09-28-2022, 09:54 AM | #375 |
Rep 255
Drives: BMW 320d g20
I did not remove it. I found that if I press down on the grill it moves a little. Hence it vibrates and rattles against the glass or metal frame under it. I wedged 3mm thick felt tape between the grill and the glass (just pushed down the grill and forced the tape through). This has greatly dampened the rattles. I can still hear sometimes but very faint and only while driving on course chip roads.
09-28-2022, 09:57 AM | #376 | |
Rep 255
10-01-2022, 07:43 PM | #377 | |
Rep 29
It's especially bad on rough roads and maybe colder environments. Sounds like someone shaking a box of tic tacs... but I have misophonia so I'm mega sensitive to noises so I'm very likely exaggerating. |
10-05-2022, 02:33 PM | #378 |
Rep 2
Hello, i have this annoying vibration on my G22 among with several other rattles/squeaks (Driver B pillar, both of ceiling lights, undefined rattle from passenger side and somewhere around back seats) but vibration thing is another level for 30k KM car imo (first year). Anyone come across with this? Sound stops with touching silver frame. Even road marks can cause this sound but not always.
Here are 2 recordings of them https://www.youtube.com/shorts/lmaZMdmmYUc Last edited by beamerboiiii; 10-05-2022 at 04:01 PM.. |
10-10-2022, 04:35 AM | #379 | |
Rep 1
If you can share details would be great seems i have same issue. Thanks. |
10-12-2022, 11:32 AM | #380 | |
Rep 1,798
11-02-2022, 04:38 AM | #381 |
Rep 18
Hi my bmw g20 2.0 gasoline, the car is new it has 1000km mileage, lately when it's cold in the morning my car makes a strange noise,
After starting the engine and driving from 3 km, the engine is not 100% warmed up yet, standing in a stationary gear with the brake pressed, I hear rattling from the passenger area, when I press P at this point, it stops rattling when I press the first gear again with I can hear it again when the engine is already warmed up to operating temperature, this whore does not occur, This sound can only be heard in the cabin, I asked my friend to hold the engine cover with his hand and suddenly the rattling sound stops, I thought that the problem is in the engine cover, unfortunately this is not the reason, I drove 2 days without this cover and the sound still occurs, t sounds like that the plastic hit the plastic with a high frequency, the car was already in the service twice, they looked for a problem but did not find it, On the website they thought it was from plastics in the pit, they attached additional soundproofing, but it did not help .. It seems to me that when the engine is in gear and on the brake, it slightly changes position and some part of the engine may vibrate against something and it makes such a noise, or maybe the exhaust system? But why, when the engine has the appropriate operating temperature, this sound does not occur until the next morning? Have any of you had similar problems? Last edited by Mario2020; 11-02-2022 at 04:44 AM.. |
11-30-2022, 05:39 PM | #383 | ||
Rep 255
11-30-2022, 05:53 PM | #384 | |
Rep 1,798
Advise to take the car in and have dealer deal with it — no pun intended. |
francton126.50 |
11-30-2022, 11:09 PM | #385 |
Rep 302
Less than 20 degrees means my car has started to rattle a lot more, hope it goes away in the spring lol
2022 M340i xDrive, Mineral White/Tacora Red, Modesta Coated
12-01-2022, 04:34 AM | #386 | ||
Rep 255
12-10-2022, 02:53 PM | #387 | |
Rep 112
01-18-2023, 12:46 AM | #388 | |
Rep 1
02-03-2023, 03:01 AM | #389 | |
Rep 2
They said it is risky to demount/mount center console completely without being 100% sure cause of problem but i insisted on it. I still have rattles/noises around car but can't fix, i am not sure where they came and dealer says "they are normal". I think that's poor build quality, car shouldn't broke down at 30000km like that and i have poor braking pads too (i will change rear brake pads for the third time at 35000km) |
02-18-2023, 04:27 PM | #390 |
Rep 4
Can you show with a picture where you put that felt tape?
02-18-2023, 04:32 PM | #391 | |
Rep 4
Could you share? Sound is driving me crazy |
06-15-2023, 12:35 PM | #392 |
Rep 2
I dealt with this one. If you pull down on the corner of the headliner where the clicking is coming from, the clip will pop free. I used some trim removal tools to make some space and used felt tape to pad the gap. It fixed it. There's a clip that doesn't stay put, so it taps on the whole making the clicking sound.
06-26-2023, 12:39 PM | #393 | |
Rep 1
09-26-2023, 11:41 AM | #394 | |
Rep 40
11-09-2023, 09:34 PM | #395 |
Rep 15
I've had this rattle for over a year now. The dealer looked at it several times but can't figure out the source.
It happens from 1500-2500rpm and only while moving, noticeable after each upshift. https://gemoo.com/tools/upload-video...44666699272192 |
11-15-2023, 11:23 PM | #396 |
Rep 16
Can someone help me identify this rattle? I can't tell if it's coming from behind the steering wheel, or the side speakers? If you happen to know a fix please let me know, it's driving me insane.
