2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions Remote Services/Start via MyBMW App Never Works
      01-18-2022, 05:10 AM   #1
Enigma735
Drives: 2012 F30 328i Sport Line
Anyone else have this problem? I can get OTA software updates just fine in my above ground, open sided parking garage, but every attempt to Remote Start / lock / unlock / update vehicle status in the App fails. Is it using a different cellular band or satellite to relay from BMW? I feel like I wasted money on the add-on.
Hell even in wide open parking lots with full cell service on my phone where the vehicle should have full service it fails more often than succeeds.
      01-18-2022, 06:36 AM   #2
k4sh_90
k4sh_90's Avatar
Drives: 2020 BMW M340i xDrive
Try opening up the app when you're sitting in the car, phone connected to iDrive. That works for me sometimes when syncing messes up, perhaps it'll work with remote services as well.
Can also try removing your car from the app (you'll get a few emails that the car has been removed from your ConnectedDrive account - no worries about those). Wait and hour or so, and then re-add.
Hey Google, play "Who Am I" by Beenie Man
      01-18-2022, 03:59 PM   #3
Frank The Bunny
Drives: 2022 BMW M340i
I had a similar issue after getting the last firmware update. My app wouldn't update my car status, so it thought the car was unlocked or in drive-ready mode (or something like that). Which meant I couldn't remote start.
I found this post, and it fixed my issues. Not sure if this will help, but worth a try.
https://g20.bimmerpost.com/forums/sh...php?p=27311504
RCook42.50
      02-14-2022, 02:41 PM   #4
Enigma735
Tried all that. I’m guessing maybe the Remote Services use AT&T and maybe AT&T signal is weak here? I have full Verizon LTE service fwiw. Either that or my antenna is not working right.
      02-14-2022, 06:28 PM   #5
Redditor9000
Drives: 2022 M440i GC
If you click your key fob lock button 3 times, what happens?
      02-14-2022, 06:28 PM   #6
jpowers36
jpowers36's Avatar
Mine works like 70% of the time. Sometimes I have to close the app and just try it again. I have Xfinity cell service (uses Verizon network). Haven't been able to figure out the thing that causes it not to work. Luckily my key fob works from inside the house and my from my desk at work lol. That's where I use the remote start feature the most.
2008 Infiniti G37S Coupe 6MT - Black/Black
IG: jpowers36
      02-16-2022, 05:25 PM   #7
Enigma735
If I’m within 30 feet of it, it starts. Which doesn’t help much on cold days when I have to walk across our big ass apartment complex to the garage on the other side. Which is definitely out of range of the fob.
Also, I was picking up food yesterday in a highly populated, well covered service region in metropolitan DC, and my car was within view, and I had full service on my phone and tried to initiate remote start 3 times and unlock 2 times from the MyBMW App, and all failed.
      02-16-2022, 06:53 PM   #8
Aero7000
Aero7000's Avatar
246
Drives: M340i DravitGrau / Cognac
Remote start with key FOB and via MyBMW are two different things, and both work perfectly on my 2020 car.
The only thing caused an issue, that last soft update (by dealer) turned off remote start via MyBMW app, so I had to find the menu to turn it back on.
      02-16-2022, 07:29 PM   #9
Enigma735
Remote Start is remote start. Same mechanical mechanism is triggered by two different communications mediums. The MyBMW app simply sends a command to BMW’s servers which are then relayed via the cellular connection to your car. The delivery mechanism of the command is all that is different. Fob is long range radio, not cellular. I am not talking about “preconditioning and ventilation” which is what you have if you don’t purchase Remote Start connecteddrive services.
      07-25-2022, 08:53 PM   #10
Enigma735
Bumping because I moved recently to a home with no garage, full Verizon and ATT 4g service, and still can’t get remote start, lock, unlock, etc to work from the app.
Ran through all the Genius steps. They resubscribed all my services.
Local Service Tech couldn’t find codes or “reproduce” even when I showed him multiple failures right next to him with full cell service in the middle of our major metropolitan region. He suspects a hardware issue but doesn’t know what since he has no codes and no logs to verify. Short of trial and error nothing he can do, and says I would have to pay out of pocket for parts and labor to do that since Foreman won’t approve a repair order without an understood root cause.
