Technical Topics DIYs and Coding Discussions DKOMBI4 flashing failed. Any idea?
      05-13-2022, 11:32 AM   #1
ATG_
Drives: e90 320d, g20 330i
Hello,
Please, could you give me an idea what is wrong and how to do successful flash.
Ethernet cable. BMW G20 2019, updated all ECUs (flashed). All (23 of 24) went well, except DKOMBI4.
DKOMBI4 is not working, but it is still possible to flash it. I tried to repeat it, but getting the same error.
Log:
<[DKOMBI4 - 60] prepareECUforBLUpdate started [PROGRESS]>
<[DKOMBI4 - 60] prepareECUforBLUpdate finished [PROGRESS]>
<[DKOMBI4 - 60] authenticateECUforBLUpdate started [PROGRESS]>
<[DKOMBI4 - 60] authenticateECUforBLUpdate finished [PROGRESS]>
<[DKOMBI4 - 60 - flsl_00005c56-100_003_005] Transaction type: blFlash; Message: TA started [TRANSACTION]>
<[DKOMBI4 - 60] performECUBLUpdate started with protocol UDS [PROGRESS]>
<[DKOMBI4 - 60 - flsl_00005c56-100_003_005] Transaction type: blFlash; Message: 0% progress on ECUIdKOMBI4_0x60 [0% of flsl_00005c56-100_003_005] [TRANSACTION]>
<[] job failed with negative response error:
code: repeat job
description: Service TD returned a negative response with response code generalProgrammingFailure; LinkName: DKOMBI4_60_ETHERNET
severity: ERROR
[THROWABLE]>
<[DKOMBI4 - 60 - flsl_00005c56-100_003_005] Transaction type: blFlash; Message: TA finished [TRANSACTION]>
<[DKOMBI4 - 60] -MessageID is used multiple times, so MessageText may be ambiguous-job failed with negative response error:
code: repeat job
severity: ERROR
[WARN]>
<[DKOMBI4 - 60] - [Exception - DKOMBI4 - 60] job failed with negative response error:
code: repeat job
severity: ERROR
<MCDDiagService<id=28634, job=com.bmw.psdz.jobs.uds.MCD3_PerformECUFlashBL, service=RD - RequestDownload, description=error: negative response : conditionsNotCorrect, link=DKOMBI4_60_ETHERNET> [DIAGSERVICE]>
code: repeat job
description: Service RD returned a negative response with response code conditionsNotCorrect; LinkName: DKOMBI4_60_ETHERNET
severity: ERROR
[THROWABLE]>
<[DKOMBI4 - 60] There was an error during TAL execution, please check the log files. [WARN]>
code: repeat job
severity: ERROR
<[DKOMBI4 - 60] installECUBL started [PROGRESS]>
<[DKOMBI4 - 60] installECUBL finished [PROGRESS]>
<[DKOMBI4 - 60] finalizeECUBLUpdate started [PROGRESS]>
<[DKOMBI4 - 60] finalizeECUBLUpdate finished [PROGRESS]>
<[] There was an error, please check the log files. [WARN]>
<[] - [Exception - DKOMBI4 - 60] job failed with negative response error:
code: repeat job
severity: ERROR
      05-13-2022, 03:22 PM   #2
maximking
Drives: F10
You have flashed with launcher or without ?
      05-14-2022, 12:23 AM   #3
ATG_
Without launcher
      05-15-2022, 03:25 AM   #4
maximking
Drives: F10
PM me will try help you out
      05-25-2022, 08:26 AM   #5
ATG_
Local experts re-flashed it successfully, works fine now.
      05-25-2022, 02:19 PM   #6
G30M
G30M's Avatar
3787
Drives: BMW M550i; Kia EV6 GT
that's a relief! enjoy!
ATG_7.50
      05-26-2022, 10:06 AM   #7
ferbmw
Drives: BMW 330i G20 2019 Sportline
what did they do? Do you have details??
      05-26-2022, 02:23 PM   #8
ATG_
Looks like bootloader was incorrectly flashed (mistake in 2022.03 data?)
KOMBI didn't want to reply on several important requests.
1. Tried to flash in the car, didn't work well
2. Removed
3. Disassembled, made sure everything is OK and the part is original from this car. Confirmed that.
4. Attached to their harness on the table, flashed after several tries.
5. Works fine, no errors in ISTA.
I checked again with esys, TAL calculating. All 24 modules are visible and fine.
23 of them are black (no changes) after SVT calculation.
Kombi HW is black, everything else is RED / BLUE, which makes me think it may be some mistake in this psdzdata... and I won't update this module using this psdzdata...
      05-27-2022, 07:16 AM   #9
ferbmw
2. Removed
did you flash with ista or esys? it is no the first time psdzdata is wrong....
      05-27-2022, 01:44 PM   #10
ATG_
esys
      06-26-2022, 06:49 AM   #11
hanselfransel
Germany
Drives: BMW
Have the same problem now with 22-07-521
Can not solve it. Anyone able via remote?
      06-27-2022, 03:29 PM   #12
hanselfransel
Germany
Drives: BMW
Anyone in europe who can try flash it on the bench?
      07-05-2022, 06:57 AM   #13
ferbmw
Did you finally solve it? What ilevel/psdzdata you used?
      07-05-2022, 02:28 PM   #14
hanselfransel
Germany
Drives: BMW
Not possible to solve, i used 22-07-521
Sent it to someone who tried to repair it on the bench, but did not get it work.
He said PT Can Wakeup Line defect.
I dont know what this is and who can repair.I have bought now a virginized used one.Will see if it works
      07-07-2022, 03:01 PM   #15
hanselfransel
Germany
Drives: BMW
Bought used kombi, it should be virginized, but bullshit , only odo was 0KM .Old VIN was still in the car and red manipulation point was set.
Now i will buy a new one.
      07-19-2022, 01:17 PM   #16
ferbmw
any update on this?
      08-07-2022, 10:16 AM   #17
hanselfransel
Germany
Drives: BMW
Bought a new one, did ECU verification with aos System .
Got this file in Ista and did the verrfication to thhe car .
Its possible to write with esys too
coding, dkombi4, flashing, g20, programming
