04-26-2024, 09:00 PM | #265 | |
Rep 7,007
Drives: 2022 DG/BLk xDrive M4C Wk 34
I posted all of the part numbers in the first post. Yours should be in there.
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou |
04-26-2024, 09:57 PM | #266 |
Rep 324
Drives: '24 M4 Competition xDrive
Limegrntaln13574.00 thatguyM4209.50 |
04-26-2024, 11:22 PM | #267 |
Rep 7,007
I don’t wanna crash too hard. He’s a busy man.
YT: G Dubyou |
thatguyM4209.50 |
04-28-2024, 04:31 PM | #268 |
Rep 186
Get the harness on the site so I can schedule I'm setting appointments and getting booked out ..... and we're about to release M Mode this week .... on guys with ID 7 ....ID 8 is plug and play ID 7 will need to jump.a.wire ...
Limegrntaln13574.00 |
04-28-2024, 10:52 PM | #269 |
Rep 412
G83 needs a jump wire?
04-29-2024, 06:18 AM | #270 |
Rep 551
Drives: 2022 G83 M4
G83 just needs coding if you want to have the Euro turn signals otherwise it's just plug n play and simple coding to eliminate the flicker. No jump wire needed. The convertibles are already wired up for separate turn and brake signals.
2022 G83 M4 Convertible Isle of Man Green on Tartufo Instagram:kermit_g83
2020 GLE 450 Emerald Green on Macchiato Beige - wife and baby mobile 2016 M3 TB on SS - gone but not forgotten |
04-29-2024, 08:27 AM | #271 |
Rep 2,687
Drives: 2024 M4 Convertible
So where's the definitive resource of ordering these at this point?
04-29-2024, 09:10 AM | #272 |
Rep 186
04-29-2024, 03:18 PM | #273 |
Rep 2,380
If you have a euro spec car already (UK RHD drive) , MY23 G82 with ID7 and you get the LCI tails, does it still need a wire and coding? TIA.
04-29-2024, 04:53 PM | #274 |
Rep 7,007
Wiring, it shouldn’t because that’s the standard setup, there. Coding it probably does. It was skeptical, but it takes :30 seconds, a cell phone and an enet cable and Bimmer utility.
YT: G Dubyou |
as7920601.50 |
04-29-2024, 04:53 PM | #275 |
Rep 551
Drives: 2022 G83 M4
Only will need coding to eliminate the startup flicker. Otherwise plug-n-play
04-29-2024, 08:11 PM | #276 |
Rep 412
Thanks. Wonder if the US spec LCI taillights will need coding on a G83?
04-29-2024, 08:16 PM | #277 |
Rep 7,007
Yes, but just coding. Very easy to do, yourself. I’m going to update the original post, once I gather all of the info from the posts throughout the entire thread. But, right now, you need to enable one switch that’s disabled in the coding. Check post 256 and a few before and after.
YT: G Dubyou |
04-29-2024, 08:18 PM | #278 |
Rep 412
Thanks
04-29-2024, 08:19 PM | #279 |
Rep 7,007
You’re welcome. Part numbers to the lights you need, on the OP.
YT: G Dubyou |
04-30-2024, 09:35 AM | #280 | ||
Rep 2,380
Have someone able to do the coding for me, if above true then I may be looking to get a set pretty quickly! |
04-30-2024, 09:38 AM | #281 | |
Rep 2,380
04-30-2024, 10:21 AM | #282 | |
Rep 551
Drives: 2022 G83 M4
You only need to run wiring and do some more advanced coding if you wish to separate the turn and brake signals or if you get the euro set with amber signals like I have and separate the turn and brake. G83's only require coding irregardless of which lights you purchase as they already have the respective wiring.
04-30-2024, 02:10 PM | #283 |
Rep 186
05-01-2024, 01:09 PM | #284 |
Rep 39
I tried ordering and got my order canceled because 2 of the parts had no current fulfillment time. Mine was from bmwpartsdirect.com
Where to order? |
05-01-2024, 01:32 PM | #285 | |
Rep 2,687
We're all in waiting mode now. |
Jrsred1021.00 Limegrntaln13574.00 |
