02-18-2024, 02:57 PM | #1 |
Rep 53
AA catted downpipe CEL
Hey guys, just installed an AA catted downpipe on my 21 M440ix and drove it for around 200 miles before I had a CEL appear. Pretty disappointed with that, but I checked the code and I’m showing P0420. Downpipe was purchased used so it’s gone through its break in period and I had a new gasket put on during it’s install.
Can anyone throw a suggestion as to why it’s coming on? Car is driving fine but it’s annoying that I spent the extra money to avoid the CEL in the first place |
02-18-2024, 04:04 PM | #2 |
Rep 597
2 things I would recommend
1) carefully go over the install and make sure there are no leaks at the coupling locations 2) if you floored the accelerator before the cats warmed up; try warming up first. The CEL will go away if it’s something like you did #2 once…. Otherwise, see if AA can advise you. I’ve had 2 separate units in 2 separate cars and only had the #2 issue once on a very cold day. |
Whysitcold9.50 |
02-18-2024, 07:18 PM | #3 | |
Rep 53
02-21-2024, 05:21 PM | #4 |
No 55mph
1622
Rep 8,477
I have 2 AA catted DP on my BMWs. 435 and M440. Never a CEl and no issues. Passes insp here in PA every yr.
AA has a great warranty and guaranteed no CEL, but doubt they will be any help since you bought the DP used 2nd hand...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
02-21-2024, 05:26 PM | #5 | |
Rep 1,151
As others have suggested, I would also contact AA for any suggestions they may have.
Whysitcold9.50 |
02-22-2024, 09:20 AM | #6 |
Rep 198
Just checked AA's website, and warranty doesn't transfer owners. Here's what warranty covers for new DPs:
"Covered by 5 Year / 50,000 Mile Warranty (on shell and tube ends) and 2 year / 25,000 Mile Warranty on the Catalytic core" |
02-22-2024, 10:35 AM | #7 |
Joint Chiefs of Staff
24369
Rep 191,194
You should never buy a used active downpipe.
1- you lose the warranty which is the most important part of this downpipe with the CEL 2- you don't know if the downpipe is good. Let me explain. if a customer gets the active autowerke and it triggers the check engine light, they file a warranty with us or active, and we send them a new downpipe. he might have sold you his original downpipe knowing fully well its defective.
Whysitcold9.50 mondayze498.50 |
02-23-2024, 12:33 AM | #9 | |
Rep 962
02-23-2024, 09:07 AM | #10 |
Rep 550
Sounds good keep us posted if it comes back.
2014 435i xDrive M-Sport, Fabspeed cat, Active Autowerke axle back, CTS Turbo intake, ER charge pipe, ER Competition Intercooler, MHD Tuning Stage 2+
Whysitcold9.50 |
02-23-2024, 12:00 PM | #11 |
Portimao Blue G22
42
Rep 38
I’ve heard on the AA catted DP that your car can throw a CEL in the first few hundred miles as your car adapts. Your car needs to learn and adapt to the new stuff and I guess there’s a small break in period for that. In the instances I’ve heard about, once you clear the code after then first time it won’t come back. This is the info they were given directly from AA for example if you bought new from them they will tell you this is common and to clear the code and should be good. Then if it still comes back they will exchange it. This is all info I heard from others not something I have dealt with personally so can’t say for sure it’s 100 percent accurate but have heard the same from multiple people so pretty confident it’s accurate. Wait it out, drive her hard and if it comes back I would still give active a call and see what they say. While you might not have the warranty I’m sure they will still be happy to give some suggestions to help.
Whysitcold9.50 |
02-24-2024, 10:59 AM | #12 | |
24369
Rep 191,194
02-24-2024, 12:41 PM | #13 |
Portimao Blue G22
42
Rep 38
[QUOTE="mike@x-ph.com;30931418"]you are correct that the downpipe will trigger the check engine light during the first 100 miles. but he bought it used, so it has already gone through that cycle.
Ahhh gotcha…. Appreciate ya. I always thought it was the car itself that had to learn and adapt due to the different air/fuel ratios. The way I was explained was that it’s the computer in the car not the actual downpipe itself that had the break in period. Again, not my field of expertise as I’m just going on what others have told me… good luck to OP I hope CEL stays OFF for him! |
Whysitcold9.50 |
