02-23-2022, 12:26 PM | #89 | |
Rainbow Racer
1008
Rep 2,539
If you drive 50/50, expect closer to EPA range. But if you drive 70/30 (city/highway), expect higher than EPA range, and vice versa.
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
02-23-2022, 01:09 PM | #90 | |
Rep 5,089
Instead of 1000 miles, how about 500 miles? @5miles/kWh that is 100kWh battery, @10 miles/kWh it drops to 50kWh, at 2x(and beyond) density. Porsche currently can support 350kW charging, so 20-80% of 50kWh battery takes 5 mins, it is just that current home charging cannot max out that charging capability. Although the curb weight(and heavy battery) appears to not affect miles/kWh much at highway speed, my feel is that pulling heavy loads on typical mixed driving still consume juice, so maybe 2x density tech can provide a good bump on miles/kWh. Also even though 20-80% on 240V 30A@7.2kWh in 5 mins. looks insurmountable, I still think it is good parameter to entice innovations in many fronts. |
02-23-2022, 01:13 PM | #91 |
Rep 5,089
02-23-2022, 01:21 PM | #92 |
I know a thing or 2 about a thing or 2...
3101
Rep 3,470
Drives: E36 M3 Coupe, e39 M5, i3s
I'm getting my house upgraded to 200A next week with a 50A circuit for my L2 charger. It's not a cheap job, but the house needs it anyway.
2019 Imperial Blue Metallic i3s BEV
2003 Le Mans Blue e39 M5 Dinan S1 1997 Alpine White e36 M3 (the old gal) 2013 Mineral White e92 M3 (sold ) 2014 Carbon Black 650i M-sport (sold) |
bavarianride1509.00 |
02-23-2022, 03:25 PM | #93 | |
Rainbow Racer
1008
Rep 2,539
Regardless, peak charge rates are just that, and it's sustained to only a portion throughout the entire charge curve in usually a waning manner. For that to be sustained for a longer rate, the battery would have to be larger capacity where "0-100%" is only 50-60% of the battery's full capacity - - -> more space for electrons to flow into the battery and move around efficiently since the closer you are to true battery capacity, the slower the charge rate. If 200kWh battery on a solid state would equal the weight/size of a 100kWh lithium-ion version (doubtful since it wouldn't be a 2:1), and having 100kWh as usable, I can see it being closer to 10 mins. But that doesn't resolve the weight issue but in practice would reduce charge times through shear total capacity alone to sustain the 350kw rate for a longer period.
-Loe P.-
02-23-2022, 03:58 PM | #94 | |
Rep 5,089
Another point made previously by another poster is exotic light weight like CFRP is costly. My thinking is that, similar to battery cost driven down with scale, cost reduction can also happen for these light weight alternatives with enough scale, and these alternatives can drop curb weight, which may help miles/kWh, which can in turn drop battery size and reduce charge time, and .... |
02-23-2022, 04:36 PM | #95 | |
Rep 8,017
02-23-2022, 04:44 PM | #96 |
Rep 8,017
It’s funny but currently they seem to be putting all the batteries in the floor but I read somewhere that both Porsche and Lotus aren’t going to do this with their next EV sports car, instead placing some if not most in the space usually occupied by the engine to help them create the handling characteristics of their petrol engines counterparts.
I wonder why BMW didn’t look at this idea for the i4, it would have helped rear legroom for sure. I agree with what’s been said above battery tech needs to change, weight has to come down by a fair old margin be it through increase capacity of power thus reducing the number needed or increasing the charging capabilities so you don’t need the range because 150 miles can be added in the same time it takes to fill a tank with fuel, ideally this would be the one I would favour. Last edited by footie; 02-23-2022 at 04:49 PM.. |
02-23-2022, 05:42 PM | #97 | |
Rep 5,089
E.g. current BEV owners are conditioned to hide charging time, that does not work for many(who then don't choose current gen BEV). Your point of 150 miles in 2-3 minutes also makes sense, e.g. if tech can eventually hit 10 miles/kWh, then 150 miles takes 15kWh, which takes 2.57 minutes to charge at full 350kW rate. For 10 miles/kWh, 300 miles only needs 30kWh, which is huge savings of resources of current tech. This comes full cycle when one realizes that a large part of BEV industry is powered by fossil fuel. |
02-23-2022, 05:52 PM | #98 | |
Rep 1,964
High speed is a range killer. Go faster than about 70mph and range drops off on most EV. There is a range difference if.you go 40mph and 70mph.
Arctic Metallic\CF Splitters,Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1\M-Performance Brakes\Cobb Tuned\xHP Flash ->
02-23-2022, 06:08 PM | #99 | |
Rainbow Racer
1008
Rep 2,539
I anticipate my range will be above 350 miles , it's mostly flat here, normally above 75F throughout the year, and 99% of my driving is when it's dry outside. |
02-23-2022, 07:49 PM | #100 | |
Rep 5,089
02-23-2022, 08:23 PM | #101 |
Rainbow Racer
1008
Rep 2,539
02-23-2022, 09:43 PM | #102 |
Rep 5,089
02-23-2022, 09:55 PM | #103 | |
Rep 1,236
02-24-2022, 08:13 AM | #104 | |
Rainbow Racer
1008
Rep 2,539
The only time I travel outside of town is for work (once a qtr) or to FTL/Miami area, but there are many charging stations along the route either through the free EA network, or pay to use EVgo, Chargepoint, or free city municipalities that aren't listed in random searches. I actually suspect this car will be quicker 0-60, 1/4 mile, and trap higher than my CS, albeit by a small margin. But it doesn't matter too much for me, I rarely use the CS for its intended purpose. ...plus I don't want to be tied down with oil prices anymore. I need to cut that cord.
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 Last edited by spool twice; 02-24-2022 at 08:19 AM.. |
02-24-2022, 12:08 PM | #105 | |
Rep 5,089
02-24-2022, 12:47 PM | #106 |
Rainbow Racer
1008
Rep 2,539
the fluxuation per kWh isn't enough to swing beyond $1.00 vs $10 for gas for one refill, so I am fine with that trade-off, especially since it won't cost me a dime on the EA network for two years if I chose to use them in my area.
-Loe P.-
02-24-2022, 01:07 PM | #107 | |
Rep 5,089
These days Model 3 SR is same price as i4 40 with similar waits, so there is no point not to get i4 40 if needed. Home charging with PG&E without solar is not cheap, around $0.35 to $0.40 per kWh, so around $0.09 to $0.10 per mile. In contrast, $4.45 AKI 91 gets around 32-35 miles with my mixed driving(or 40+ mpg on freeway), so around $0.13 per mile for now. |
02-24-2022, 03:20 PM | #108 |
Rep 4,210
I have an all electric house with 225 service and all the electrician could generate for me was a 20 amp dedicated circuit. Before you make the investment, make sure that 200 will be adequate.
02-24-2022, 03:31 PM | #109 |
Rep 5,089
Yes that is a common issue and frustration among friends who consider/live with BEVs. My strategy is to not bother with home upgrades and take whatever is available, and then complement with work/public charge ports as needed.
02-24-2022, 04:20 PM | #110 |
3101
Rep 3,470
Thanks, Steve. Yeah, when I talked to my electrician who is pretty seasoned, he said it would be enough. I don't have a huge house. Mid-size cape built in the 50's.
