01-15-2022, 10:46 AM | #23 | |
Rep 692
I went into bimmer code expert mode specifically looking for this entry and can’t find it. Are you sure this is available to g20? It’s not under kombi!
01-16-2022, 05:47 AM | #24 | ||
Luxury at the redline :)
9105
Rep 7,563
As far as the newer "G" generation goes, I can't confirm that this is still possible with certainty because I never actually gotten a chance to experiment with this myself and no one else shared any testimonials of actually accomplishing this. Making an inference, I was assuming that it was all the same between both generations and maybe it is possible but the proper coding parameters hasn't been discovered yet. I really can't say. . |
gnolivos319.00 |
01-16-2022, 08:28 PM | #25 |
Rep 1,479
Drives: 2020 M340Xi (G20)
Poochie ,
I found BLINKER_VOLUME in DKOMBI (Instrument Cluster). Using Bimmercode experience mode, I coded to the value you pointed out above. Quite honestly, I can not tell any difference-- but it may be my ears?
Al
01-16-2022, 09:30 PM | #26 |
Rep 692
That entry has always existed and in past platforms (f30 etc) it did nothing. The CONTI entry was the correct one with actual effect.
RSnic657.50 |
01-17-2022, 05:24 AM | #27 |
Rep 1,479
gnolivos ,
What is the full title of this CONTI function? Is it also in DKOMBI? Thanks
Al
gnolivos319.00 |
01-17-2022, 06:42 AM | #28 | |
Rep 692
I believe it's in kombi yes
01-17-2022, 08:32 PM | #30 |
Rep 853
Drives: 2020 BMW M340i xDrive
I think the turn signal volume is affected by the speed volume system. Might be worth checking out those settings
gnolivos319.00 |
05-24-2022, 03:44 PM | #31 |
Rep 15
Is there any way to change the actual sound? It sound like the click from an 87 cavalier
05-25-2022, 04:09 PM | #32 | |
Rep 8,163
If anyone could find a way to at least lower the volume, I'd be happy.
Dr. Avit Grey0.00 |
11-20-2022, 02:21 PM | #33 |
Rep 3
12-11-2023, 08:23 PM | #34 |
Rep 13
