09-08-2023, 12:00 PM | #1 |
Rep 185
G20 M340 Steering Creak - Turning right towards lock
Hi all - I have 14k miles on a 2020 M340 xDrive, still in warranty (just) but this issue has been happening for a few thousand of miles. Been to a dealer multiple times for the issue under warranty. When I turn the wheel to the right, nearing lock, I hear a creaking (like walking on a wooden floor) for half a second. It's not that loud, but it's there. I generally just hear it when reversing out of a parking spot in one direction and cutting hard. It doesn’t happen when I turn to the left, ever. Dealer has replaced both front strut top mounts, both front tie rods, and both front thrust arms. It's been a parts cannon, and the noise is still there. There's zero other symptoms (no vibrations, rattling, nothing). They keep giving it back saying it's fixed, and I keep bringing it back, proving it's not.
Might try another dealer before my warranty expires, but I'm at the point where do I just live with it since it's so minor, or do I keep on them, risking them screwing up things in the process; when they replaced the strut top mounts, I got a huge clanging noise under heavy acceleration, which they ended up fixing. I've searched high and low, and while there are plenty of threads on front end noises, nobody's seems to be like mine, which is limited in behavior, and most other issues seem to be noticed going over bumps, turning in any direction, etc. Any feedback is much appreciated. Thank you! |
09-08-2023, 11:39 PM | #3 |
Rep 185
09-10-2023, 10:28 PM | #4 |
Rep 410
So I have a 2020 and am experiencing something similar. When I turn to the right, say going around a curve on the road, I hear a clicking noise coming from the right side. Almost like something is loose and hitting something. When I straighten the wheel, the noise goes away.
09-13-2023, 02:23 PM | #5 |
Rep 185
It also does not make the noise when I have the car in the air. Not sure if that rules out anything with the steering rack/gear, but I would think so.
09-18-2023, 11:14 AM | #6 |
Rep 31
I have the same problem in my 330i Touring, 2020 build.
Creaking noise when turning wheels to the right, before steering lock. Sound appears to come more from the left side. It does not do the same noise when turning wheel to the left. Dealer suspects steering rack. First time they (supposedly) only lubricated something. Next day it was the same. Have an appointment for next Monday. Lets see. Still under warranty. Thankfully I extended warranty... |
09-18-2023, 11:41 AM | #7 | |
Rep 185
09-19-2023, 04:00 AM | #8 | |
Rep 31
I personally suspect from the start something related to tie rods or control arms. It is the typical noise of a ball joint going bad. But they pointed out to the steering rack. From what I understood there is a service bulletin for this. BMW recommends first to lubricate the steering rack and then to replace steering rack if problem persists. I understand your concern but if BMW recommends to change steering rack I want it to be done still under warranty. Tie rods and control arms are way cheaper and need to be replaced anyway in a number of years. Cheers, |
09-29-2023, 09:47 AM | #9 |
Rep 185
pmgoliv were you able to take your car in and get a diagnosis? Also, do you have the TSB you were referencing for the steering rack? I searched and couldn't find one for any G20, except for the one regarding the tie rods.
10-01-2023, 09:47 AM | #11 |
Rep 185
Thanks, glad yours is fixed. I saw you post a video on your issue, and yours is far more extreme then mine, and looked to be turning the wheel in general. Saw a thread on another site and his video was identical to my issue: thrust arm fixed it, though I've done that. Maybe it's the wishbones then (only ball joint component I haven't replaced). Anyway, if it was the steering rack, would expect the same noise if my car was on a lift, but it doesn't replicate.
10-10-2023, 06:08 PM | #12 |
Rep 106
I got the same issue on my 2023 m340 and dealer said there is a service bulletin for this issue. They are going go replace both tie rods next week.
10-10-2023, 06:24 PM | #13 |
Rep 185
My issue is very specific and is only turning to lock in one direction. That TSB is general noises over road bumps, etc. Anyway, they tried tie rods and it didn’t fix my issue. Hope it works out for you though.