Now I’m battling BMW to get reimbursed for connected store add on of Remote Start that never works because they claim it must be an “end user” issue and because the Fob start works.
Moral of the story. Fuck connected services.
      07-25-2022, 09:37 PM   #11
zazzau
Drives: 2021 M340i XDrive
Bumping because I moved recently to a home with no garage, full Verizon and ATT 4g service, and still can't get remote start, lock, unlock, etc to work from the app.
Local Service Tech couldn't find codes or "reproduce" even when I showed him multiple failures right next to him with full cell service in the middle of our major metropolitan region. He suspects a hardware issue but doesn't know what since he has no codes and no logs to verify. Short of trial and error nothing he can do, and says I would have to pay out of pocket for parts and labor to do that since Foreman won't approve a repair order without an understood root cause.
Now I'm battling BMW to get reimbursed for connected store add on of Remote Start that never works because they claim it must be an "end user" issue and because the Fob start works.
Not sure why service provider is mentioned in this thread. Does it work when your phone is connected to wifi? If it works from key fob I'm not sure how much traction you'd gain from claiming a refund.
      07-26-2022, 12:43 PM   #12
elambo
elambo's Avatar
238
Drives: 2021 M440i convertible
Does a hard reset of iDrive reset any preferences? I've made a lot of customizations and would rather not need to redo all of it.
      07-26-2022, 06:10 PM   #13
GrannyShiftG80
GrannyShiftG80's Avatar
1286
Drives: G20 330i, G80 M3 6MT
i used to have so many problems with connecteddrive
went to the dealer 5 times, logged in and out, cancelled and reregistered the car, all that bs etc nothing worked
the thing that finally fixed it in the end with a software update to the newest version. everything's been perfect since
      07-26-2022, 08:13 PM   #14
Enigma735
Update. A poster on reddit recommended I try getting BMW Connected Services to try to issue a remote unlock after letting the car sit in an area where I know it should have service. Easy enough I used my wife’s X3 to make sure her remote start worked so I assumed mine should have service. Connected Services tech was unable to reach the car to unlock after 4 painstakingly long attempts including auth token generation.
I decided to do a little test thinking maybe the remote commands are not able to wake the car, so I started it and let iDrive boot. Then turned it off so it was still awake. Locked the car. Walked into my house an initiated a remote start from the app and it worked.
To test this I called BMW Connected Services back and had another tech initiate an unlock, but this time, I had him wait until I turned the car on and off and locked it and walked back inside. Sure enough, he was able to unlock it remotely.
After a few minutes (definitely less that the time it’s supposed to wait to go to sleep), it stopped responding again to me via app or the BMW CS tech.
It appears my car either goes to sleep super quickly and can’t be woken remotely, or the cellular receiver shuts down after a couple minutes within car turn off and cannot receive commands.
      07-26-2022, 08:45 PM   #15
Enigma735
Because as far as I know BMW pushes their remote commands for Assist / Connected Services over a 4G LTE connection provided by AT&T’s network in the US. So if you are in an area of no AT&T 4G coverage, Assist and Connected Services won’t work regardless of whether you have cell service / wifi access on your phone.
      07-27-2022, 08:31 AM   #16
zazzau
Because as far as I know BMW pushes their remote commands for Assist / Connected Services over a 4G LTE connection provided by AT&T's network in the US. So if you are in an area of no AT&T 4G coverage, Assist and Connected Services won't work regardless of whether you have cell service / wifi access on your phone.
Thanks for clarifying. I have terrible cell service at home - I'm on AT&T. I have barely 1 bar on my phone. In fact I use WiFi calling at home because of poor reception. That been said I've never had issues getting my car to start remotely at home.
Could be service provider issue but seems highly unlilely based on update from OP. From OP's update it could be suggestive of a bigger problem. If OP is having this issue at just one particular location then I can understand the argument against service provider/AT&T.
OP ought to take the car to the delearship and have the foreman take a look since the problem is reproducible.
