12-08-2020, 08:48 AM | #1 |
Rep 156
How to: Adding Luggage Hooks in Boot / Trunk
Thought this would be useful for those without extended storage and the grocery bag hooks -
Part number:51477258562. Thankfully the bracket used already has the hole in place, so its a simple DIY job of drilling a small hole in the boot carpet. Step by step: For the N/S hook 1) Remove the two clips shown below - 2) Then remove the clip which holds the carpet bracket to the top of the boot. After this you can pull back the carpet around the boot hinge rubber weather seals - 3) This reveals the otherside of the bracket where you can easily see the hole designed for use with the luggage hook - 4) For simplicity, I then used a self tapping screw to mark up where I need to drill into the carpet - 5) Then drill through the carpet to make the hole large enough to accomodate the boot hook - 6) Push the hook in, then putting it back together is simply the reverse of the above - I'm going to investigate the offside bracket as well and I expect it will be possible to install a second hook. Last edited by Amos91; 12-08-2020 at 02:04 PM.. |
12-08-2020, 10:14 AM | #2 | |
Grumpy Old Git
443
Rep 923
Looking good.... There was an alternative solution thread a while ago which I followed. This was using VW/Audi type hooks available from eBay. https://g20.bimmerpost.com/forums/sh...ighlight=Hooks
Retired:
12-08-2020, 12:18 PM | #4 |
1942
Rep 3,521
Great write up!
Did they remove the hooks in the 2021 models? Or do you guys in the UK not get them? My 2020 G20 in America has it. Which is why I'm asking.
Fpangalos46.00 |
12-08-2020, 01:31 PM | #5 |
Rep 256
My 330e has the extended storage pack but no hooks I assume because it’s a hybrid the boot is very shallow. I’m in the UK and the demo 320D I had for a week had the hooks.
VipinLJ1941.50 |
12-14-2020, 12:48 PM | #8 |
Rep 1,479
Drives: 2020 M340Xi (G20)
Amos91 ,
Great write up! Have you had a chance to check out the other side -- driver's side for you, passenger here in US? I have one hook, but have had several occasions needed a second Thanks
Al
12-22-2020, 10:56 AM | #10 | |
Rep 33
Drives: G02 3.0d Xdrive
12-29-2020, 01:01 PM | #11 |
Rep 26
Thanks for this, did it on mine yesterday. I had the hooks but had put them each side replacing the clips right by the boot lid. This is much better, I did one side as per the “how to” them measured it and did the other side insitue.
