03-13-2024, 01:13 PM | #1 |
Rep 185
I had a few questions on BMW lease return process that I’m sure many have gone through in the past.
-My car came with run flats originally, I changed them to different tires question is do I have to install the original tires the car came with prior to returning? -I have my car lowered on dinan springs, I really don’t want to have to put the stock ones back on but must I? Will BMW check? -I had the resonator removed at muffler shop, must I re-install the original? -edit: forgot to mention I am over miles by about 7,000 miles I’m hoping I can get away with the springs on the car and the resonator delete and just go find the original run flat tires the car came with on here and call it a day, what do you guys think? Lastly I was thinking I’ll wait towards lease end and just get another BMW lease but i assume the dealer will do a lease return on the old one and leave me with a hefty bill at the end regardless. Trading in my car doesn’t make sense as I’m roughly $7,500 negative on it if I were to do so to avoid all the over miles, tires, etc Thank you |
03-13-2024, 02:02 PM | #2 |
Rep 1,688
You need to put the car back to stock. If your just giving the car back at the end of the lease and are getting a new car they generally waive the disposition fee, that would be the only charge unless the car has damage.
If you are getting another car, and have a good sales guy they won't mind a bit of wear and tear above what BMW are normally comfortable with. My last lease had a big hole in the front bumper where someone drove into it in a car park but they covered it for me. I would of been in a couple of thousand dollars on return if they hadn't. The dealer either take the car in (aka buy it from BMW FS) and sell it, or BMW FS retains ownership and they send it to auction. |
03-13-2024, 04:00 PM | #3 | |
Rep 1,185
Drives: 2023 M550i CBM/Ivory
i believe the inspection is done usually 3rd party and their goal is to find fees... |
03-13-2024, 11:23 PM | #4 | |
Rep 185
03-13-2024, 11:25 PM | #5 |
Rep 185
03-13-2024, 11:28 PM | #6 |
Rep 185
Any in sight on over miles? Another reason why I don’t want to do a lease return is I’m over miles by about 7k I know if I get another BMW lease they waive the disposition fee but I’m still worried about it being lowered…tires I’ll find a used set or see if I can find same size run flats with the star on the tire wall since I was told it has to be BMW approved tires from someone…
03-14-2024, 06:35 AM | #7 | |
Rep 1,185
I believe it might be possible to purchase additional miles during your lease, which potentially might be cheaper than the overage miles. Try giving BMWFS a call. |
03-14-2024, 08:57 AM | #9 | |
Rep 1,688
03-14-2024, 11:48 AM | #11 | |
Rep 185
03-14-2024, 11:52 AM | #12 | ||
Rep 185
I suppose I can see what the residual is to purchase it. If I go about purchasing the car I’m paying tax, title and fees on it. Then what’s the car going to be worth on a trade in? I’m still going to be negative on it making it difficult to get a new car and rolling negative into it, not to mention I’m Buying a car with 44k miles on it and would need to get an extended warranty if I’m planning on keeping it for a few more years. |
03-14-2024, 11:58 AM | #13 | |
Rep 1,688
03-14-2024, 12:21 PM | #14 |
936
Rep 4,327
Drives: M340
These are all the questions you should of asked BEFORE leasing a car.
BMW gave you a brand new car with a certain contract terms and conditions and that is how they expect their car back. You best option is to buy the car out as stated by others or pay all the fees they are going to charge you. Your car's residual should be pretty attractive if you leased it 3 years ago. PS: There is no way you are getting away with resonator delete (This is a big no no on a leased car) or the springs or the tires for that matter.
03-14-2024, 01:16 PM | #15 | |
Rep 185
If I lease again I’m going with 15k miles per year.. |
03-14-2024, 01:17 PM | #16 | |
Rep 185
03-14-2024, 01:39 PM | #18 | |
936
Rep 4,327
Drives: M340
Having said that, I've been through cases where they just walked around the car and took it in or there were times, I had to schedule an appointment for a lease return inspection where there was a full detailed inspection. One bet you might want to take is to schedule a return inspection and see what the report says but you will still have to pay for the miles. Your absolute best bet it to buy the car.
03-14-2024, 01:55 PM | #19 |
Rep 94
They're charging you almost 43 cents a mile? That sounds excessive. You can log in to your My BMW and check the cost of overage miles, as well as the cost of buying more miles. You can even purchase the miles right there.
A buddy of mine recently returned a Lexus and leased another car with the same dealership. They forced him to return the car to stock, including his lowering springs, but waived all other fees including his over mileage. |
03-14-2024, 02:39 PM | #21 | |
Rep 185
I reached out to a dealer to get a new 330i and they were rolling my remaining payments into the new lease and said I’m responsible for paying the over miles separately. |
03-14-2024, 02:42 PM | #22 | |
Rep 185
In the past the BMW genius did the lease return checklist process not sure if that’s still the case. |
