05-29-2023, 04:30 AM | #24 |
Rep 54
This update os doing my head in. I'm on second attempt at it. First update loaded to car and then refused to install - car eventually forgot. I then did a second time and in same position. Car's battery at 12.2v (I charged over night with CTEK charger on two occasions to see if it made a difference).
This is the first time Ive had an issue - previous ones have worked fine. No idea what the problem is tbh. |
05-29-2023, 05:49 AM | #25 | |
Rep 198
The only difference for me is that this is the first time I get a software update after doing some coding, so not sure if that is the problem. Hopefully this second time it triggers at some point. |
05-29-2023, 01:01 PM | #26 | |
Rep 117
05-30-2023, 12:12 PM | #27 |
Rep 138
still not updated, so cars back on the charger after being sat in it with ista seeing why it wont start the upgrade, it vaugely mentions the car preconditions and customer preconditions not met but doesnt really delve much further into it (altho my battery shows 67% so hoping its that)
one thing it did show was the preconditions for the customer Gradient below 12% Selector lever position P engaged Trailer disconnected No device connected to the diagnostic socket parking assistant inactive neutral detected No CD/DVD/BLU-RAY inserted in front drive ive switched off park assist in the hope that will kick it in now (clutching at straws) |
05-30-2023, 02:55 PM | #29 |
Rep 352
Mine hasnt let me upgrade either. Not sure I want to considering I hear it muffles the cars exhaust. I dont think an upgrade has been downloaded since 2020 on my car.
05-30-2023, 03:05 PM | #30 |
Rep 138
06-01-2023, 02:39 AM | #32 | |
Rep 66
Does you Stop / Start work if not that is a signal the battery is not sufficiently charged and therefore the update will not start. Try a good run on local roads with braking and coasting this should charge up the battery and once the stop / start is working hopefully the update will commence. |
06-01-2023, 03:44 AM | #33 |
Rep 138
you can force the car to forget the update pretty easy, in the data privacy bit turn off remote software upgrade, then back on, it will say its unavailable but after a little while itll come back and allow you to search again
06-01-2023, 06:38 AM | #34 | |
Rep 138
06-02-2023, 03:33 PM | #35 |
Rep 2,250
23-03 contains absolutely nothing new for idrive 7 cars ( check the imprint , you might be surprised it’s actually still 11/22 ! ), but does bring bug fixes and support for newer versions of certain hardware units
