01-22-2024, 06:49 PM | #1 |
Rep 14
Hi guys, I own a 2021 bmw 330i, M sport package. Everything was working fine then I sprayed air freshner into the AC vents while it’s on max, now my climate control buttons won’t work and the screen won’t light up. At first it was dimming in and out but now is just completely off. I can manage my ac through the screen just fine, everything else works just fine, but the climate control is gone. I also have a video but idk how to upload it on here. Could it be a fuse? Please help 🙏
01-22-2024, 07:46 PM | #2 |
Rep 93
Did you spray it into the vents above the controls? If so i guess if enough accumulated and dripped down it could hurt things. If youre trying to freshen the smell you spray into the filter location. I also feel like that panel being dead would throw a hidden code.
Bronxg204.50 |
01-22-2024, 08:48 PM | #3 |
Rep 14
I sure did spray the vents above the controls. Then after that, the lights started flickering on and off, buttons would work sometimes then don’t work the next minute. Now is just completely dead. Do u think it will fix itself once it dries up?
01-23-2024, 05:24 AM | #4 | |
Rep 93
Sorry to be a nihilist but i doubt itll fix itself. I see your safety system button (green circle) is off but the hazard switch is on. Im not sure if thats normal. Do they both work? |
01-23-2024, 05:45 AM | #5 |
Rep 14
Only the hazard works, nothing else. I’m still under warranty thankfully. Everything works just fine in the car.
Could it be a fuse? I have attached some “maybes” I found online doing research. #5 & #66 I have circled in red. There’s is another one for “interior lights” but I scratched that off being that every other light/function works inside. |
01-23-2024, 07:44 AM | #6 |
Rep 93
Theres a paper folded up inside the trunk fuse box and itll tell you exactly which fuse is which. Some G20 have a basic and others a high fuse box. As far as #5 you can check that one but its a pain to remove footwell cover.
Also i would NOT give this info about spraying to the service center....sorry i cant be more help |
01-23-2024, 08:37 AM | #8 | |
Rep 1,151
Since you are under warranty, I would take it to the dealership. Be prepared to potentially hear bad news. This is definitely user error and not a defect.
Bronxg204.50 |
01-23-2024, 08:40 AM | #9 |
Rep 14
Well I can always blame it on the water that accumulates on driver side foot well when it rains hard, it’s a known defect on these cars, I had made an appointment for that a 4 days ago. I think people here posted about the problem being inside the driver side door, a seal? Idk.
Regardless, I won’t ever speak on the spray part lol. |
01-23-2024, 09:01 AM | #10 | |
Rep 1,151
Good luck!
02-02-2024, 07:39 PM | #12 |
Rep 14
Long story short, dealer didn’t cover the part, I fried out the climate control. I bought another one and installed myself, the dealer did say it had to be programmed.
But everything works flawlessly on my car now, except seat warmers, I’m guessing that’s what they meant as to have to code it. Is there a way I can code this myself? I hear the seat warmers click on and off when I touch the button, just barely/no heat going to the seats. There’s a before and after pics. Any help is appreciated! |
02-29-2024, 11:46 AM | #13 |
Rep 1
My climate control buttons stopped working as well. However, I’m not sure what caused it to stop working.
Have you tried turning on the heated seats through BMW Voice? I can turn mine on VIA BMW voice. Can you provide the link where you purchased yours from? |
