09-07-2021, 01:57 PM | #1 |
Rep 71
License plate brackets/holders G20 (not the frame)
What's up with BMW releasing license plate brackets/holders, both front and rear, with plastic self-tapping holes w/ screws for G20?!
Anyways, my actual question; is there an alternative BMW license plate brackets/holders for G20 with stainless steel or brass thread inserts? My F80 plate brackets came with thread inserts, but they wont work on G20 due to the slight variation in mounting hole gaps and shape/profile. Dealer (parts personnel) is a pain to deal with because he only wants look for the parts under the VIN number. Useful help/tips will be appreciated. Thanks in advance. Note: I don't want to use tow hook plate mounting bracket anymore because dealer already mounted the front one on the bumper(drilled in).
///M3 F80
------------- Sold: STi VA1 Series.White, 330i xDrive G20 WRX VA1, STi GV2, EvoMR CZ4A, STi GDB |
09-07-2021, 04:10 PM | #2 |
Rep 44
Can’t speak to the front because it’s not required in AZ. For the rear, I replaced the sh!t stock part with this one… much more secure.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
07-19-2022, 01:37 PM | #3 | |
Rep 139
Asking because I'm sick of dealing with those stupid brass inserts seizing after a few winters & would prefer to use a self-tapping screw for plastic. Was hoping the new G-series bracket could bolt to an F-series car. thanks! EDIT: stopped by the local dealership this evening, the brackets are 100% forward / backward compatible. Only difference is the self tapping screws on new vs. brass inserts on old. Last edited by Neuner; 07-19-2022 at 07:46 PM.. |
07-21-2022, 09:52 AM | #4 |
Rep 71
I don't have the G20 anymore...got rid of it.
Anyhow, if I recall correctly, BMW has new (as in revised) plate brackets for F series without brass inserts. According to the dealer BMW has eliminated those brass insert completely (on all of their plate-brackets). I never had this seizing issue. Well, I always replace those crappy steel screws/bolts which dealers use with stainless steel ones along with thread anti-seize. Plus I have the screw covers as well.
///M3 F80
07-21-2022, 05:17 PM | #5 | |
Rep 139
what did you mean by this statement? were you talking about the front plate mounts? the rear are identical, other than the screw thread type. Last edited by Neuner; 07-21-2022 at 09:50 PM.. |
07-21-2022, 10:06 PM | #6 |
Rep 71
If they are the same besides the inserts good for you
I don't know what else to say because when I pulled the one off my F80 and tried to fit on the G20 it didn't quite fit. When I looked up the PNs for F80 & G20 they were different...even the revised one without inserts for the F80.
///M3 F80
07-21-2022, 10:19 PM | #7 | |
Rep 139
Dunno about your car or what you're saying about the p/n's. There's the new & the old, that's it. |
07-22-2022, 01:18 PM | #8 | |
Rep 2
https://www.amazon.com/Genuine-Licen.../dp/B08P8P9JQ7 https://www.ebay.com/itm/234078817007 The BMW part number for this is 51117422238 |
08-08-2022, 10:43 AM | #9 | |
Rep 71
///M3 F80
------------- Sold: STi VA1 Series.White, 330i xDrive G20 WRX VA1, STi GV2, EvoMR CZ4A, STi GDB Last edited by SP_M3; 08-08-2022 at 10:55 AM.. |
08-08-2022, 10:52 AM | #10 |
Rep 71
So I was waxing the car (M3) over the weekend. I took the plates off and while at it I checked the rear plate bracket again. Both mid-holes on the bracket are through-clearance holes. I believe the bracket which came on my 330 had one through-clearance-hole and one through-clearance-slot to mount the bracket to trunk lid. M3's bracket has the BMW logo, but I didn't see a pn. I don't know what's going on.
///M3 F80
