03-10-2020, 10:48 PM | #133 | |
Rep 11,759
Drives: 2018 M4 Comp Indv
So even if someone agrees with all of your numbers, it means the F8x *BARELY* beats an M340i, and needs time, and not by much, and maybe not in some scenarios. In your scenarios, with your numbers, that's the same performance tier! May I humbly suggest you watch Ford vs Ferrari? What you'll notice is that, yes, power/chassis matters, but only if you can reliably count on it. See, the F8x has seven coolers. Seven! (right? that still true?) All of its performance parts are custom designed to handle massive track stress all day long. It's oil sump is designed to resist g-forces. See where I'm going? What puts the F8x car in a different tier is that it can run at a track (or in a canyon) at anger management speeds for 8 hours and then drive home no worse for wear. again and again. The M340i is not designed to handle that kind of stress. So, what makes the F8x special, what defines the tier, is not the performance numbers in a 1-off test, but that the F8x is reliably trackable all day long, all year long. |
mcjohnsonsg386.00 |
03-11-2020, 06:15 AM | #134 | |
Rep 489
03-11-2020, 06:38 AM | #135 |
Rep 281
Shankopotomus29.50 |
03-11-2020, 10:27 AM | #136 |
Rep 845
He was fine doing 125 in a 60 though and trying to fornicate with my exhaust pipes? I am sure he could stretch a little.
03-11-2020, 10:51 AM | #137 |
Rep 190
We all know it’s not an M. As I see it it’s pretty much as fast as the outgoing M but massively more useable, modern, cheaper and a better daily driver. Also there is no M touring.
Say it’s not as special or doesn’t have the feel of an M car. Don’t try and play the speed game because there is fuck all in it. |
03-11-2020, 11:57 AM | #138 | |
Rep 14,115
Drives: G82 M4C X-Drive
The video was an acceleration test from 0-100 then 200 then 250kph. The M3 won 2 of three, the majority, and you interpreted it as a post showing the M340 was faster to 60? That's not only inaccurate, it's to 100kph, but it's incomplete, since it lost to 200 and 250. We shouldn't be cherry picking to come up with a conclusion.
03-11-2020, 01:34 PM | #139 | |
Rep 845
There is something in the speed game between a high 11 quarter mile at 120mph trap vs a mid 12's at 113-115 if we want to play that game. Also it's a generation ahead. I am not sure where the claims came that the M340i is just as fast if not faster when they are all objectively incorrect for maybe the exception of the 0-60 which is largely debated as F8x's have been launched in the 3.7-4.0 region without much difficulty. We sit here and compare a 4.3 second launch with just a speedometer reading, reminds me of a video recently i saw of the M340i doing 3.9 going downhill, we have 0 clue what elevation these cars are at. All in all, as i said, the M340i is still in a tier below in flat out speed, it just is. It is a very fast car but a tier below. |
jmg18703.50 |
03-11-2020, 03:34 PM | #140 | ||
Rep 315
03-11-2020, 03:38 PM | #141 | |||
Rep 14,115
03-11-2020, 03:47 PM | #142 | ||||
Rep 315
03-11-2020, 05:44 PM | #143 | ||
Rep 845
You sure your M3's weren't broken or you forgot the other half of your gas pedal? |
03-12-2020, 08:58 AM | #144 |
Rep 2,007
Absolutely positive. I'm sure they will make the new M faster, but if you are driving a current model M and an M340 pulls along side of you.... well, you might just get embarrassed.
03-12-2020, 11:33 PM | #146 | |
Rep 14,115
03-13-2020, 11:46 AM | #148 | |
Rep 1,044
Btw the Tesla is no slouch when it comes to cornering (mainly due to its C of G being so low) |
jmg18703.50 |
03-13-2020, 02:27 PM | #149 | ||
Rep 14,115
OR you can get the M340i for what it's really good for: Cheaper, slightly more practical, newer tech, AWD, and size. I'm not sure why so many people are requiring it to be faster than an M car be considered a good car. It's simply not the same league as an M car because it's not designed to be. If it were designed to be more of a performance car, it wouldn't weigh as much as it does and it would have a wider stance to accommodate a wider track.
03-13-2020, 05:35 PM | #150 | |||
Rep 845
M340i is not faster, i don't get it, the cs traps at around 122 mph which is different from the 118-120 of regular m4 which is different from the 113-115 of m340i. The M4 civic, M4 comp pack, M4 cs all sport very similiar times, the variation happens in the consistency of those times and the 1-2 mph quarter mile trap difference and 0.1-0.2 second quarter mile time, the real difference is the cs and comp consistently launch sub 4.0 which would beat out the 340i while the civic is hit and miss, sometimes sub 4.0 as low as 3.7 other times up to 4.3-4.5 |
jmg18703.50 |
03-13-2020, 09:15 PM | #151 |
Rep 1,168
I take it as a compliment it's even getting compared to the F80 gen.
I don't see the big deal. You'd think M owners want the base 3 series to be solid performers. Just means the G80's will be even better even if they're guise is highly controversial
2020 M340xi PB (sold)
03-13-2020, 11:08 PM | #152 |
Rep 14,115
You should and we are, but facts are facts.
03-14-2020, 12:59 PM | #154 | |
Rep 845
The stock and zcp run mostly 3.9+ while the cs goes down to about 3.7 more consistently. The 4.3 launch in this video is trash can tier, probably done in snow ahahahaha or on bald all seasons |
