01-12-2022, 02:39 PM | #1 |
Rep 194
Should you feel suspension change when switch modes?
Hi All - Just purchased my first ever BMW; so excited to join the forum! It's a 2022 330I with the M Sport package. I had one quick question regarding shifting through modes. Can you shift from Eco/Comfort/Sport at any speed or parked? At moving speeds and switching I don't feel anything upon switch, but if parked or at very low speeds you can feel sometimes a slight jerk when switching. After the mode is switched it's fine. Is this just the suspension/steering adjusting itself to the new mode?
01-12-2022, 04:00 PM | #3 |
General
13235
Rep 19,728
I have never felt a jerk when switching modes. Do you have the Adaptive M Suspension? If not, when you change modes the suspension is not affected.
Congratulations and welcome to the forum. Good luck, enjoy and be safe.
01-12-2022, 04:35 PM | #4 | |
Rep 15,858
For example on the move; If all functions are checked for Sport mode and you have AT and adaptive damping, toggling from Comfort to Sport, steering stiffens, AT will drop a gear or two, throttle is more sensitive, and suspension firms up, all changing immediately. The jerking when stationary... If you have AT and are in Drive, it could be a down shift, (2nd to 1st) ready to move off, if say you switch to Sport from Comfort. |
01-12-2022, 04:52 PM | #5 | |
Rep 64
I have the same color combo. beautiful car and congrats! I have the adaptive m suspension and I can tell the difference between sport and comfort. I can tell the switch happens maybe 1 second after I push the button. one other thing to consider is the road surface. ion bumpy roads or curves I can tell easily. but in fresh paved roads it can be challenging to tell if the suspension changed. I can easily tell now after 6 months but I can see where you still need to learn the quirks of your car. anyways enjoy the new ride! post more pics too |
01-12-2022, 05:46 PM | #6 | |
Rep 761
You don't need adaptive suspension for that. Would that be different for the 330i?
01-12-2022, 05:52 PM | #7 |
General
13235
Rep 19,728
The M Sport suspension is a passive suspension that is not affected by the drive modes.
wtwo317968.50 |
01-12-2022, 06:11 PM | #8 | |
Rep 1,261
The only jerking you would feel is if you switch to sport and it downshifts aggressively. |
01-12-2022, 09:36 PM | #9 |
Rep 692
If parked and you switch modes you will hear a click. It's not the adaptive suspension changing. I have confirmed that. I suspect the click is the engine mode changing.
Long story but I verified this scientifically by setting up the Individual modes in specific ways and switching back and forth. And reached that conclusion.
01-13-2022, 04:58 AM | #10 | |
Rep 1,138
Drives: Z4 M40
Garage List 2015 Yamaha FZ-09 [10.00]
2018 BMW S1000XR [9.83] 2018 BMW R1200RT [10.00] 2023 BMW X4 [7.88] 2022 BMW Z4 [9.78] |
I have a 2019 440gc that does not list any special suspension on its monroney and yet in the pictogram displayed when you set up sport individual mode it shows the suspension being affected. I believe it refers to it as being the chassis. I'd be surprised if they deleted this type of suspension with upgrade to the new g20. From everything I've been able to find about AMS (which isn't much), it seems like programming to automatically adjust the suspension based on how you are driving and even on the road ahead if you have a gps route entered. Being that its only $700, that kind of supports my theory i think, especially when wireless charging is 500 and remote start is 350. TB or anyone else with more knowledge/info here please enlighten me. Last edited by SpeedyATL; 01-13-2022 at 06:57 AM.. |
01-13-2022, 07:12 AM | #11 | |
Rep 15,858
You require the different hardware for variable damping, there is no in between, even if drivers 'feel' there are differences. The only thing that could change the chassis 'feel' on a passive suspension example, is the steering weighting, changing with the modes. |
SpeedyATL1871.00 |
01-13-2022, 08:47 AM | #12 | |
General
13235
Rep 19,728
