01-18-2022, 08:07 PM | #1 |
Rep 255
Drives: BMW 320d g20
water leaking into floor
my cup of woes with my G20 continues. my car was a Nov 2018 build, so was one of the first g20s. has had a series of maintenance issues. latest being wet floors on the rear seat areas. the dealer has ruled out the two most obvious causes - blocked sunroof of AC drain. they are still investigating.
what else could have caused the water buildup? has anyone else faced similar issues? |
01-18-2022, 09:16 PM | #2 | |
Rep 81
01-18-2022, 11:29 PM | #3 | ||
Rep 255
01-19-2022, 06:43 AM | #4 | |||
Rep 81
francton126.50 |
01-19-2022, 07:29 AM | #5 | |
Rep 15,858
I'm assuming you or the dealer have checked under the inner doors for damp. Vapour barriers are prone to come unstuck if they are stressed, (likely due to heat on hot sunny days), Moisture on the door sills, in rain, a first clue to water ingress. |
francton126.50 |
01-19-2022, 02:19 PM | #6 |
Rep 255
thanks guys. no dampness or water on the inner doors or nearby area. the car is still at the dealer. they have taken off the carpet to dry it and also try locate the source.
my theory is the heavy rain somehow got water in, it stayed under the carpet (a rubber piece under the driver seat tracks was still squishy after the carpet dried), then when I drove on Saturday this water again wetted the carpet. |
HighlandPete6658.50 |
01-19-2022, 09:09 PM | #7 |
Rep 255
the dealer now thinks is the sunroof that is the source of the leak.. is it somehow possible that the drains are ok, but perhaps the seals are not, and too much water got into the sunroof channel which then overwhelmed the drains? I would have thought that in such a scenario it would leak from the top and not from the floor..
01-20-2022, 12:22 PM | #8 | |
Rep 714
My "gut" is that the dealer just looked at the holes and didn't validate performance of the drains or run a cleaner brush. If water builds up, it drains down the door pillar between the front and back seats. Good luck!
francton126.50 |
01-20-2022, 02:23 PM | #9 | ||
Rep 255
seccsc239.00 |
01-20-2022, 09:23 PM | #11 |
Rep 255
so latest update from the dealer. they have checked sunroof drain lines, it is clear. AC drains are clear too. they have removed the carpet and tried washing the car with someone sitting inside. no sign of a leak. they have given up, can't locate the leak, will now put the car together and return it.
the only other thing I can think of is a potential defect in the underside of the car. I drove over a shallow stream of water on the road. was very heavy rain and water was flowing down the gradient. did not seem dangerous, all the cars drove through it. could this have caused the leak, how hard is it to check? |
01-21-2022, 07:39 AM | #12 | |
Rep 714
As for driving through a stream of water, I don't know. If there was a "hole" in the bottom of the car, in my opinion, the dealer would of I identified it when pulling the carpet. I thought the same thing when I had the issue on the another car but ultimately it was the sunroof. When I ordered the my M340, I did not want the sunroof but was standard and not an option delete. Hopefully this issue is resolved. Cheers!
francton126.50 |
01-21-2022, 04:19 PM | #14 |
Rep 453
I would have custom ordered in a heartbeat if I could delete the sunroof from an M340i. I'm pretty sure the sunroof in my E46 is going to be a problem before it's over and I don't even open the slider.
2003 330i (Titanium Silver)
2023 M3 Competition xDrive (Skyscraper Grey) |
01-24-2022, 07:34 PM | #15 |
Rep 255
The dealers had the car for a whole week now. They say they need the car for another week as the carpets are not dry yet! It's been hot 30 degree days recently and I'm surprised the carpets are still wet, especially since they had taken the carpets out to dry. Does it take this long to dry?
01-24-2022, 08:26 PM | #16 | |
Rep 453
francton126.50 |
01-24-2022, 08:33 PM | #17 |
Rep 255
I agree. However they took the carpet out on Wednesday. Wouldn't it have dried by now, especially in hot weather?
01-25-2022, 02:08 AM | #18 |
Rep 83
Drives: '04 E46 ZHP 6MT, '22 G22 RWD
Mine hasn’t given me any trouble at all with leaks or rattles. The vapor barrier in the front door let water into the car and it took a very long time to figure out that that was the source of the wet carpet after driving in the rain or with the car parked in the rain. The leak was slow enough to make detection difficult. Easily one of the most frustrating problems I’ve had on the E46.
francton126.50 |
01-25-2022, 07:25 AM | #19 | |
Rep 15,858
I know when my car leaked, it took a lot of attention to the thick backing foam, (with a fan heater blowing warm air), as well as on the carpet surface, to get completely dried out, even in our UK summer. |
francton126.50 |
01-26-2022, 02:30 AM | #20 |
Rep 255
The car gods are definitely angry with me. The loan car (118i) picked up a nail puncture. It's fully flat now. The Goodyear tyre does not seem to be run flats (no "Run on Flat" or ROF marking on the tyre). Looking at the flat tyre profile, doesn't look like a run flat (pls see pic). No spare wheel in the car. No tyre repair kit either. What the hell was BMW thinking? Have to now get it towed to the dealer I guess.
01-26-2022, 06:01 AM | #21 | |
Rep 1,687
francton126.50 |
01-26-2022, 07:11 AM | #22 | |
Rep 1,772
I can understand why a dealer won't equip their loaners with spares/repair kit. You could call BMW roadside assistance and you should be on your way. Otherwise I'd tow it to the dealership. Not to sound negative: for what it's worth depending on the loaner agreement you signed the dealer *could* charge you for the damage. Hopefully that's not the case. Oh and good luck with your car. Keep us posted. |
francton126.50 |
