Technical Topics iDrive, Nav, Phone, Audio, Video, Cameras, Electronics BMW New Design 12V Power Ports = FAIL
      04-07-2023, 01:47 PM   #1
1QuikWS6
No 55mph
1QuikWS6's Avatar
1626
Drives: F32 435ix MSport
Angry BMW New Design 12V Power Ports = FAIL
So I purchase a new Escort Redline 360C RD, ordered it with the 12V cigarette style SmartCord Power Adapter.
Typically like to use these over hardwire since I like my RD mounted near bottom of windshield, don't want the hassle of HW, and it makes for quik n EZ swap between cars.
Come to find that the RD power plug gets no power from the center console 12V power port by cupholders Yet when I try in my 2015 435 it worx fine just like my other Passport Max RD, but neither will work in the 22 M440i
At 1st I was thinking bad fuse, but upon inspection of the port the internals appear slightly different in the 440 than the 435 - mostly down @ the bottom where it appears to neck down smaller than main bore = BMW decided to change out the design of their power ports in the newer cars & the cigarette style adapters that have been the same & worked in ANY car since the beginning of time will no longer push all the way in to make contact
All I can say BMW is WTF?
After a call to Escort the tech confirms the above. I ask if I can use the USB port that is directly in front of the power port, but see no USB power cable available?
Answer is not directly, BUT you can pick up a USB A Male to 12V Car Cigarette Lighter Socket Female Converter Cable (8W Max) for $6.59 that they recommend from Amazon to do the trick
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
So for any of you running into the same situation, that cable would be a quik/cheap solution (at least for Escort RD as IDK power draw of other makes)
In the meantime, I'm gonna order an OEM power port that is for a 2015 435 & see if I can't simply swap it into the M440, hoping for PnP as they look exactly the same on exterior - just different interior
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
      04-07-2023, 02:18 PM   #2
upstate650
upstate650's Avatar
Drives: 2014 650xi Gran Coupe Msport
2020 BMW M340xi  [0.00]
Answer is not directly, BUT you can pick up a USB A Male to 12V Car Cigarette Lighter Socket Female Converter Cable (8W Max) for $6.59 that they recommend from Amazon to do the trick [...]
It’s a common problem. Take it to the dealer and they will swap it out under warranty. They have a new version of the power port that works fine.
2014 BMW 650xi Gran Coupe Msport Black Sapphire Metallic on full black merino leather. 20" M5 343M wheels for summer, 20" 373 wheels for winter with Nokian Hakkapeliitta 8 studded snow tires. M6 CP exhaust with M6 Diffuser and ///M Performance carbon fiber finisher. Mission Performance stage 1.5 and transmission tune.
1QuikWS61625.50
      04-07-2023, 07:48 PM   #3
1QuikWS6
No 55mph
1QuikWS6's Avatar
1626
Thanx for the heads up, 1st I heard of this issue
I'll give the dealer a call
      04-08-2023, 09:08 AM   #4
upstate650
upstate650's Avatar
If you search this site you will find many threads on it. Not sure when they switched over to the new design in production. There is a BMW TSb on this issue you can search for.
