Technical Topics Cosmetic and Lighting Modifications (exterior & interior) OEM g80/g82 mirror caps on g20
      07-25-2021, 02:20 PM   #1
StevenDS85
I ///M Fan
Drives: BMW 330i M-Sport
My next little project would be to replace my g20 mirror caps with M3/M4 OEM mirror caps (no replicas as they are not identical). I’m also planning to paint them in dravit grey. Couple of questions:
Will they fit on the G20?
What are the part numbers? ( I have found below numbers, but not sure if they are correct …)
51-16-9-500-711 (left)
51-16-9-500-712 (Right)
      07-25-2021, 02:37 PM   #2
StevenDS85
I ///M Fan
Two pictures added
      07-26-2021, 03:44 AM   #3
helmet91
helmet91's Avatar
Netherlands
298
They're only $77 each!? I was just going to order the normal G20 mirror caps painted in gloss block from IND for quite a bit higher.
Schmiedmann https://www.schmiedmann.com/en/produ...1-16-9-500-711 says they're for the G80/2 - so your numbers are definitely good.
I don't see why they wouldn't fit a G20. I'll reach out to a couple places in the States to see what I can find.
      07-31-2021, 01:43 PM   #4
StevenDS85
I ///M Fan
I indeed have ordered them via Schmiedmann. Not the quickest webshop, hope to receive them somewhere end of next week. Painting them in Dravit will cost 77€ (including VAT).
helmet91297.50
      08-06-2021, 05:42 PM   #5
StevenDS85
I ///M Fan
It looks like above two part numbers will not do. The gloss black support ring around the mirror glass is also different. This means the following two extra parts are also required:
51-16-8-746-847 Side-view mirror supporting ring, gloss black L.-side
51-16-8-746-848 Side-view mirror supporting ring, gloss black R.-side
Let’s hope that the mirror glass and mirror base are the same for G80 vs g20.
Similar installation guide:
https://g07.bimmerpost.com/forums/sh....php?t=1737021
Note: part numbers are for a left hand drive car!
helmet91297.50
      08-09-2021, 03:32 AM   #6
helmet91
helmet91's Avatar
Netherlands
298
Did you see this site? Here's the diagram and part numbers: https://parts.bmwnorthwest.com/a/BMW...r/51_Z464.html
The 'housing lower section' appears to be for the G2# and G8#: https://parts.bmwnorthwest.com/p/BMW...167498203.html
Here are the glass options for the M3: https://parts.bmwnorthwest.com/a/BMW...s/51_Z393.html
Looks like they matchup with other G2# cars?
      08-09-2021, 04:26 AM   #7
helmet91
helmet91's Avatar
Netherlands
298
Granted they're in the US, but I just saw this too: https://g20.bimmerpost.com/forums/sh...ghlight=mirror
      08-09-2021, 09:08 AM   #8
helmet91
helmet91's Avatar
Netherlands
298
I think I'm going to order the caps and frames from https://www.baum-bmwshop24.de/ - it's about 180EUR shipped.
      08-09-2021, 09:21 AM   #9
StevenDS85
I ///M Fan
Caps are delivered from Schmiedmann. Support rings are on order with baum-bmwshop24. Caps are also handed over to a paintshop. Should have them on my car by beginning next week. Thanks for guidance and confirmations @helmet91!
helmet91297.50
      08-18-2021, 12:29 PM   #10
StevenDS85
I ///M Fan
Driver side mirror has now the OEM M3 mirrow. Small issue with passenger blind spot connector. I can’t see how to disconnect this one. Any hint?
Edit: it’s kind of a rubber plug which can just be disengaged by pulling on the cable cord with some force.
      08-18-2021, 02:22 PM   #11
StevenDS85
I ///M Fan
Et voila, M3 mirrors installed on my G20. Some takeaway for forum members who are planning this mod:
-Most difficult part was to remove the fragile mirror connectors. Depending on the mirror features you can have up to 4 connectors. In my previous post courage was needed to just pull it out with some force.
- removing the mirror engine/rotor was not needed (and difficult to remove as there are also hidden clips at the back). The support ring can be removed like kind of a puzzle, wiggle it around and find a way to remove it.
All in all it took me 2 hours to replace both mirrors. Very happy with the end result.
Appreciate 8
      10-02-2021, 02:47 AM   #12
Stevie_B
Stevie_B's Avatar
11
Drives: M340i X-Drive Touring (due May
Oh man, really want to do this on my G21 in Dravit too. Just need to find places that offer the correct parts for right hand drive versions.
Did you just use a local paint shop once you had the parts in hand?
      10-03-2021, 07:07 AM   #13
StevenDS85
I ///M Fan
Hi @Stievie_B, I indeed brought the mirror caps to a local paint shop (actually my local BMW dealer). For the RHD parts it’s mostly just one partnumber up or down.
      12-13-2021, 06:33 PM   #14
TTG
TTG's Avatar
Drives: M340
I am bumping this up as it appears all MX40 cars will come with M Style mirrors.
Does anyone on know the part numbers for the OEM G20 M Performance style part numbers in black if they come pre-painted
It would be great if BMW offers them in piano black.
I am not interested in anything in carbon fiber.
Thanks.
      01-30-2022, 09:39 PM   #15
JSaid
JSaid's Avatar
Drives: 2022 BMW M340i xDrive
I've been considering this for my M340. Anyone have experience with the ind retrofit kit?
https://ind-distribution.com/collect...g2x-3-4-series
      02-22-2022, 06:19 AM   #16
DenHaag3er
Drives: BMW M340i
Will the mirror glass from the m340i work with these caps?
      02-22-2022, 06:29 AM   #17
Chubbiejones
Chubbiejones's Avatar
Drives: 2020 BMW M340i
See link:
M340i Retrofit G80 mirrors - Yes or No https://g20.bimmerpost.com/forums/sh....php?t=1897840
      02-22-2022, 06:59 AM   #18
StevenDS85
I ///M Fan
Yes, your mirror glass remains intact, no need to replace them.
