Technical Topics DIYs and Coding Discussions Bimmercode
      10-26-2020, 09:35 AM   #1
Le2
Mr
South Africa
Drives: BMW 330i M Sport G20
Bimmercode
Greetings M Performance family. I have a Vgate icar 2 OBD professional when I use it on bimmercode I can't access Advanced Crash Safety Module and Body Domain Control Unit. The error message says "This control unit is not accessible with the used OBD adapter"
My Question is, does Vgate Icar Pro has the same limitation? I am thinking of purchasing it but I need to know if I won't be throwing my money in a pithole. Vgate is the only OBD that is easily available in South Africa at the moment.
Your assistance will be highly appreciated.
      10-26-2020, 09:44 AM   #2
Tam the Bam
Grumpy Old Git
Tam the Bam's Avatar
443
Originally Posted by Le2 View Post
Greetings M Performance family. I have a Vgate icar 2 OBD professional when I use it on bimmercode I can't access Advanced Crash Safety Module and Body Domain Control Unit. The error message say "This control unit is not accessible with the used OBD adapter"
My Question is, does Vgate Icar Pro has the same limitation? I am thinking of purchasing it but I need to know if I won't be throwing my money in a pit hole. Vgate is the only OBD that is easily available in South Africa at the moment.
I don’t see Vgate as one of the approved adapters on the Bimmercode website.
See these other threads for more info on what people use ...
https://g20.bimmerpost.com/forums/sh....php?t=1726475
https://g20.bimmerpost.com/forums/sh....php?t=1741368
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
Le22.50
      10-26-2020, 10:23 AM   #3
chenry
Drives: BMWs
I could not use wireless adaptors with bimmercode and the G20 for full access - like you I could not gain access to all the modules (this despite the fact that this same setup worked flawlessly on my last couple BMWs)
I ended up ordering a simple lighting to obd cable and it works flawlessly (and much much faster vs wireless)
Hope this helps
Le22.50
      10-26-2020, 11:02 AM   #4
Le2
Mr
South Africa
Thank you
