2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions Switching tire sidewall from 40 to 45 viable on 19" M440i GC rims?
      04-05-2023, 02:57 PM   #1
saudisinaudis
Drives: M440i xDrive GC
G26, tire profile is 245/40R19 on 8.5 rim width
Purpose is to cover wide fender well. Will it cause friction?
      04-05-2023, 03:04 PM   #2
tturedraider
tturedraider's Avatar
Drives: 2018 340i M Sport
Unless you also change your rear tires it will screw up your xDrive. As in it will damage your xDrive system.
https://youtu.be/-ay-8p2p29w
www.bmwcca.org
member #388003 - Use me as a referral
& you could win a one day ///M Driving School!!
___________________________________________
      04-05-2023, 03:10 PM   #3
saudisinaudis
So if I do change all four, no bad consequences?
      04-05-2023, 03:24 PM   #4
tturedraider
I’m not sure. I’ll let someone else chime in on that. It would increase your overall tire diameter by a full inch. Only a half inch increase in radius. I think the odds of rubbing with that small change are low, but I can’t say for certain.
www.bmwcca.org
      04-05-2023, 03:26 PM   #5
saudisinaudis
It shouldn’t, given that lowering springs lower by up to 35mm (more than an inch) on xDrive.
