01-14-2022, 02:19 PM | #1 |
Rep 18
Moisture in headlight taillight
Hi I just noticed that both my right side headlight and taillight have moisture in them. I live in Winnipeg and it gets really cold in winter. 5 month old m340 with laser headlight. Anyone experienced this?
01-16-2022, 08:55 AM | #2 |
Rep 685
Perfectly normal at least on the headlights. It even says so in the manual.
Not sure about the tail lights.
01-16-2022, 10:38 AM | #4 |
Rep 685
Must have been excessive? Manual says some moisture is normal and I've seen it in 2 g20 I test drove
01-16-2022, 04:42 PM | #5 |
Rep 81
Some moisture is normal for headlights and taillights. They have a small hole located on the backside and that hole is covered with a vent patch. This patch usually is made out of a material like gore-tex. So moisture can exit thru vent patch and it will prevent water from going inside headlight.
Sometimes this vent patch is not applied correctly from headlight manufacturer or lamp itself is defected and it is not sealed properly (pin holes in epoxy or molded plastic, misplaced boot etc). If you think there is more moisture than normal I would take pictures and show them to dealer. Best case scenario, they will replace it. Wort case, they will say it is within spec. I don't think replacing headlight will hurt BMW. They will charge the headlight manufacturer for the warranty replacement so they might just replace it. |
Chubbiejones886.50 |
01-17-2022, 11:14 AM | #6 |
Rep 166
It was identical to yours and they change it but now my passenger headlight as some watermark inside but they didn't approve it and say I should keep watching it
01-17-2022, 11:44 AM | #7 |
Rep 59
Same issue with laser front lights and right rear lights, bmw told me that normal and is stipuled on manual if you cant see water inside the light,bmw will dont change the light
