09-17-2023, 07:55 AM | #2 |
Rep 361
Minimal unless you have a tune. Even on a tune the gains between sport cat and catless will be negligible. You may see small gains with a custom tune to take advantage of not having a cat. If you have the cheddar go catted, it will help save the atmosphere and your nose.
Present: 2014 f30 328xi MSport, 1992 VW GTi VR6 swapped
Past: 2010 335i 6 speed; 2008 VW GTi stage 2, 2004 Subie WRX FBO, 2003 20th Anny VW GTi FBO |
ekinnee15.00 |
09-17-2023, 10:35 AM | #3 |
Joint Chiefs of Staff
24457
Rep 191,382
There is no power difference on stock cars between catless and high-flow catted.
The catted option is better for the stock turbo; it's louder than stock but not raspy and has a deeper mid-range tone. Catless is louder than both but also raspy and generates a fuel smell. the only pro for catless over high flow catted is the cheaper cost.
1QuikWS61623.00 Randy Johnson401.50 |
09-17-2023, 03:26 PM | #4 |
No 55mph
1623
Rep 8,479
And catless is illegal and car won't pass emissions in any state that requires a IM test
Never had any issues on both my BMWs with AA hi flow catted DP installed (guaranteed no CEL & to pass emissions here in PA) that I purchased thru Mike @ XPH
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
09-17-2023, 03:44 PM | #5 | |
Rep 37
09-18-2023, 12:08 AM | #7 |
Rep 1,175
Neither. AA Catted Downpipe guaranteed no cel and is of top notch quality.
09-18-2023, 11:35 AM | #8 | ||
24457
Rep 191,382
If the CEL is a concern, get the Active Autowerke If it's not, CTS or MAD catted will get the job done.
09-18-2023, 03:28 PM | #9 |
Rep 5,071
The difference will depend on the cat you choose. Our catless and catted are very similar in hp because we use a 200 cell which is extremely high flow. The only downside of the 200 cell is it will not pass emissions and will throw a cel.
However if you are tuned or don't live in a state where they test and you want catless but do not want the smell our 200 cell is the ticket. 200 cell- https://mad-us.com/mad-b58-4.5-catte...chassis-supra/ 4.5 inch- https://mad-us.com/mad-b58-downpipe-...chassis-supra/ 5 inch- https://mad-us.com/mad-2052-mad-bmw-...40-m440-supra/
09-25-2023, 02:05 PM | #10 |
Rep 14
I installed the AA catted on my 2023 M440i and it significantly increased sound and throttle response with the stock exhaust. Worth the price as quality and flow is excellent and no CEL. The stock downpipes on the B58 are very restrictive. This should be the first item to swap before any exhaust upgrade.
09-26-2023, 08:42 AM | #12 |
24457
Rep 191,382
lots of customers have a locked DME and they use a piggyback which does not hide the check engine light.
imported_nick83.00 |
02-18-2024, 09:20 PM | #13 | |
Rep 1
02-19-2024, 09:39 AM | #14 |
Rep 5,071
02-19-2024, 06:54 PM | #15 | |
Rep 472
If you have to spend money on a DP that won't throw a cel - which is a number of times more expensive than a (higher-flowing) 200cell or catless DP - it just makes no sense at all to me. My strong recommendation is just stay stock. If you need a Femto unlock - I'd STILL do that and get a 200cell or catless DP. Works out about the same cost or a bit more than just a DP which won't throw a cel (which won't flow quite as good as a 200cell or catless). If you are doing it for sound - much cheaper ways to get your exhaust louder - like a muffler delete or open airbox etc. |
02-20-2024, 11:12 AM | #16 | |
24457
Rep 191,382
I get it if it's not for everyone, but I can see the reasoning for getting downpipes with no CEL. That's what i did on my car because it made the most sense.
02-21-2024, 05:29 PM | #19 | |
Rep 1,175
For ex. AA catted DP with MPE = no drone
phanamous19.00 |
02-22-2024, 01:16 AM | #20 |
Rep 46
02-22-2024, 04:37 AM | #21 | |
Rep 13
02-22-2024, 04:45 AM | #22 | |
Rep 472
You simply can't get more power with just a dp because fueling, ignition and boost are all the same. It's just a bit quicker spool up (slightly less turbo lag) with a dp. As for sound, it will be slightly louder than stock. The cats act like a muffler and so with a higher flow dp you get a bit more volume. Most volume is with a catless, next loudest is a 200 cel and then 400 cel is a little louder than stock. I'd say a 200cel is maybe 10-15% louder on startup (only in sport modes) and WOT than stock. Normal driving can hardly tell any difference. |
