11-27-2023, 06:02 PM | #1 |
Rep 189
Drives: 2020 M340i X-Drive
For anyone interested in an Active Autowerke Catted Downpipe...I highly recommend it! Here's a video I put together showing the difference between stock and then adding the downpipe. My car is a 2020 (Stock Tune) so it will be louder than the 21+ models.
https://youtu.be/oUSoL4VAsxg?si=3y0kWANa6qyaeRCS https://youtube.com/shorts/etW1Rf_Fd...dvX5cgt9D8yS3z
Youtube: DanVilla
IG : @dan_villa83 |
11-27-2023, 11:01 PM | #2 | |
Rep 24
11-28-2023, 10:55 AM | #3 |
Joint Chiefs of Staff
24282
Rep 190,975
Thank you for sharing
11-29-2023, 05:58 AM | #4 |
Rep 189
Youtube: DanVilla
IG : @dan_villa83 |
11-29-2023, 07:31 PM | #6 |
Rep 189
They are the only company that guarantees no CEL. That's why I went this direction. I haven't had an issue yet and don't expect to but it's only been 5 days since the install.
Youtube: DanVilla
IG : @dan_villa83 |
11-30-2023, 10:16 AM | #7 |
Rep 69
Sweet car!!
Been waiting for mine to ship since it was ordered back on the 17th. The wait is killing me but looking forward to getting this installed on my 2021 w MPE. |
11-30-2023, 02:56 PM | #8 | |
24282
Rep 190,975
the downpipe will trigger the check engine light once or twice during the break in cycle. But after that you are set. in the rare occasion that the CEL comes back, Active will replace the downpipe right away. If the CEL is a concern, the active autowerke downpipe is the best option in my opinion.
Seba77W401.00 |
12-01-2023, 05:23 PM | #9 |
Rep 153
I just got mine in today and tried to install it. Everything was going smoothly until it was time to connect the AA DP to the exhaust. I cannot for the life of me get it to fit back into the OEM exhaust. Do you have any tips for getting the AA DP to fit back into the exhaust? Did you mount the DP on the bracket first or did you fit it snug into the exhaust, and then mount it to the bracket and turbo?
Really appreciate the help. |
12-01-2023, 06:42 PM | #10 | |
Rep 189
Youtube: DanVilla
IG : @dan_villa83 |
12-01-2023, 07:14 PM | #11 |
Rep 153
12-01-2023, 07:18 PM | #12 |
Rep 189
Is the clamp all the way loose? If so you can try some kind of lubricant spray like wd40 or liquid wrench to help get the pipes seated. But it will take a good 10 min or so to burn it all off afterwards.
Youtube: DanVilla
IG : @dan_villa83 |
12-01-2023, 09:52 PM | #13 |
Rep 153
The clamp is completely loose. I also tried WD40 and still was not able to get the down pipe into the midpipe... I'm losing hope lol I'm thinking of taking the car to a shop and have them do it for me. Hopefully I can drive without them actually being connected.
12-02-2023, 12:24 AM | #14 | |
Rep 547
I saw on either another post or YouTube video where someone had a similar problem and they used an exhaust pipe spreader to open it up a bit to get it to fit. You can try that option I guess. https://www.harborfreight.com/exhaus...rge-59698.html
2014 435i xDrive M-Sport, Fabspeed cat, Active Autowerke axle back, CTS Turbo intake, ER charge pipe, ER Competition Intercooler, MHD Tuning Stage 2+
12-02-2023, 05:53 AM | #15 | |
Rep 66
dancing__narwhal141.50 |
12-03-2023, 07:32 PM | #16 |
Rep 71
I had to chamfer the edges of the OD of the outlet on the downpipe using a file to get it to slide into the stock mid pipe. It was very difficult to get the outlet to slide into the mid pipe even after doing that. I'd say it was the hardest part of the install for me, laying in the driveway with the car on ramps.
12-03-2023, 10:37 PM | #17 | |
Rep 153
12-03-2023, 10:41 PM | #18 | |
Rep 153
12-04-2023, 10:33 PM | #19 | |
Rep 69
I just installed mine a couple days ago and was having the same challenge. What worked was loosening from the DP vclamp and the bracket so we could get more play affecting the insertion angle from the DP. After battling for over an hour this did the trick right away. Good luck! |
12-04-2023, 10:49 PM | #20 |
Rep 1,129
Guaranteed no CEL. I’ve had my AA catted dp installed for about 20k miles and no cel. I think it sounds phenomenal paired with my MPE. Installed on a MH MY22.
12-05-2023, 06:48 AM | #21 | |
Rep 66
It is very loud when cold starting but when idle settles down it seems okay, I am not detecting any leaks. |
aci439.50 |
12-05-2023, 10:04 AM | #22 | |
Rep 153