I can't speak to your 440gc but what you are describing is the Adaptive driving mode. For that you need to have an Adaptive suspension. Edit: For some more information on the Adaptive driving mode, here is something I got from another forum that I post every so often: "I asked BMWGenius to explain Adaptive Driving Mode in more detail, including whether or not it switches between comfort and sport depending on the situation. Here's what they said. The Adaptive Driving Mode is a unique driving mode, separate from COMFORT, ECO PRO, and SPORT. While driving in Adaptive Driving Mode, the vehicle does not switch to COMFORT or SPORT mode automatically. However, characters of COMFORT or SPORT will be implemented, depending on the situation. The vehicle is considering many factor to determine the optimal drive feel. Along with acceleration, steering, and speed, the vehicle is also factoring in driving conditions, braking, cornering speed, input from the xDrive system and Navigation data. When the Navigation system has an active guidance, the Navigation data is used to anticipate curves, crossroads and type of street or road that you are driving on. For example, it can select the optimum transmission gear in advance, potentially enhancing efficiency. I responded with this: One more question: Some have suggested that Adaptive Driving Mode learns how you drive over time and adjusts itself based on that history. Is that true? Or does it just adapt based on the current situation without regard to history? Here is what they (a different person) said: In Adaptive mode, the following influences on the driving style are taken into account, among others: • Longitudinal dynamics • Current speed • Pedal sensor position • Cruise control (sensor data from ACC radar sensor) *If equipped • Sport shift gate for automatic transmission • Turn indicator • Steering wheel movements • Navigation data "ADAPTIVE" reacts to the current driving style. The affected control units can change their parameters on the basis of the detected driving style. This system will not use previous driving tendencies to change settings for the current trip.""
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50 Last edited by TurtleBoy; 01-13-2022 at 09:10 AM.. |
01-13-2022, 09:16 AM | #13 | |
Rep 2,983
01-13-2022, 09:51 AM | #14 | ||
Rep 692
In all seriousness, the click is not the active dampening. Has to do with some other setting (chassis/engine/wheel?). It's easy to prove. In any case this was not the main topic of discussion and I only provided this info as an interesting little fact. Click click click!
01-13-2022, 10:38 AM | #16 | |
drives cars
243
Rep 319
Drives: '23 IS 500, '23 X3
2023 BMW X3 | Phytonic Blue | Black Vernasca Leather | Dark Wood Trim 2023 Lexus IS 500 F Sport Performance | Infrared | Black NuLuxe |
01-13-2022, 10:42 AM | #17 | ||
Rep 692
01-13-2022, 10:44 AM | #18 |
drives cars
243
Rep 319
Strange. Is it this sound?
https://photos.app.goo.gl/uYL4Gzou9SrFJQBn7 Don't want to stray too far off-topic... but I think OP's question has also been answered. FWIW, my car does not have adaptive suspension.
01-13-2022, 12:53 PM | #19 |
Rep 194
Thanks everyone for the replies! So as someone said; it makes sense now that the small jerk was just a downshift. Going slow through my parking lot and switching to sport mode, I think causes the car to downshift to a lower gear which is the reason for the quick jerk. I don't have the adaptive suspension; but the salesguy told me going into sport mode the suspension gets firmer as well as steering (along with the higher shift points). So I guess adaptive suspension auto switches suspension between sport/comfort where as you don't have that your suspension is stuck on sport or comfort but doesn't switch on it's own? And thanks for the compliments; I'll post some more pics soon!
RoGo330i142.50 |
01-13-2022, 01:32 PM | #21 | |
General
13235
Rep 19,728
The Adaptive suspension does not automatically switch between comfort and sport, you need to change the drive mode for that to happen. The Adaptive drive mode is something different and explained above.
01-13-2022, 04:09 PM | #22 | |
Rep 15,858
There is a lot of confusion out there on what changes when there is no adaptive suspension option fitted. This has been the case since modes were introduced and a chassis option could be checked. As I've mentioned in an earlier post, any difference in 'feel' is the steering weighting. Some users have been sure there is some other suspension option working in the background, (even without adaptive suspension), as there is a noticeable change moving from Comfort to Sport mode. This can be a real feeling, but there is no suspension change. The passive systems fitted are either standard or M-sport, according to model. Both are pre-set from factory, no changes possible by the user, or link to the car's vertical dynamics management. |
RoGo330i142.50 tylers1027127.50 |
