Technical Topics Wheels and Tires 19x8+32 offset with Dinan springs on G20 330i
      05-27-2023, 02:20 PM   #1
ztech
Drives: 2019 BMW 330i
2019 BMW  [0.00]
Thinking about 798M rims with 19 x 8 +32 for my G20 on Dinan Springs. Anyone know if this will work? Thanks
19' 330i G20 E85 Custom Tuned
100-200km/h 11.76 seconds (Racebox GPS)
Full bolt-ons (stock turbo/stock engine)
      06-06-2023, 09:10 AM   #2
Jnasratyar
Jnasratyar's Avatar
Drives: 2023 BMW M340i
2023 BMW M340i  [9.83]
As long as the wheels have the bolt pattern matching the car, the wheels will fit. I am currently running 19x9.5 in the back and 19x8.5 in the front with 35 offset all around on my m340i and it looks amazing. G chassis bolt pattern is 5x112 and the hub bore is 66.66.
      11-14-2023, 05:11 PM   #3
SoFlo M340i
Drives: 2020 BMW M340i
Hey do you have any spacers on your wheel setup? how does it drive? worse, the same, or better than the original wheels?
'20 Portimao Blue M340i – Current
'17 Dark Graphite 530i – Retired
'14 Alpine White 328i – Retired
      11-14-2023, 06:23 PM   #4
Jnasratyar
Jnasratyar's Avatar
I run a 15mm spacer in the front, but the back I don’t run any. Driving is the same, I don’t think spacers or wheels change the ride of the car, that would be the tires if anything.
      11-14-2023, 06:56 PM   #5
SoFlo M340i
Got it. Were spacers too much in the back? Does it all sit flush?
I was wondering if going to the wider tires changed driving since it does change overall wheel/tire diameter. During more spirited driving or coming out of corners, I wondered if response is the same or if it feels different.
      11-14-2023, 07:12 PM   #6
Jnasratyar
Jnasratyar's Avatar
The back didn’t need the spacer, sat flush without. Front needed it though. Wider tires I feel might’ve helped a little bit during spirited driving. I drive in the canyons a good bit and I feel like the wider tire lets you come out of turns a little faster since you got more meat to grip the road. I’ll attach a pic of how she sits now.
      11-14-2023, 08:23 PM   #7
SoFlo M340i
Looking good. I’m about to pick up some wheels that are 19x8.5 30 offset and 66.56 bore. The rears are19x9.5 with a 40 offset, so they should sit similar to yours. Not sure if they 40 offset will be a problem though.
      11-15-2023, 01:15 PM   #8
Jnasratyar
Jnasratyar's Avatar
Thanks, I don’t think the 5mm difference will be noticeable at all.
