Technical Topics iDrive, Nav, Phone, Audio, Video, Cameras, Electronics Interchangeability of G20 and G30/G11 speakers
      12-20-2023, 12:52 PM   #1
320iG20
Stick Shift ftw ;)
320iG20's Avatar
Germany
24
Drives: 320i
Question Interchangeability of G20 and G30/G11 speakers
Unfortunately my car only has the base sound system without tweeters (OS7/RAM).
I would like to retrofit those with the Harman/Kardon ones and maybe also use the center speakers from the G30/G11 as they share the same tweeter as the G20.
Does someone know, if these are interchangeable and plug & play?
Would the subwoofers work, too? Stock woofers are 4Ω/15w, Hifi 4Ω/25w. Does someone know the spec of the Harman/Kardon ones? And what power is the RAM able to deliver?
      12-21-2023, 07:20 AM   #2
ramparts
ramparts's Avatar
1170
Drives: M40i
They are all identical parts across the range so yes
      12-21-2023, 09:30 AM   #3
320iG20
Stick Shift ftw ;)
320iG20's Avatar
Germany
24
Drives: 320i
Thanks, also the plugs are the same?
I could just replace the base G20 mid-range speakers 65132622560 with the G30 mid-range 65139364956 and add the tweeters 65139362561?
      12-21-2023, 05:34 PM   #4
panki_86
Slovenia
202
Drives: G20 M340i xDrive Individual
You will also need to change RAM from Basic to High and add Booster (ALEV3) for HK woofers.
RAM Modules
-Basic for Base audio
-Mid for HiFi
-High for HK or BW
Boosters
-Base audio is without it
-for HiFi I don't know
-HK have ALEV3
-BW have ALEV4
Also if you have DAB, you need to find RAM with DAB option (HIGH DAB).
And normally you will need to code your VIN number to the new RAM module and add S688 option (for HK) in VO. You will also need to recode HU-MGU unit to HK.
I don't know how is with used RAM modules, if you can get OTA for your car or not?
      12-22-2023, 02:50 AM   #5
320iG20
Stick Shift ftw ;)
320iG20's Avatar
Germany
24
Drives: 320i
Does the basic RAM not offer enough power for the HK woofers?
It should have a 6-channel analog output?
https://www.bimmer-tech.net/blog/ite...system-upgrade
Changing completely to HK would not make sense, as it is more expensive and sounds worse than a third party solution.
      12-23-2023, 02:54 AM   #6
panki_86
Slovenia
202
I don't know, but HK woofers are not even connected to high RAM, they have separate amp called Booster.
      12-23-2023, 08:35 AM   #7
320iG20
Stick Shift ftw ;)
320iG20's Avatar
Germany
24
Drives: 320i
Ok, I also checked the plugs, Base has two pins, Hifi and HK only one per side at different positions. That won't work without custom cables/plugs. Not worth the effort.
And the stock woofer is tiny and only has 15w, Hifi 25w, HK is not specified. Third party woofers have 100+w.
      01-06-2024, 08:53 PM   #8
suchpro
suchpro's Avatar
Serbia
17
Drives: BMW 320d (G20)
This link has a lot of info: https://www.audiokit.fi/kirjoitus/bm...-audio-upgrade
