2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK M340i 2025 what engine ? Is it TU2 ?
      02-09-2025, 03:37 AM   #1
walker1971
walker1971's Avatar
66
Drives: G20 330D
Hi
I have a 2025 M340i and I was just wondering what engine it is in the uk as it seems in America they get the latest TU2 engine, how do you know or tell ?
      02-09-2025, 07:11 AM   #2
sync24
sync24's Avatar
34
Drives: M340i LCI2
Originally Posted by walker1971 View Post
Hi
From my understanding, M340's, as of July 2024 (IE LCI2), have B58TU2 engines.
There are a few videos on you tube explaining the difference. A quick look under the engine cover should confirm.
      02-10-2025, 01:36 AM   #3
walker1971
walker1971's Avatar
66
Drives: G20 330D
I think I need to take off the engine cover and have a look, most places I have read seem to say that the uk did not get the TU2 engine, no idea why they would do that tbh.
      02-10-2025, 07:16 AM   #4
sjb993
sjb993's Avatar
227
Drives: G20 M340i XDrive MHT
Seems like MHT cars also have the in-line starter/generator.
      02-11-2025, 05:50 PM   #5
blau3er
Drives: F31 30d
Yes, LCI 2 cars get the TU2 engine.
      02-12-2025, 02:35 PM   #6
walker1971
walker1971's Avatar
66
Drives: G20 330D
Is that 100% in the uk also ?
      02-12-2025, 05:32 PM   #7
blau3er
Drives: F31 30d
Why wouldn't it include the UK?
Post a picture of your plastic engine cover, or furthermore, take your engine cover off, and look at the markings embossed into the plastic, it will say TU2.
      02-13-2025, 08:04 AM   #8
walker1971
walker1971's Avatar
66
Drives: G20 330D
The reason that i thought maybe they are not type TU2 engine is i had read somewhere that the uk were not getting the TU2 engine which i thought was odd, i will take a look under the hood properly
      02-14-2025, 08:02 AM   #9
sync24
sync24's Avatar
34
Drives: M340i LCI2
FYI my late 2024 LCI2 (October build) M340i has the TU1 engine.
The presence of the alternator and the lack of fuel rail (for direct port injection) confirms this.
Maybe they will switch to TU2 for the UK when TU1 engines "run out" 🤷
      02-14-2025, 09:12 AM   #10
Elderado82
Elderado82's Avatar
196
Drives: 2025 M340i XDrive
Hi
To identify whether you have the TU2 or TU1, simply pop the cover off. If it's the TU2, you'll notice a shiny aluminum port injection intake manifold. If it's the TU1, it'll be a black plastic intake manifold. I hope this helps you determine which version you have!
      02-15-2025, 03:35 PM   #11
blau3er
Drives: F31 30d
No need to even go that far, the TU2 has a different plastic engine cover!
Also, some TU2’s (the first ones) got the poverty spec non-M engine cover, whereas the newer ones now feature a much nicer M plastic engine cover.
      02-16-2025, 10:18 AM   #12
sync24
sync24's Avatar
34
Drives: M340i LCI2
Late 2024 UK LCI2 M340i with TU1 engine.
This is my engine cover:
      02-16-2025, 10:46 AM   #13
blau3er
Drives: F31 30d
Originally Posted by sync24 View Post
Late 2024 LCI2 M340i with TU1 engine type engine cover:
Well, that’s a first and I stand corrected.
I’ve always thought that the TU1 engine cover looks terrible with its older (F generation) M Perf logo / typeface.
In terms of the TU2 engine cover, all TU2’s I’ve seen either have the non-M variant, which was on the first batches of cars, as pictured here;
Or, latterly with the M version, which looks like this;
Last edited by blau3er; 02-18-2025 at 09:52 AM.. Reason: to correct context, as reply was based on a now edited post
      02-16-2025, 12:48 PM   #14
walker1971
walker1971's Avatar
66
Drives: G20 330D
So bottom line is we do not get the TU2 engine in the uk :-( so the info i had read a while back that said the uk were not getting the TU2 engine is in fact correct.
      02-17-2025, 02:21 AM   #15
sync24
sync24's Avatar
34
Drives: M340i LCI2
It's odd isn't it? Personally - I am not that bothered, I ❤️ my LCI2 340i 🤓
As I said before, perhaps they will swap to TU2 engines when TU1 engines cease being made. I think you said you have a '25 340? Be good for you to check yours so we can clearly differentiate the year models/engine variants 👍🏻 in the UK
      02-17-2025, 02:33 AM   #16
walker1971
walker1971's Avatar
66
Drives: G20 330D
Sorry when I say 2025 model I picked mine up middle of October 2024so it’s a 74 plate, they just call the LCI2 MY2025 model
      02-17-2025, 10:40 AM   #17
sync24
sync24's Avatar
34
Drives: M340i LCI2
I don't have the engine bay bracing either on my 340, is yours a 4 series? This picture is not my engine bay, mine is shown higher up this thread
      02-17-2025, 10:41 AM   #18
sync24
sync24's Avatar
34
Drives: M340i LCI2
Same as mine then mate! 🔥
      02-17-2025, 11:33 AM   #19
blau3er
Drives: F31 30d
No, mines a G21, the last of the LCI1's (May 24 build). Those were just stock images I found so show the differences.
Looks like youve edited your post from earlier, which originally led me to believe you were suggesting that yours was a LCI2 car, with a TU2, but with a TU1 engine cover.
Obviously thats not the case, so my previous posts should be disregarded! Very odd that there seem to be UK cars which are LCI2's but still with the TU1.
Everything else I have read online seemed to point to the opposite, in so much as LCI2 cars were getting the TU2.
If this is correct, it makes the price increases and lower (standard) specs of the LCI2's seem even more ridiculous now, given the upgrades essentially now seem to consist only of ID8.5, a steering wheel change and new HVAC controls!
      02-17-2025, 03:19 PM   #20
walker1971
walker1971's Avatar
66
Drives: G20 330D
I still need to check under the bonnet just not had time will look tomorrow but I am sure mine has that M Performance cover over the engine so probably is a TU1 engine.
      02-17-2025, 04:00 PM   #21
Longp2
Drives: BMW M340i
My M340i touring was delivered 2 weeks ago and has the m performance cover so assume TU1 engines, this is our first BMW and I am very impressed with it so far (only 200 miles on the clock so far) and tbh I’d need to do some more research to see if I should feel short changed regarding the engine.
      02-20-2025, 03:05 AM   #22
ramparts
ramparts's Avatar
1186
Drives: M40i
If you read the “future model information” thread, it states the the TU2 is coming to test of the world later this year.
Right now it’s US only.
