep 320
I've seen it might be possible to do a res delete on them which would also help.
That was a mod I did on my GTI and it made a really nice difference. Easy to swap back at the end of the lease as well!
Arrived: '20 330e M Sport in Mineral Grey
'03 MY 996 Turbo in Arctic Silver Gone: '18 Golf GTI Performance DSG in Tungsten |
07-01-2020, 01:15 PM | #4 |
Rep 274
Resonator delete, so you get your burbles and crackles.
Example: Last edited by Funboy78; 07-01-2020 at 01:24 PM.. |
07-02-2020, 04:00 AM | #5 |
Rep 320
There's a large resonator which can be exchanged for a link pipe. Fairly straight forward and can be put back in for resale/return. Frees up some good noise. Not sure what options there are yet in the UK.
Does anyone know if the exhaust is the same as the 330i?
02-27-2021, 10:55 AM | #6 |
Rep 34
I’ve just taken the spring out of the actuator with a pair of pliers and used some metal wire to hold the flap open. Definitely a difference on idle, not gone for a drive yet due to plenty of rugby to watch today. I will let you know tomorrow if the driving sound is noticeably different.
normimb3.00 |
02-27-2021, 11:27 AM | #7 |
Rep 8,081
There is no need to wire or hold the flap open - simply allow the actuator to open the valve (by running in sport mode) and then simply disconnect the actuator. Job done.
02-27-2021, 11:44 AM | #8 |
Rep 858
Excuse my lack of exhaust knowledge, but what does the actuator do? Guessing it closes off one branch of the tail pipe, but what's the benefit in that?
Assuming it's added to the car for a reason
02-27-2021, 11:52 AM | #9 |
Rep 8,081
It closes off the RHS outlet for noise reduction. I don’t care about the noise but I can’t stand to drive in winter with vapour only coming from one side making it look like a naff fake exhaust. I shall open the flap and leave it like that.
02-27-2021, 11:58 AM | #10 |
Rep 858
Yeah, one working pipe would look a bit poor.
So disconnecting doesn't throw any failure codes? Maybe you would be so kind as to take a few photos of the process of disconnecting for others to follow? Guessing there's issues with protecting the unplugged cables from the elements though.. Maybe a nice project for someone with a 3d printer to make something that could sit inbetween the cable and the actuator to enable it to remain plugged into something, but not actually doing anything.
02-27-2021, 12:10 PM | #11 |
Rep 8,081
Absolutely. No failure codes but you are right that you should protect the disconnected plug and socket. A small polythene bag and ty-rap is all you need. When I get the car on Monday it will be the first mod. I’ll take some pictures but plenty on YouTube already.
02-28-2021, 02:43 AM | #12 |
Rep 858
Would be nice if the actuator could be disabled via bimmercode. Or programmed to remain open in all drive modes.
Can just see repeated issues and awkward discussions with the service dept of the dealers when they notice the plug disconnected.
02-28-2021, 03:05 AM | #13 | |
Rep 13
Mine is being delivered this week and it is something I definitely want to do |
02-28-2021, 09:49 AM | #15 | |
Rep 34
Definitely a better sound when driving(330e) and it no longer looks like one tailpipe was fake. When I was considering unplugging or taking the spring out I did notice that the valve opens and closed multiple times on idle, so I guess you have to unplug at the right time. This also isn’t an issue if you just remove the spring and use some wire to hold the valve open. |
normimb3.00 |
02-28-2021, 12:03 PM | #19 |
Rep 858
if you need to manually open the flap after removing the spring, does it need the wire to hold it open? or that just there for belt and braces? Don't suppose you have a 'before' photo?
thanks be interested to hear if anyone notices fuel economy drop significantly. Being a tight old man with two kids, that would probably be more important to me than noise.
02-28-2021, 12:08 PM | #20 |
Rep 8,081
I guess it will move reasonably freely when not attached to anything so the wire will keep it where you want it.
I can’t see how it could possibly affect fuel economy? If it makes any difference at all it could only reduce back pressure thereby making the engine breathe easier and improving economy. I can’t see how realistically it would make any difference but not for the worse. |
willougs265.00 |
