01-15-2021, 01:36 AM | #1 |
Rep 42
Find NCD files for countries where TLA is compatible.
I wanna test my G20 in South Korea.
I success upgraded 20-11-545 myself. and I coded 21my new 5AU (TLA, Distance...). TLA is work but click SET button from aSLA Automatic mode. Manual mode is same. I guess exist compatible or not compatible NCD are diffrent, I wanna find more code except IFR spread sheet. if 21my is default compatible car. (ex Germany or UK) Anyone all NCD File please.
2014 ~ 2017 Chevrolet Cruze J300 1.8
2017 ~ 2019 Mercedes Benz W205 C200 2019 ~ 2020 KIA Motors YG K7 Premier 3.0 2020 ~ BMW G20 320i |
01-15-2021, 02:23 AM | #2 |
Rep 1,587
The auto accept TLA is determined by aUCC_Land*. If you set that to FFFFFFFF and it doesn't work then it's not supported for the region the car is physically located in, and this is set in the i-step version software.
You can collect as many NCD files as you like, but they will all be configured the same way for the only code that really matters, which is the land mask. You could move to another country, like the UK or Germany, and take the car with you. That should work without any further coding. Maybe a bit drastic. I challenge you to prove me wrong |
01-31-2021, 07:02 AM | #3 | |
Rep 194
Is changing the setting of aUCC_Land* to FFFFFFFF + experimenting in the region the only way to see if it actually works? I am exporting a F96 from Canada to the Middle East with 11/2020.045 iStep version and would be keen to see if, after coding TLA (and other features), they'd work here. |
