11-02-2021, 11:49 PM | #727 | |
Rep 1,795
JasonDot585.00 |
11-03-2021, 03:44 AM | #728 | ||
Rep 379
BMWphile
2020 G20 330iM Sport (Tanzanite Blue), Visibility, Comfort, HK 2012 F30 328i Sportline (Mineral Grey) |
11-03-2021, 06:01 AM | #729 | |||
Big Beaver Smile
2101
Rep 3,791
With them all you can open the car door, get out, open the garage door and get back in and they will all still be running. They don't go into idle state (off) until I hit the start/stop button (standby) and open the door. One thing though, I am able to and always turn off ASS automatically when I start my trip. I know some don't have the disable button. Not sure if that makes a difference.
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch |
11-03-2021, 08:04 AM | #730 | |
Rep 4,724
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
11-03-2021, 09:02 AM | #731 |
Rep 1,795
Couple of weeks ago I saw activation point as an option while playing with the drive recorder. Could be different for forward camera. I haven't yet had a use for the feature but I'll check it out later today
11-03-2021, 09:21 AM | #732 | |
Rep 1,795
Exits are a function of navigation so yes you should still see an exit warning for lane change on your nav just like you would if you were driving yourself. The feature does not require you to be at a particular lane for it to work. |
11-03-2021, 09:36 AM | #733 | |
Rep 2,983
Not having the disable button doesn't make a difference as I don't have it, but I also engage Sport Individual mode every time I start up the car which for all intents and purposes achieves the same thing. |
wrickem2101.00 |
11-03-2021, 11:08 AM | #734 | ||||
Rep 1,086
11-03-2021, 11:31 AM | #735 | |
Rep 1,795
Edit: I indeed have that option checked; I tested and my engine stays running even when I open the door and step out. What exactly is the point? The option is a bit misleading and could have been worded differently |
11-03-2021, 11:46 AM | #736 | |
Rep 5,094
In other words, when the engine is off, but ignition is on(e.g. radio is still on), selecting that option allows opening door to turn off ignition and shutoff electronics. |
11-03-2021, 11:57 AM | #737 | ||
Rep 1,795
TruthOne1081.00 |
11-03-2021, 12:13 PM | #738 | |
Rep 5,094
However, when I stop and exit without pressing start-stop, the engine does not turn off. At times I do that to drop off something quick, and the car alerts me(horn goes on) when I lock the car. When I press start/stop to turn off engine, the radio still plays. But when I open the door, the radio and the rest of electronics turn off. |
wrickem2101.00 |
11-03-2021, 12:23 PM | #739 | ||
Rep 1,795
Edit: if I park and then manually unlock the door; once I open the door engine does not shut off. So yeah it has something to do with the door being locked at least on the M340i |
11-03-2021, 01:26 PM | #740 |
Rep 2,983
Sort of confusing to keep up with everyone's experiences here but all I know is that by checking the "Turn off vehicle after opening door" box it does exactly what I wanted. When I park the car and shut off the engine and open the door, the electronics all shut off, including the audio system. Prior to that my music continued to play even after shutting off the engine and opening the door. It's all good now.
It seems bavarianride has the same settings as I do. I'm not certain how anyone being parked with the engine running but when opening the door it cuts off power to the engine. That would piss me off. |
11-03-2021, 01:51 PM | #741 | |
Rep 5,094
Mine is 330i with ASS default enabled when engine is turned on, but I usually press ASS button to disable. So my engine keeps running when parked, and iDrive alerts me(with car horn) of running engine if I exit(and lock door). |
11-03-2021, 01:55 PM | #742 |
Rep 5,094
M340i mild hybrid's ASS should be always on, so if not already coded default to off, I think the engine may shutoff when parked(not 100% sure), regardless of door open or not.
11-03-2021, 02:13 PM | #743 | |
Rep 1,795
11-03-2021, 02:17 PM | #744 | |
Rep 5,094
Similarly, on my 330i, pressing ASS button is the driver input to bypass ASS. |
11-03-2021, 02:19 PM | #745 | ||
Rep 1,795
11-03-2021, 03:56 PM | #746 | |
Rep 2,983
Oh and when I put it in Park, I'm not manually unlocking the door per se (aka not pressing unlock button), but simply opening the door. |
11-03-2021, 04:19 PM | #747 | |
Rep 5,094
So it is puzzling why other M340i(may be 330i too?) behaves differently. |
11-03-2021, 04:25 PM | #748 | |
Rep 2,983
By the way, just to reiterate, the electrical system (incl. audio) turns off when I open the door only AFTER I shut the engine off. |
bavarianride1512.00 |
