08-11-2021, 04:46 AM | #1 |
Rep 3
"Limited support with driver assistance" error- 2 systems affected
Hi all, I'm getting this error on the central screen of my 330i xdrive. It is very annoying because the message appears every 45 seconds, even acepting and closing the message, it appears again... so the gps, carplay and any othe app are blocked.
I tried to stop and start the car, close and open it, but it's still there! Only parking the car and waiting for some hours makes the error disappear until next time (may be next day, next week, weeks... it unpredictible) The message also says that there are 2 systems affected: lateral colission detection and lane departure warning. As far as I see both systems are related to lane detection. Any idea of what's happening. Anyone had a similar experience? Thanks in advance! |
08-11-2021, 05:51 AM | #2 |
Rep 177
Looks like a faulty (or dirty) sensor which is throwing an error code. A dealer will have to run the diagnostics and will find what component is causing the trouble.
Jose Vigil0.00 |
08-11-2021, 07:13 AM | #3 | |
Rep 3
I'm already in touch with them, and they already run the diagnostics. Actually, they made a sw update thinking that it was the problem, but the issue re-appeared after 1 week. (I'll go back to them) The problem is that the issue is intermitent. It'll be extremelly dificult to bring the car at the moment the issue is present. If anybody has another info, it'll be much appreciated. Thanks to all in advance! Jose |
08-12-2021, 09:11 PM | #4 |
Rep 399
I drove in heavy rain during a recent trip and that same message was displayed several times as the sensors were blocked. I think it was the front sensor, but it’s hard to tell for sure. I cleared it each time without any issue. It sounds like you have a faulty sensor or loose wire, and it’s causing intermittent detection problems.
08-17-2021, 04:20 AM | #5 | |
Rep 3
Jose |
08-22-2021, 08:30 AM | #6 | |
Rep 29
Called BMW and they said probably not worth my time to come in. They could try scanning but couldn't do much if the issue had cleared. Diag codes had all cleared as well (in iDrive at least). Turned around and haven't had the issue since . |
08-25-2021, 11:26 AM | #7 |
Rep 110
I had the same problem. My audio cut out, driver assistance cut out and then the car would go off with a loud bang every couple of minutes. It was the RAM (Radio Audio Module) that was issue.
