09-05-2023, 09:44 AM | #1 |
Joint Chiefs of Staff
24197
Rep 190,805
***NEW & IN-STOCK*** BMS Elite BMW/Supra B58TU Charge Pipe Blow-Off Valve (BOV) Kit
IN-STOCK & READY TO SHIP BMS Elite B58TU Charge Pipe Blow-Off Valve (BOV) Kit Finally, that blow-off valve sound you've been waiting for on your B58TU powered BMW or Supra. Designed and manufactured by Burger Motorsports in the USA. The BMS Elite is the highest quality B58TU charge pipe upgrade on the market. Our charge pipe is constructed from high-gauge aluminum featuring a CNC throttle body and turbo flange for a snug, OEM-style fit. It is completed with a glossy black powder coat to coordinate with the engine bay and boasts three 1/8" NPT bungs ideal for an external boost gauge or methanol nozzles. Its double o-ring seal design on the chargepipe flange that attaches to the turbo is designed to withstand up to 40+psi of high boost. In comparison, other makers reuse the single OEM o-ring, which is not suitable for high boost. Also includes a heavy-duty replacement coupler, o-ring, c-clip, and all required installation hardware. This version features the Turbosmart Raceport valve blow-off valve to release excess pressure in the charge pipes when letting off the gas. In addition to intoxicating sound, it reduces compressor surge and improves overall reliability at higher boost levels. Compatible with factory tuning, JB4, and flash tuning. Features and Benefits • Amazing blow-off valve sound • Improved reliability at higher boost levels • Snug OEM fitment • Increased diameter for better airflow • CNC machined throttle body and turbo flange • Reduces compressor surge • Compatible with factory tuning, JB4, and flash tuning. • Includes three 1/8' NPT bungs for methanol/water injection or boost gauges • Heavy-duty reinforced silicone coupler • 100% reversible. • Made in the USA Vehicle Fitment BMW 2 Series • 2022-Present G42 B58 M240i including xDrive BMW 3 Series • 2020-Present G20 G21 B58 M340i including xDrive BMW 4 Series • 2021-Present G22 G23 G26 B58 M440i including Gran Coupe and xDrive BMW 7 Series • 2016-2022 G11 G12 B58 BMW 740i including xDrive BMW Z4 • 2019-Present BMW G29 B58 Z4 M40i Toyota Supra • 2020-Present Toyota GR Supra Mk5 B58 3.0L 6 cyl. What's Included: (1) Turbosmart Blow-Off Valve (1) Lower charge pipe (1) Upper charge pipe with BOV flange (1) 3R2.5 silicone coupler (1) 2.5" Tbolt clamp (1) 3" Tbolt clamp (5) 1/8NPT plugs (1) M6x1x16mm bolt (2) O rings (1) N54 BOV adapter + E clip (2) 90* 1/8NPT to 1/4" push lock fittings (1) 30" 1/4" tubing
09-28-2023, 09:31 AM | #2 |
24197
Rep 190,805
10-24-2023, 09:58 AM | #3 |
24197
Rep 190,805
12-20-2023, 11:05 AM | #4 |
24197
Rep 190,805
12-31-2023, 02:55 PM | #6 |
Rep 66
Drives: 2020 BMW M340i xDrive
01-29-2024, 01:41 PM | #7 |
24197
Rep 190,805
03-08-2024, 10:24 AM | #8 |
24197
Rep 190,805
