2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK New 330e charging queries...
      10-27-2020, 04:18 AM   #23
Jim_330e
144
Drives: 2020 330e M Sport
This post explains how Adaptive works
https://g20.bimmerpost.com/forums/sh....php?t=1679165
Obviously, those of us with only M Sport don't have this ��
Arrived: '20 330e M Sport in Mineral Grey
'03 MY 996 Turbo in Arctic Silver
Gone: '18 Golf GTI Performance DSG in Tungsten
ADIUK89.00
      10-27-2020, 04:24 AM   #24
thomashunt1
Drives: BMW 330e Msport (ordered)
since ordering my 330e im looking into orderin a podpoint. i know the 3 series only has capability of the 3kw charger, and with the OLEV grant this is £449 (un tethered) and £479 (tethered).
But is having a pod point actually worth it, or is plugging it in to mains power sufficient?
      10-27-2020, 04:31 AM   #25
shakey707
England
26
Drives: BMW G22 M440i Xdrive
I would say install a podpoint or similar. I have an EV Mini Pro, charge time approx 2.5 to 3 hours compared to 8 plus hours on 3 pin.
And surely it will add value to your home. In 5 to 10 years I’m sure one of our cars will be pure electric.
Get one whilst there still is a government grant!
      10-27-2020, 04:36 AM   #26
wassap
wassap's Avatar
86
Drives: Volvo
Ive had one fitted in preparation for mine. I was planning to go via the OLEV grant route, but i was getting quoted daft money for a simple install, i was getting quoted £750 or so for a cheap WALL E 7KW unit. So I decided to source a used pod point from Ebay and had it fitted by a local spark. This cost me around £400 inc materials, and i had a 3 pin socket fitted outside at the same time. The OLEV installers are taking the mickey on prices, they have so much work, they dont need to be competitive anymore.
That said, Ive only had one fitted as im planning to get a full EV for the wife in the next 12 month. It all depends on your usage, i want to get as much usage as possible from the battery, and i would like the option to be able to pre condition without impacting range.
Jim_330e144.00
      10-27-2020, 05:36 AM   #27
woody320
Drives: G20 330e M Sport
I have a Zappi charger fitted in my garage and it really is excellent. For what its worth it links with the solar panels on our roof and in summer you can (and I do) choose to recharge purely on solar. Whilst its no huge saving, its actually a nice feeling.
Jim_330e144.00
      10-27-2020, 08:41 AM   #28
ADIUK
ADIUK's Avatar
89
Drives: X3 xDrive30e M Sport 2020
I was originally waiting for a Countryman PHEV and got a BP Chargemaster 30amp Type 2 Tethered unit fitted £549.
Worked well with the MINI E they loaned me (7kw)
As shakey707 said the 3 hour charge time is beneficial expecially if you do multiple journeys a day.
Also preconditioning does not impact on your drive away mileage.
      10-27-2020, 11:29 AM   #29
Vossy
110
Drives: G20 330E M Sport
I have the recommended 3kw Podpoint charger. Big mistake. Go for the 7kw output as the 3kw isn’t enough to charge AND precondition the car. If you go with 3kw and precondition you will lose a fair amount of electrical range as the car can’t charge and precondition simultaneously with only 3kw charging.
ADIUK89.00
      10-28-2020, 10:58 AM   #30
thomashunt1
On the pod point website, if i click on the 330e, it recommends getting the 3kw charger though...
      10-28-2020, 05:16 PM   #31
Vossy
110
I know I regret that I followed it. Your decision but a) the 7kw won’t make any difference to charging b) it’ll enable full charging without any loss when preconditioning.
      10-28-2020, 05:20 PM   #32
Vossy
110
Quite simply the Pod-Point recommendation is spot on if you have no intention of preconditioning whilst tethered.
If you want maximum charge and a warm/cool car in the morning the 3kw option isn’t enough. Preconditioning wasn’t factored in.
      10-29-2020, 03:23 AM   #33
Jim_330e
144
Plus, if you and when you get a full EV car, 3kw won't be any good at all!
