2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK Active Cruise Control now in the UK Connected Drive Store
      12-02-2021, 05:38 PM   #1
Chris_1128
Drives: 330e
Hi
I see Active Cruise Control with Stop & Go function has finally been added to the UK connected drive store as an aftermarket software/license purchase. (Its been available in Europe for some time).
Does anyone know if the current 3 series, as being produced for the UK at the moment has the hardware for this?
(I believe owners who have there car registered with connected drive can check by going to the connected drive store either online or in the car).
I had originally order my car with the full driver assistance package, which is a more advanced version of the above, but it was unfortunately removed due to the semi conductor shortage.
If I can add Active Cruise after I get the car, that would at least make up for the touch screen and reversing assistant I've just been told by BMS won't be on it now
From the BMS connected Drive website:
"The hardware required for this feature comes ready-installed in your vehicle when it leaves the factory. This gives you even more flexibility when it comes to configuring your vehicle after it has left the production line."
https://www.bmw.co.uk/en/shop/ls/cp/connected-drive
      12-03-2021, 01:19 AM   #2
ramparts
Drives: M40i
Originally Posted by Chris_1128 View Post
Hi
If it's showing up for you after you log in, then your car has the right hardware for it.
Otherwise it would say not available for this vehicle
      12-03-2021, 02:26 AM   #3
verysideways
Lateral grip estimator
verysideways's Avatar
957
Drives: i4, M2
Mine isn't showing it as available for my car.
Perhaps because I don't have one of the packages with the relevant hardware?
'20 BMW M2
'23 BWM i4 Mora
'10 Porsche 997
'02 Morgan Aero 8
http://petrolhead.tours
      12-03-2021, 03:51 AM   #4
SilverGrey
124
Drives: BMW 330i M Sport
The same here.
Current: G20 330i M Sport
Previous BMW's:
F36 420i Gran Coupe M Sport; Z4 Coupe 3.0si M Sport; E46 325i Sport coupe;
      12-03-2021, 04:20 AM   #5
4monks
95
Drives: 2021 BMW M340i xDrive MHT G20
Unless you have front radar, you can't have active cruise. The steering wheel cruise buttons are different also.
      12-03-2021, 05:30 AM   #6
paulockenden
572
Drives: 330e xDrive Touring
I don't understand how it would be possible to have the front radar fitted WITHOUT the vehicle having ACC. Surely that's the trigger for fitment when the car is built?
      12-03-2021, 06:06 AM   #7
johno
47
Drives: G20 M340ix
Well, it depends. I have worked with expensive test systems where many options are factory fitted, even if not specified, and available as a licensable option post purchase.
Given that BMW are offering these upgrades, it seems that automotive manufacturers are moving in this direction.
      12-03-2021, 06:58 AM   #8
marksandygill
marksandygill's Avatar
240
Drives: G20 320d xDrive F22 M240i
I'm guessing that as certain aspects of the Driving Assistant Plus weren't available in the UK (until now), people were buying the Tech Plus Package and had the Radar installed but couldn't use it?
Makes you wonder if BMW were charging for it when it didn't work and now charging for it again?
Current: G20 320d xDrive F22 M240i
Previous: Many, many boring BMWs, 116d (F20), 220d, M240i (F22), 318d (F30), 320d (F30 and G20), 330e (G20), 420i (F32), 420d (F32), 435d GC (F36)
      12-03-2021, 07:54 AM   #9
225
Drives: 340i
I agree this makes no sense unless from now onwards all cars have the hardware and buttons on the steering wheel as standard. Most cars must have a radar of sorts for collision prevention and I'm sure mine senses cars in front when deciding to use or disengage the MHT or not.
I do not have ACC buttons however so it's not an option for me on the site and if I did have it wouldn't be anyway surely as I already have it?!
      12-03-2021, 08:48 AM   #10
Funboy78
Drives: ‘72’ BMW M340d G20 LCI
Was thinking exactly the same, without the steering wheel button I don’t see how it can be purchased after and work the same way?
Just checked the shop to be sure, not available for mine….. sadly.
Funny you say about pre sense. I wondered why mine would feel like it’s engine braking when following someone and slowing down, almost feels like the car is auto braking itself. Glad it’s not just me who has noticed.
      12-03-2021, 09:00 AM   #11
Talisman77
Talisman77's Avatar
151
I had a look, even though I already have ACC (w/ tech+ pack) from when I got the car - not available for me, so doesn't seem to add anything "additional" either.
jdc090724.50
      12-03-2021, 09:58 AM   #12
paulockenden
572
DAP has been available for ages though. It came as part of tech plus (and before the plus packs it was available separately), and included ACC.
P.
      12-04-2021, 07:39 AM   #13
Keith_C
Keith_C's Avatar
179
Drives: BMW 330i M Sport Plus
DAP was available from the onset as far as I'm aware and only cars that had DAP had the correct button on steering wheel and sensor on the digital cockpit (The easiest way to identify DAP cars) so unless all newer cars come with the ACC button as standard now, then you either have it through DAP or can't get it anyway or there's a different method of activation.
The only option my car doesn't have is DAP and it's not available for mine now, so be interesting to see what cars it is available for.
      12-04-2021, 09:11 AM   #14
Beemer5to3
907
Drives: G16 840i
There are some cars that do have the necessary hardware for ACC, including the correct steering controls, but don't actually have ACC - new X5's for example. Assume the availability in the store is for those.
      12-04-2021, 10:20 PM   #15
4monks
95
The configurator shows the buttons change depending on whether you select a package with DAP or not on the X5.
      12-05-2021, 04:58 AM   #16
Beemer5to3
907
Drives: G16 840i
I wouldn't pay too much attention to what the configurator shows - it's never 100% perfect in the images.
Below is a pic of a current new X5 for sale - you can see the buttons for the distance control are there, as it the forward facing radar sensor, but it only has "Cruise control with braking function" as standard.
The DAP equipped cars would have slightly different buttons again, as where the "LIM" button is on this would have "Mode" for switching between just Adaptive cruise and Assisted Driving modes.
Not like BMW to complicate matters…god help people looking at used purchases with all of the cars going out with odd specs at the minute because of the semiconductor issues!
      12-07-2021, 05:08 PM   #17
Chris_1128
Drives: 330e
The BMW connected drive team have told me they have been looking in to whether I will be able to order it for my new 330E which has now gone to build.
From what I can gather, some cars will include the required hardware.
They're unable to currently confirm if my car will have the hardware until its actually been built, but it possibly will do.
I'm assuming new cars will come with the hardware, but I guess the semi conductor shortage may throw a spanner in the works.
      12-19-2021, 01:10 PM   #18
btfbmw
Drives: 2021 BMW 330e xDrive
Can this car be "upgraded" to have adaptive cruise control through the connected app after purchase, even though the buttons are different?
      12-19-2021, 01:51 PM   #19
Beemer5to3
907
Drives: G16 840i
The buttons aren't different? It has the +/- distance controls already on there, as well as the radar on the front, so I'd assume it could be upgraded.
