04-01-2023, 04:25 AM | #1 |
Rep 43
M340i LCI Sport VS Sport Plus
Hi guys,
Just yesterday received my first BMW m340i (super exhited so far) love the car. As currenty i'm in the break in period of the car I was wondering what's the main differences between Sport and Sport Plus? Also can i use those two modes in the break in period (I will not cross the 4.500 rev limit of course) P.S the guys at the dealership mentioned that the cars are ready to go from the factory and i don't need to break in.. I'm a bit sceptical about that, what is your opinion? Many thanks. Chris |
04-01-2023, 07:49 AM | #2 |
Rep 395
Ignore the dealer - BMW does specify a break-in period, but it’s quite short. If someone can’t hold off and follow the guidelines for 1200 miles, maybe they aren’t mature enough to have a new car. Or it’s a leased vehicle and they don’t really care (another maturity issue).
AFAIK, you can use any drive mode you want during break-in as long as you follow the rpm guidelines. It’s also best to drive under conditions where the rpm goes up and down frequently, not a constant highway rpm. A nice winding rural road is a usually good choice. Sport plus definitely opens up both exhaust pipes and changes the exhaust tone. It also makes the transmission down-shift automatically as you slow down so you get more engine sound and more power. I’d have to check the manual to find the other differences in the engine and transmission settings. You can also configure sport individual, if you want some sport features, but not all. Also experiment with clicking the shifter over to the manual mode. If you just click it over to manual it will initially still shift normally, but probably never engage the top two gears. However, once you click one of the paddles it will change to full manual and you will have to shift up and down. You might want to also change to the sport mode display so you can see the tach in the HUD. I find that a quick click over to manual is really good for highway merges. It usually drops down at least one gear, and then holds it in lower gears longer to get better acceleration. |
04-01-2023, 08:18 AM | #3 |
Rep 1,664
Yes you can use whatever mode you like. Car break in is a contentious topic. I’ve broken in cars by the manual, I’ve driven them hard from the get go. For a mass produced engine like the B58 I would warm it up, do some gentle pulls to a higher RPM then let engine braking slow the car. After the first couple of hundred miles I would just drive it normally after that. Main thing for any car is always keep the revs below 3-3.5k until the oil is warm.
04-01-2023, 01:47 PM | #4 |
Rep 236
There is a break in period. A guy at the dealership told me to drive it like I stole it. But if you check the manual it says 1200 miles, don’t floor it (ever), not to exceed 100mph and I think keep it under 4000 RPMs. I did my best but I’m sure I broke some of those rules but I tried to take it seriously and I always let my car warm up before I drove it. But I can tell you, unless you’re a corpse, you’ll find it very hard to stick to those rules 100% of the time until 1200 miles. Definitely waited to launch it after the break in period.
Have fun! |
04-01-2023, 01:55 PM | #5 | |
Rep 4,143
sport - gas pedal response less aggresive than sport plus sport - gear changes slower and less aggressive and will use lower gears but there is another mode Sport plus - Sport mode - that is the most aggressive mode |
04-01-2023, 04:58 PM | #6 | |
Rep 43
Whats that other mode you mentioned |
04-01-2023, 10:40 PM | #8 |
Rep 236
04-01-2023, 11:16 PM | #9 | |
Rep 4,143
but in gear flick sport mode, the moment you pull the paddle it is stuck on manual, it will no longer shift for you, i always get caught out and hit the limiter if i forget, eg if i've come to a stop and decide to then gas it. Last edited by G30M; 04-01-2023 at 11:30 PM.. |
james1138122.50 |
04-02-2023, 12:25 PM | #10 | |
Rep 236
Also, sorry to thread jack but you might have an answer to a question that’s bothering me. I’ve read that the car will take on the characteristics based on how you drive. Your post seems to allude to that as well. The problem is my morning commute is in stop and go traffic where you can’t change lanes very much and I’m stuck topped out going 50 mph. So it doesn’t make much sense for me to drive in sport mode so I just use Eco plus. Every other time I have the option to drive on the open road I am in sport plus. Will driving an hour in traffic five days a week in Eco plus mode mean that I will get a less aggressive drive in sport plus mode? Hope that makes sense. |
04-02-2023, 12:31 PM | #11 | |
Rep 1,115
james1138122.50 |
04-02-2023, 01:19 PM | #12 |
Rep 90
Imo sport plus shouldn’t be used in the break-in period because the car holds onto gears way into the rev range and downshifts high into the revs when you brake.
Sport+ is a very fun mode and I’m glad BMW includes it but it is not usable in stop-and-go traffic or even daily driving. Sport is more widely usable. |
04-02-2023, 01:33 PM | #13 | |
Rep 4,143
04-02-2023, 01:34 PM | #14 |
Rep 4,143
04-02-2023, 03:37 PM | #15 | |
Rep 15,858
Also changing modes, or simply flicking the shifter to M/S (in any mode) breaks the current adaptation. BMW data also states there is no driver adaptation held in memory and it starts afresh on each start up. Driver adaptation basics: Note reference to "temporary" adaptation... |
Frank_Zuccarini45.00 |
04-02-2023, 10:25 PM | #16 | |
Rep 236
04-02-2023, 10:56 PM | #18 | |
Rep 4,143
drive like a gran in that mode - it might keep the RPM around 1800-2200 (easier to get that in comfort + gear stick sport i think) drive normally it will keep RPM 2400-3000 drive like a mad man RPM 3500-5000 and gear shifting aggressiveness/clunks/shakes etc also follows on a rainy day you will get the tail sliding even with TC fully turned on, just be warned |
