2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions Help with coding G22 430i Adaptive Sound Design& Blinker sound level
      04-26-2024, 03:25 AM   #1
dymmy
Drives: 430i
Hi, I've tried searching for a definitive answer to this common problem worsened by adding an after market amp. All threads I find end up being sureness about not using indicators at all or wanting more burbbles coming from the ADS fake system.
My issue is switching off the fake engine sound entirely. So far using bimmercode app, I tick the deactivate box and nothing changes, even after changing the license to deactive
Each time i start the car the sound is set back to 'depending on driving mode'
I would simply like it off, full stop. Due to the amp it sounds sillier than usual and I'm almost sure it used to stay in 'reduced mode' if i selected it within the head unit.
Second issue is the ridiculously loud blinker sound coming through the drivers side door speakers. Without music playing it is twice as loud as it used to be before fitting the amp. Any help coding these issues away and helping me not regret upgrading the stereo. .
      04-26-2024, 03:36 AM   #2
Torettoshifts
Drives: G30
You can dm @btoretto5 on Instagram they can remote in and sort it
      04-26-2024, 04:09 AM   #3
dymmy
Drives: 430i
Thx, that's helpful. Is it not possible using bimmercode app?
      04-26-2024, 04:29 AM   #4
dymmy
Drives: 430i
      04-26-2024, 08:40 AM   #5
zazzau
Drives: 2021 M340i XDrive
You might want to move this post or repost to the DIYs and Coding Discussions sub.
Engine Sound works just fine for me and always remembers the last setting - it never reverts to "depending on drive mode" for me. I've got ASD coded off; even when I set Engine Sound to "Sporty" it is 100% exhaust note; no fake sound.
This was working before I upgraded to 11/2023 software - and it's still working on this version. G20/M340i
      04-26-2024, 12:58 PM   #6
komoornik
Drives: M440i G23
Also - the setting in the iDrive does not only affect the artificial sound, but exhaust flaps too.
      04-28-2024, 12:51 AM   #7
dymmy
Drives: 430i
Thx for the response, I would move it if I knew how. My car is a G22, not sure why it is reverting back to default each time I use the car. ASD is switched to off on mine too but I can still hear silly sound through the upgraded speakers.
The blinker level is more annoying though.
      04-28-2024, 12:52 AM   #8
dymmy
Drives: 430i
I guess I would be happy with mechanical flap related extra sound but not through the stereo at all. Thanks again.
      04-28-2024, 11:28 AM   #9
zazzau
Perhaps code Rolce Royce sound, I find that the blinker sound in that setting is more pleasant to the ears. But if you're bothered by the blinker then not sure anything other than muting the sound will do.
You could search through the DIY and coding sub for ASD - perhaps there might be some additional steps required to turning off. I used Esys to disable mine. BimmerUtility is also popular on the forum.
There are others with G20 who have also noted that Engine Sound reverts back to default at every start up. Perhaps, spend sometime on the Coding sub; it's likely someone there has figured out how to make it persistent. Mine just works.
      04-30-2024, 07:08 AM   #10
dymmy
Drives: 430i
Thx, I will check out these options.
      05-09-2024, 01:19 AM   #11
JoB01
JoB01's Avatar
14
Drives: 2023 i4 M50 & 2008 E90 M3
Is the amp a Match or AlphaOne amp?
If so, the blinker sounds should drop back down to “normal” if you do a Tune EQ on it using an omnidirectional mic, a laptop and the free audiotec Fischer software. Not only that, but your music will sound even better after you’ve set up the DSP…. The reference software tune they provide with the amp has the eq set pretty flat, which tends to amplify the blinker sound for some reason…. I think it might be the default gain.
      05-10-2024, 07:46 AM   #12
dymmy
Drives: 430i
Thx, it's a Match amp with a tune. I am yet to fully understand the software.
It's quite complicated. My local sound man who did the tune may be able to help.
I think the engine sound have actually stored using the bimmercode. I rebooted the head unit after coding it and I'm almost sure it's stopped being audible. It doess however still reset to default 'depends on driving mode' .
