06-12-2023, 08:51 PM | #45 | |
Rep 7
Send it back to your dealer, and be stern about it. Unfortunately, the tie rod recall didn't fix ours. Auto Bavaria finally decided to replace the entire steering rack this time. Let's see... |
06-12-2023, 10:34 PM | #46 |
Rep 52
😣😣😣…is yours the 2023 lci model as well? Didn’t hear much of same complain from friends having the 2021-22 model of m340
06-14-2023, 07:01 AM | #47 | |
Rep 7
I found the exact same sound in another 2021 pre-LCI M340i and a 2020 pre-LCI 330i. I'm a detailer so I have access to all sorts of BMWs. Just got a call from AB (Ara Damansara) today. They finally replaced the entire steering rack, another set of tie rod ends, and cross-checked all suspension components. Will report back. Fingers crossed Last edited by Thisguy; 06-14-2023 at 07:06 AM.. Reason: Missing words |
06-18-2023, 06:38 AM | #49 | |
Rep 52
I just sent mine in to AB- SG besi 2 days ago. They said they will try changing the tie-rod first but not the steering rack….will see. Can’t enjoy the car yet 😪 |
06-19-2023, 09:00 PM | #50 | |
Rep 7
Same knocking sound all over again. Yes AB claimed a change of the steering rack and tie rods. Fingers crossed for you. Let's see... |
06-20-2023, 02:44 AM | #51 |
Rep 52
Damn, that’s bad for a new car experience. Such a hassle going back and forth. Will update as well. Thanks
06-22-2023, 08:17 PM | #52 | |
Rep 160
06-29-2023, 12:52 AM | #53 | ||
Rep 52
Has anyone gotten this issue fixed actually? |
07-08-2023, 06:19 PM | #55 |
Rep 1,114
How long has that guy been using his car post link replacement?
07-09-2023, 12:53 PM | #56 | |
Rep 7
I’ll be taking my car back to the dealership at the end of the month because my moonroof is crackling like crazy again so I will report back. |
07-13-2023, 05:29 PM | #57 |
Rep 4
I have same problem back after changing the left and right tie rod. I hear the noise only at low speed when passing uneven road surface. Did the problem solve after changing the sway bar? Thanks
07-14-2023, 07:43 AM | #58 |
Rep 47
Same issue - knocking sound drivers side slow speed on flat surfaces. But goes away after driving 15-20mins. I haven't done anything to fix the issue and the car is basically bone stock.
M340i 2020 29500k Miles |
07-14-2023, 08:19 PM | #59 |
Rep 52
Did u have the issue only recently? Mine or many had the issue since new 😤😤
07-24-2023, 10:31 AM | #60 |
Rep 28
I still haven't been able to get my car into service for this because they have so few loaners at the moment, but I talked with someone at BMW NA and registered the issues. I'd recommend filing a complaint so they have a good sense of how widespread this issue seems to be.
08-06-2023, 12:55 PM | #63 |
Rep 41
After changing just the left tie rod, clunk was back after just a couple of miles. Went back to the service and they changed the right one too. Now the car has been dead silent for +1000miles, two weeks after replacement. Hope it will stay that way.
CSBM52721.00 |
08-07-2023, 04:55 PM | #64 |
Rep 4
I currently have a 2023 m340 experiencing the same clunking noise over bumps and uneven roads surfaces. I also notice the clunk reversing over imperfect roads as well. Took it over to the dealer and got my struts replaced but the problem was still there. Currently going back and fourth to the dealer trying to get them to do more but they claim everything is find and they can’t replicate the sound.
10-18-2023, 05:12 PM | #65 |
Rep 1
Knocking M340i
I also have a 2022 M340i with a knocking noise on the driver's side that I noticed within a month of having the car. I've brought it in 11 times, about half of those times they told me it was in my head.
Now, after a year and a half of owning it, they still haven't fixed it. Currently they're replacing the tie rod. They've already replaced two control arms and bushings. I'm not confident they'll fix the issue. At what point can I force a lease trade in? It's a waste of time and stressful. I'm over it. |
10-20-2023, 07:35 AM | #66 |
Rep 106
My 23 m340 makes loud creaky squeaky noise when turn steering wheel close to lock on parked or very slow speed. No knock sound on bumps. Dealer says they will replace tie rods today.
