04-17-2022, 06:19 AM | #309 |
Rep 3,062
This can be done if you have 552 or 5AZ option which means either Adaptive Headlights or Laser Headlights
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
05-05-2022, 02:16 PM | #310 |
Rep 820
Drives: 2021 BMW X3 M
Has anyone figured out how to do this with Bimmercode? There's a video on youtube on how to enable anti-dazzle headlights on an X5. Potentially similar on our cars.
2014 BMW 335i M-Sport - SOLD
05-12-2022, 10:31 AM | #312 |
Rep 1
xnick101 I successfully coded it using only Bimmercode. The FLM (front lighting module) items are available in the BDC (Body Domain Controller) section for Bimmercode with the G20. The KAFAS items are not changeable, however, so optimization for staying on longer with street lights / signs isn't possible; you'll need Esys for that. But basic functionality plus some parameter editing to improve performance is possible.
Basic functionality is in BDC section with the following changes: Code:
PARAMETER US VALUE ECE VALUE C_HBA_DIM_ENA: disable [00] enable [01] C_HBA_GFHB_ENA: disable [00] enable [01] Code:
PARAMETER US VALUE ECE VALUE C_AFS_ECO_LEVEL_3_ENA disable [00] enable [01] C_AFS_ENA disable [00] enable [01] C_BLC_PRE_ENA disable [00] enable [01] C_CLC_CURV_V2 US [3C] ECE [23] C_CLC_CURV_V3 US [46] ECE [28] C_CLC_EXT_ENA disable [00] enable_roundabout [01] C_HBA_DIM_ENA disable [00] enable [01] C_HBA_GFHBA_ENA_V_HI 55km/h [37] standard [3C] C_HBA_GFHB_ENA disable [00] enable [01] LUT_AFS_CODRV_HOR Laser_US/G007_US standard/init LUT_AFS_DRV_HOR Laser_US F040_G005_AHL/G015_G020_Laser LUT_FLC_FORWARDLIGHTING_Y no_AFS [00 00 14] AFS [00 00 00] I find that it works quite well. The highbeams definitely tunnel around cars that I'm following, and turn off for opposing traffic while still staying on in my lane. I am driving a 2022 M340xi (North America). Last edited by dantwaddell; 05-12-2022 at 10:37 AM.. Reason: adding detail |
08-17-2022, 02:36 AM | #314 |
Rep 8,364
08-18-2022, 10:34 PM | #315 |
Rep 28
Followed the instructions here, but I FUBARd my BDC_BODY3 coding. Error message after coding complete on this ECU and No lights, turn signals.
When I tried coding back to the original, the attached screenshot is the error I received. Running Launcher Pro 5.1 E-Sys 3.40.2 PSdzDATA 4.36.71 US-spec 330i with laser lights. i-level on my car is 03/2021.50 Selected S18A when connecting to my car. |
08-19-2022, 02:13 AM | #316 | |
Rep 8,364
08-19-2022, 07:09 AM | #317 |
Rep 28
08-19-2022, 04:58 PM | #318 |
Rep 8,364
08-22-2022, 10:01 PM | #319 |
Rep 5,316
Drives: G80 M3 6MT
Anyone have issues with Auto high beams just shutting itself off? As in you need to re-enable it with the button on the stalk. it happens randomly, sometimes I turn it on and it just right back off and it takes 2-3 tries before it "stays" on.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
08-26-2022, 04:12 PM | #321 |
Rep 153
My order is still pending production. But the "standard equipment" listed includes "Decoding for no-dazzle hgh bm."
Does that mean that after market coding won't be needed to get full functionality? |
08-26-2022, 05:03 PM | #322 |
Rep 8,364
08-26-2022, 09:37 PM | #323 |
Rep 30
I've been having this issue too. Not sure what the fix is. It's a bit annoying.
08-26-2022, 11:22 PM | #324 |
Rep 8,364
Have you tried coding back to factory settings to see if issue is still present?
10-06-2022, 10:23 PM | #326 | |
Rep 286
From googling around, I suspect this may be a JVM memory issue since it only affected BDC for me while VO coding the entire module (after removing the anti-dazzle decoding). Everything else worked fine. |
10-17-2022, 08:40 PM | #327 |
Rep 254
Drives: 2020 BMW M340i xDrive
I coded anti-dazzle this weekend on my 2020 M340i xDrive. I had a similar problem to tomz17 and homerjay, I should not have VO coded using Launcher Pro, was told to only use Launcher Pro for FDL Coding and use Esys by itself (no launcher) for VO Coding.
I provided 2GB to the JVM using Launcher Pro and still had issues so I don't think it was a JVM memory issue. There seems to be something wrong with reading and coding all of BDC when using Launcher Pro, maybe some kind of bug? I wonder if it would have happened with BimmerUtility. I did the VO coding first then used the Cheat Codes from siegester for FDL coding anti-dazzle in KAFAS4 and BDC_BODY3. Anyway - drove home tonight and wow anti-dazzle is awesome, I wish I had done this back when I first got the car instead of waiting 3 years to do it. Definitely makes buying the Laser Lights worth it. It still turns off sometimes, but the highbeams stay on way more often and definitely help with visibility. |
10-17-2022, 09:05 PM | #328 | |
Rep 8,364
Launcher Pro has outdated mapping, so better to use Bimmer Utility for FDL coding. |
10-19-2022, 06:58 AM | #329 | |
Rep 254
I was using E-Sys 3.38.2, LauncherPro 5.2.0, PSdZData_Lite_v4.37.42 shawnsheridan was the one who recommended using ESYS with no launcher for VO coding and using a Launcher for FDL coding only. Wish I knew about BimmerUtility before I paid $50 for LauncherPro (I just bought LauncherPro on 10/14/22) Last edited by Liquid_Ice; 10-19-2022 at 07:09 AM.. |
10-30-2022, 03:02 AM | #330 | |
Rep 8,364
I have occasionally had issue during remote coding for injection, but always good advice to remote unneeded variables to isolate issues. |
