03-24-2019, 06:18 AM | #23 | |
Rep 114
I have had both a 340 and 430 and am not happy with noise level, hoping it wont be an issue on the new versions |
03-24-2019, 12:50 PM | #24 |
Rep 9
I have a question on performance - is the performance gap between the G20 330i and F30 340i large or not noticeable? I'm mostly concerned about low speed accelerations (e.g. up to 120 Kmph / 75 MPH).
03-24-2019, 01:20 PM | #26 |
Rep 525
03-24-2019, 01:22 PM | #27 |
Rep 525
I'd say an F30 340 would have better performance in terms of power when compared to a G20 330i. However, the G20 340i should be more of a significant difference compared to what you have.
03-24-2019, 01:24 PM | #28 |
Rep 525
03-26-2019, 06:18 PM | #29 | |
Rep 114
08-12-2019, 05:14 PM | #31 |
Rep 14,115
Drives: G82 M4C X-Drive
I find it completely ridiculous that you can't close the center console while a USB is plugged in. I have to drive the 330i loaner I have around with the cup holders exposed just to use my iphone. The F30 used to have an accessory port under the glovebox dash which allowed for "hidden" power supply that didn't clutter the dash. Why did they get rid of it or at least design the center console door to allow for routing a usb cable?
08-12-2019, 07:54 PM | #32 | |
Rep 2,290
08-13-2019, 02:15 AM | #34 |
Part of the bimmer family!
139
Rep 293
Drives: BMWG20; BMW E90
Apple pay responds to NFC. The tray sends out NFC. So don't think this is BMW'S fault?
08-13-2019, 02:47 AM | #35 | ||
Rep 14,115
08-13-2019, 05:54 AM | #36 |
139
Rep 293
I'm sure if you can afford calling using an iPhone and driving a bmw, buying an usb c cable shouldn't be an issue?
08-13-2019, 11:51 PM | #37 | |
Rep 14,115
I'd still rathe have a plug under the glove box.
08-14-2019, 02:32 AM | #38 |
139
Rep 293
I hear you. I don't have any C to Lightning cables either. Yet. Because USB C is a modern standard I'm sure I'm going to use it in the future as well as more and more devices are equipped with it.
So to me, worth the money and only a slight inconvenience during the transitional period between A to C. I'm very happy BMW choose to put in USB C ports and not anything older. You also have very small C to A adapters so you can still use your old cable.
stein_325i25083.00 |
