2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions Automatic front passenger seat heating?
      01-28-2020, 04:15 AM   #1
Chuckyarla
Ireland
298
Drives: G11 730d M-Sport 2018
I managed to set the driver's seat to heat automatically if the temperature is below 6c, is there a way to set the same for the passenger seat?
Also will the (brilliant) pre-heating turn on the heated seats if it is below the set temperature?
      01-28-2020, 04:38 AM   #2
Tam the Bam
Grumpy Old Git
Tam the Bam's Avatar
443
Unfortunately you can’t do the same for the passengers seat.
As for pre heating .... sorry can’t answer that.
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      01-28-2020, 05:11 AM   #3
Chuckyarla
Ireland
298
Thank you.
      01-28-2020, 11:57 AM   #4
2020g20
Drives: 2020 330i
The incomprehensible seat preheating routine during remote start evidently has no connection to the "automatic activation under XX degrees" rule in iDrive, AND it currently only preheats the passenger seat during remote start, it does nothing for the driver seat. In other words, even if you completely disable the automatic activation rule in iDrive, your passenger seat (and passenger seat only) will still preheat at the lowest level during remote start, then immediately turn off when you open the door to get in. And conversely, if you have the automatic activation rule enabled, that rule won't kick in until you get in and press the Start button to exit remote start mode, and it only affects the driver seat, not the passenger seat.
TLDR; the passenger seat pre-heats no matter what, only during remote start...and the driver seat auto-heats if under XX degrees (if set to do so in iDrive), only after exiting remote start.
Makes perfect sense, no?
jd85_m0.00
      01-30-2020, 09:50 PM   #5
NewM3driver
Drives: 2017 M3 ZCP
It took BMW's years and years to get with the program and offer remote start. Now it sounds like they botched tying in the seat heat? Geez.
      02-04-2020, 05:57 PM   #6
Conezz
Drives: G20
Maybe check with the coding experts if there's a way to rectify it?
      02-04-2020, 06:39 PM   #7
jstnstr
jstnstr's Avatar
Drives: G20 M340xi
Haha, yikes. I'm in Florida. My seat is pre-heated 10/12 months of the year thank you very much. So glad I checked that option...
| Previous: 18 M3 ZCP | 17 M3 6MT | 15 M235i |
