2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK Dipped beams causing dazzle /glare?
      12-05-2021, 11:55 AM   #1
330 bimmerman
Ireland
Drives: 330e xdrive
Hi as we're well into winter driving ,after getting 2021model car late summer I am frequently getting flashed by on coming traffic when in dipped beam . Maybe this a common issue with modern cars with increasingly stronger lights? But have others found this issue and what options for adjustment are available... I dont have laser lights so just standard lights.
Thanks
      12-05-2021, 12:11 PM   #2
Charlie (Wessex)
Drives: G21 M340i
Found mine were too far dipped. Raised them a lot, and even though I wasn't being flashed, I knew they were too high. Sign posts on the motorway were far too illuminated. Think I'm about right now, if still a wee bit too high. Doesn't light up on coming cars though, nor the one in front.
Get an allen key out (and try not to drop it, which I did numerous times but got a magnet to fish it out). Clockwise drops them.
      12-05-2021, 01:40 PM   #3
330 bimmerman
Ireland
Drives: 330e xdrive
Ok will check out or see dealer for checking correct settings.
      12-05-2021, 02:45 PM   #4
Charlie (Wessex)
Drives: G21 M340i
It's easy to do yourself tbh. Just find a level that people don't flash you and you can still see the road.
I presume lights aren't set for driving on the right
      12-05-2021, 03:15 PM   #5
paulockenden
575
Drives: 330e xDrive Touring
I love how the visibility pack does this. I was following someone the other day and the road was lit up all around them but you could see on the road around them they they were driving in an unlit box. Same for oncoming traffic. You can use full beam on a really busy road without blinding anyone. Magic!
I think it’s friendlier to other traffic than normal dipped.
      12-06-2021, 12:28 AM   #6
Talisman77
Talisman77's Avatar
151
Hard agree. I've only had a couple times where foliage slightly obscures say a lorry's lights but obviously the cabin is above and getting the full force of the LLs but other than that I've found it incredibly smooth with HBA and the way it tracks is just great.
      12-06-2021, 08:09 AM   #7
330 bimmerman
Ireland
Drives: 330e xdrive
I will check setting on idrive but dont think so
      12-06-2021, 08:11 AM   #8
330 bimmerman
Ireland
Drives: 330e xdrive
Is this the HBA add on you refer to or something only part of visibility pack, reason is i was considering adding the HBA upgrade as available to download for car I think for 160 or so?
      12-06-2021, 10:06 AM   #9
paulockenden
575
I'm pretty sure the £160 add-on doesn't give you dancing headlight, it just auto-switches between dipped and main beam.
      12-06-2021, 10:38 AM   #10
xenon
xenon's Avatar
England
1397
Drives: 2021 G21 330i M-Sport
Yes just switches between main and dipped, the dancing lights are only part of laser lights
      12-06-2021, 01:31 PM   #11
330 bimmerman
Ireland
Drives: 330e xdrive
Ok cheers guys.
      12-07-2021, 03:31 AM   #12
Froggie401
Drives: BMW G20 330e MSport
Thanks
I'm the same. I have an early 2020 build. Standard lights and I also keep getting flashed by oncoming cars. I had thought that maybe the dipped lights are very bright.
Lets us know if you get yours adjusted and what the outcome is.
Cheers.
      12-07-2021, 03:41 AM   #13
xenon
xenon's Avatar
England
1397
As Charlie said at the start, just turn the adjust half-a-turn if you're getting flashed - job jobbed.
Ian
      12-15-2021, 09:02 AM   #14
330 bimmerman
Ireland
Drives: 330e xdrive
Cheers.
Update to this is I went to local non BMW garage and got lights checked - Mechanic showed me that the lights were height level Ok but were directed too much to right [i.e on coming traffic!] This was not because of Idrive setting as this is in default LH drive setting and actually checked this with him by changing setting to RH drive and could see movement again.
So it appears my 'new' car had light settings incorrect. Mechanic corrected lights .
