View Poll Results: does anyone use the BMW fuel additive that comes in a little blue 3-ounce bottle? | |||
YES | 1 | 3.33% | |
NO | 29 | 96.67% | |
Voters: 30. You may not vote on this poll |
01-26-2024, 12:38 PM | #23 | |||
Rep 6,297
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [8.58]
2020 BMW M340i xDrive [9.00] 2018 BMW 340i M Sport [7.38] 2006 BMW 330i Sport [5.83] 2004 BMW 330i ZHP [7.13] 2000 BMW 328i [6.17] |
DrFerry6730.00 |
01-26-2024, 03:03 PM | #24 | |
world's slowest BMW driver
1498
Rep 1,003
Drives: U11, G60, W211, AZ20
I don't know if launch control counts as Italian tune-up, but I do it once in a while. earlier this week, I did 700 miles in 2 days... 70mph to 79mph mostly. hopefully that got rid of some gunk from the engine? Last edited by SpaceSilver.X1; 01-26-2024 at 05:14 PM.. |
eugenebmw1524.00 |
01-26-2024, 07:29 PM | #25 |
Field Marshal
6730
Rep 1,829
Drives: '08 E92 M3
I'll just leave this here. See .pdf file attached.
. https://www.verifythis.com/article/n...8-6782d6065455 . . All regular grade and premium grade gasoline in any given region use the same base fuel, AAA says. What’s different is the unique mix of additives that each brand blends into their fuel before it gets to the fuel pump and into your car. Fuel brands mix in additives when their tankers are loaded at fuel terminals, says the NACS, a trade association for convenience stores and fuel retailers. The additives are designed to clean and protect the engine of a car by preventing the excessive buildup of carbon deposits, the NACS and AAA say. Those deposits can reduce performance and fuel economy, and cause other drivability problems. The Environmental Protection Agency (EPA) requires all gas retailers use a minimum level of additives, the NACS explains. According to EPA regulations, these additives must reduce an engine’s deposits by at least 10% compared to additive-free fuel. While these standards helped minimize certain deposits, some automakers felt the standards did not go far enough, AAA says. And so, in 2004, these automakers established a gas standard called “Top Tier,” which requires more additives that they say are of a higher quality. In order for a gas retailer to be a licensed Top Tier gas supplier, it has to meet the requirements established by the automakers. AAA conducted a study in 2016 on the long-term impact of gas with and without an “enhanced additive package,” such as Top Tier gas. The study showed long-term use of gas without an enhanced additive package “can lead to reductions in fuel economy of 2-4%, drivability issues, and increased emissions.” The AAA study found that there was a greater quantity of harmful deposits in engines of cars that didn’t use Top Tier fuel than there were in cars that did use Top Tier fuel. Top Tier’s website maintains a list of gas retailers that are certified retailers of the Top Tier gasoline standard. This list includes big national brands like Exxon and Shell, but also includes some local retailers. But “Top Tier” gas stations aren’t the only retailers that sell high-quality gas, says Consumer Guide Automotive, an auto review organization. Top Tier certification is optional and costly, and so some gas stations choose not to get certified. “This means that there are likely a number of gasoline retailers selling fuel that qualifies for Top Tier certification, but have chosen not to license the rights to say so,” Consumer Guide Automotive wrote in 2019. So should you worry about making sure you buy gas with enhanced additives? Occasionally using discount gas without as many additives likely won’t hurt your vehicle in the long run. AAA also found that, in 2016, Top Tier fuel brands were on average about 3 cents more expensive per gallon than other fuel brands at that time.
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
01-29-2024, 06:51 PM | #26 |
Rep 582
Best practice is to use "Top Tier" gasoline. Then quarterly add a bottle of Techron or such which with it being super concentrated does perform an additional cleaning that is above and beyond just using XYZ fuel.
It's also recommended to use a Liquid Molly or other such oil additive for fifteen minutes just before an oil change. Which helps loosen up sludge and other crud that thickens up motor oil and hangs out in the corners. |
ctcarbonari295.00 |
01-31-2024, 12:36 AM | #27 | |
1498
Rep 1,003
"More drivers report getting bad gas from metro Atlanta Costco locations" January 30, 2024 at 6:40 am EST https://www.wsbtv.com/news/local/mor...M6IR647ACZYDQ/ |
01-31-2024, 02:13 AM | #28 |
your average JAMF
3151
Rep 4,098
Drives: '21 M2 Comp, '19 Golf R
Yep. Or any Top Tier gas. Additive not necessary, just thins your wallet for slightly better seat comfort.
'21 M2 Comp
'19 Golf R |
DanG10705.00 |
01-31-2024, 02:15 AM | #29 |
your average JAMF
3151
Rep 4,098
Recommended by who exactly? Somebody who wants to sell it to you? Unless it's some 200k-mile Kia motor that's been running crappy oil, this is completely unnecessary.
'21 M2 Comp
'19 Golf R |
01-31-2024, 01:04 PM | #31 | |
Rep 582
Where I live when they had trouble sourcing they ripped up the parking lot and added a detergent dispensing system to ensure the proper dosing and detergents that meet their stringent requirements was added. |
01-31-2024, 01:38 PM | #33 | |
General
60765
Rep 19,751
01-31-2024, 03:35 PM | #34 |
Rep 582
01-31-2024, 05:27 PM | #35 |
General
60765
Rep 19,751
01-31-2024, 05:42 PM | #36 |
Rep 582
Not quite but close 99 Ron is 95 Octane here is the best conversion chart I can find. http://www.pencilgeek.org/2009/05/oc...nversions.html
In the US the highest octane is 92 (I work for a VERY large fuel distributor) Although specialty fuels are available in a pail or barrel but not readily pumped. |
M5Rick60764.50 |
01-31-2024, 06:09 PM | #37 |
Rep 436
Drives: 2016 F10 BMW 535i M Sport
Jbrown74032646.50 |
01-31-2024, 06:14 PM | #38 |
Rep 436
Yes using this or Intake Valve Cleaner and then and oil change then proceed with an Italian Tune-up ahahaha
eugenebmw1524.00 |