      10-29-2020, 06:14 AM   #34
thomashunt1
Ill be looking into the 7KW then. thanks!
      11-03-2020, 03:03 AM   #35
thelegendofyrag
Drives: BMW 330e
I've had my 330e now since Sept last year. I regularly get 29-32 Miles from my home pod point charger, plugged in via a socket or from other public pod points.
As soon as the car is on with heating I lose up to 7 miles but with the heating turned off it holds the charge. Not so ideal this time of year though.
Charge also depends on when the car has charged vs when I use it. I.e charge when I get home in the evening and use it in the morning it may show 29 miles. If I plug in before I go to bed and use in the morning I'll get 30.
I've found the key is to set the charge time on the app or in the car so it's ready roughly when I leave, this is where I've been getting 32 regularly, they seem to lose miles after being fully charged and sitting idle.
      11-04-2020, 02:59 AM   #36
lloydster82
lloydster82's Avatar
30
Drives: 330e M Sport plus edition
I charge mine at cheaper rate in the early hours of morning so its ready to go to work. First frost of year today so used the pre-condition function on app for the first time. (Car was still plugged in from charging up). Worked a treat! However, does anyone know if the car will auto pull power from the cable to pre-condition or will it take car battery power and therefore eat into my range? I noticed the range was lower than normal but not sure of this was simply down to it being colder. Or do I need to programme the car, telling it where to draw the power from?
      11-04-2020, 03:16 AM   #37
wassap
wassap's Avatar
86
Drives: Volvo
What sort of charger do you have? If it’s a 7kw then there will be no impact on range, if it’s the 3 pin or a 3.7kw then your range will be impacted.
      11-04-2020, 03:38 AM   #38
lloydster82
30
I am using a Rolec wall pod 7.2kw. Thanks!
      04-14-2021, 07:20 AM   #39
woody320
Originally Posted by george15B View Post
woody320, that is awesome, for sure. Can I know what exact solar power kits do you use, and what was a price for them?
My charger is a Myenergi Zappi. This then has an additional Harvi wireless sensor. This is installed in the electricity box. You can then choose on the app if you want to normally fast charge (obviously it will use Solar power if its available) or if you choose Solar only it will recharge only on the power from the panels. In the height of summer I charge it like this as it does not matter how long it takes. But when you drive away knowing your battery has been recharged on solar power it really is a nice feeling. I think the whole thing was about £800 of which £500 was a grant. That was all fitted and working. I love it.
      04-15-2021, 08:07 AM   #40
cliveywolves
37
Drives: 330e M Sport Plus Edition 2020
What should it cost approximately in the UK to do a full charge from standard 3pin charge cable ??
Cheers
      04-15-2021, 08:29 AM   #41
ADIUK
ADIUK's Avatar
89
Depends on your tariff.
About £1.80 if 15p kWh
      04-15-2021, 08:34 AM   #42
ADIUK
ADIUK's Avatar
89
Max a 330e can accept is 3.7kWh.
If I precondition I wait about 20 mins after set departure time to allow the charger to "top up".
The heater can draw 5kW so my 3.7kWh charger cannot keep the battery topped up. Only after the heating has finished can it do that.
Roughly 1.3 kWh needed so 20 minutes.
      04-15-2021, 12:33 PM   #43
willougs
willougs's Avatar
267
Drives: BMW 330e
Cheers
If you can be bothered to go down the smart meter route, and can change suppliers, I recently switched to Octopus Energy Go tariff which has 4 hours per day at 5p/kWh. Would guess it costs about £1.20 for a full overnight charge.
(see link below to switch and get £50 free credit!)
Would be even less if you could get a proper home charge point and charge fully within the 4 hours.
For cheaper charging, switch to Octopus Energy using this link and get £50 free credit
      04-15-2021, 01:41 PM   #44
cliveywolves
37
Thanks for advice but tied into a tariff till November with no smart meters available with my current supplier, but based on circa £1.80 for a full charge I’ll just ride it out till my contract is due and will swap to a EV tariff supplier
