04-19-2024, 05:08 PM | #1 |
Rep 124
Exhaust rust
So I jacked my car (up) today and as a man should, replaced the winter tires/wheels with the summer set MYSELF
Toxic masculinity aside, I noticed my rear summer P Zeros were essentially slicks. The only possible conclusion would be that during winter storage, the outer layer shed itself due to poor quality Italian rubber, having nothing to do with me sliding the car around a race track last year at all. While under the car, I noticed the entire exhaust system was rusted on the outside as well as the muffler and even some rust spots inside the exhaust tip just outside the exhaust valve. I would assume that's normal given I live in the best part of North America, i.e. Canada. The combination of cold, moist, free healthcare air would do a number on exposed metal I suppose. I want to avoid that if possible on my next ride. Any tips on how to prevent that from happening? I'm sure there are coatings and such out there, but would they stick to the exhaust and maintain adhesion when exposed to couple of 100 degrees of well catalyzed exhaust gasses, day in, day out? On a side note, I need a proper Jack recommendation. The old piece of crap jack I used was anemic and as a man, I felt inferior not using a big proper manly Jack. Jack stand recommendations are also welcome, as well as proper BMW approved slots. |
04-19-2024, 05:15 PM | #2 |
Rep 1,933
I drove my car in winter and there's zero rust on the exhaust, granted I did weekly car washes and it sprays the underside.
04-20-2024, 05:30 AM | #3 |
Rep 443
QUICK JACK is the way to go. I push them under the middle of the car and just park the car over them. Or you can hang them on the wall.
04-20-2024, 07:38 AM | #4 |
Rep 916
Moisture and salt. Not a good combo no matter what. You can maybe try spraying the exhaust with a very high temp clear paint, but it’s not ideal. Move somewhere where it’s not like that or don’t drive it in winter if you like Canada so much to stay where you’re at.
04-20-2024, 09:30 AM | #5 |
Rep 1,658
These cars are designed and built in Germany where there’s pretty heavy winters-anyone know if they use salt there or sand?
2019 M850i xDrive Coupe (06/19 Production)
Mineral White/Black, HP Cooling/Tire/M-Technology Pkg/Extended Shadow/Etc., Anthracite Headliner, Carbon Roof, DAx2, Display Key, Various Accs'. Topic permitting, I try to be objective as possible |
04-20-2024, 09:54 AM | #7 |
Rep 1,658
lol nonetheless one would hope the exhaust should be rust resistant at the very least especially if built/designed where there’s alpine winters
04-20-2024, 10:53 AM | #8 |
Rep 916
Yeah, but high concentrations of salt will cause rust no matter what. Like ocean water or higher concentrations will absolutely eat any metal up. The worse cars to buy are from snow regions, especially ones where the snowy seasons are much harsher and longer than others. Brakes, suspension, even chassis end up being eaten alive unless the owner made it a habit of rinsing all that shit off pretty routinely.
04-21-2024, 06:44 AM | #9 |
Rep 321
04-21-2024, 08:01 AM | #10 | |
Rep 1,658
Mineral White/Black, HP Cooling/Tire/M-Technology Pkg/Extended Shadow/Etc., Anthracite Headliner, Carbon Roof, DAx2, Display Key, Various Accs'. Topic permitting, I try to be objective as possible Last edited by RJC-1; 04-21-2024 at 01:39 PM.. |
04-21-2024, 04:33 PM | #11 | |
Rep 210
https://www.instagram.com/reel/C4sDY..._web_copy_link Last edited by / / / M3; 04-21-2024 at 04:38 PM.. |
Tags |
jack |
