12-15-2022, 02:59 AM | #1453 |
Rep 102
Updated to 11/2022.xx, noticed the cluster and the HUD have much better font now. The speed limit in the HUD now turns the speed red instead of flashing the speed limit sign. Other than that I didn’t notice any other changes.
12-15-2022, 05:25 AM | #1454 | |
Rep 2,269
( note 40i/d have a different font normally to the other models, if you have something else ) |
12-15-2022, 05:20 PM | #1455 |
Rep 102
From 07.2021.50. The default font on that istep is very hard on the eyes. They changed the font to make them bigger and easier to read it seems.
12-16-2022, 01:47 AM | #1456 |
Rep 2,269
12-17-2022, 01:12 PM | #1457 | |
Rep 488
12-18-2022, 11:38 PM | #1458 | |
Rep 488
OK, so "07" must have been a typo...
12-19-2022, 12:47 AM | #1459 |
Rep 792
I have a 2020 M340i and the dealer did an update to fix an issue.
After the update I have noticed that all the privacy options are no longer in the iDrive menu. There used to be a whole section on this whereby you could switch on/off what information is shared including a blanket option to turn everything off. There was also another section on video recording and permissions on that. All these are now gone. Has anyone else noticed this and do you know how you can now control what information is shared etc. I know for many/most don't care about this, but for those that this is important I am interested to know what can be done. |
12-19-2022, 11:45 AM | #1460 |
Rep 488
Sounds strange. See if you have access to them in the My BMW app (if you use that.) The same selections seem to be in there in settings privacy (but I'm on older iDrive version.)
12-19-2022, 07:59 PM | #1461 |
Rep 792
Yes mine were there in the older version - newer version - gone! All the settings relating to privacy are gone.
12-19-2022, 08:29 PM | #1462 |
Rep 1,010
2022 330i M-Sport, delivered with 11/2021 software back in Feb 2022. Since delivery, the vehicle would have very intermittent glitches with iDrive, CarPlay, PDC & some others I can't recall. Nothing impacting performance or safety when driving the car but definitely annoying when it happens. RSU was not working at all. On-board nav was laggy & it looked like the maps weren't updating, based on my research.
I brought her in this past weekend for 10K oil change, inspection, etc. I had sent my service advisor a copy of the SIB for RSU not working. I spent 4hrs at the dealership but it was fine since I had some work to catch up on & the customer lounge area is nice. The service team found two bad rear PDC sensors, iDrive was updated to 11/2022.27 version, oil change done, diagnostics done & she received a clean bill of health afterwards. I had to redo all the coding I did with Bimmercode (restore from backup & test to make sure it worked). Navigation is a lot faster (lag is gone & search for places/addresses comes up quicker) & tech said he would escalate the map update issue since he wasn't familiar with it. Time will tell but I'm generally pleased with this software version & that the dealership didn't push back on my request for software update (service advisor is also a BMW enthusiast & his daily driver is a mint E39 that I got to see while waiting).
gnolivos364.50 |
12-20-2022, 07:49 PM | #1464 |
Rep 141
I tried to manually update my car using the latest full PSDZ. I was surprised to see my current iStep was already up to date (07.2021.xx). I do however have OCD and constantly check for OTA updates.
12-21-2022, 11:43 AM | #1465 | |
Rep 2,269
It should come with 22-11-544 and also a 22-07-5xx backup level |
12-26-2022, 11:58 PM | #1466 |
Rep 541
FYI: For anyone with iDrive 8 and 07/2022 software, if your navigation system stops speaking actual street names, get it updated at the dealer. I checked on i4 Talk and saw others having the same issue. I took my 23 M340i to my dealer who updated it to 11/2022 which fixed the issue.
https://www.******.com/threads/navig...et-names.4435/
2023 BMW M340i xDrive
2020 BMW 330i xDrive 2018 BMW X3 xDrive30i |
12-28-2022, 11:46 AM | #1467 |
I ///M Fan
345
Rep 367
On Christmas I received an update in my car. After downloading and uploading my car is keep saying. I’ll inform you when the update can be installed. Normally this is due to a low battery voltage. So I charged it via the BMW CTEK charger for over 24 hours till the green charging LED. However, after starting and stopping the car it still wont install the latest update. Car is parked in a normal garage where the car is still connected via GPS. Any other tips/tricks/prereqs so the installation can start?
mikeyb74131.00 |
12-31-2022, 12:32 PM | #1469 |
Rep 541
The latest OTA update for iDrive 7 and 8 is 07/2022 software. You can get 11/2022 from a dealer if you’re having infotainment issues. I’d check with your dealer to see why you’ve missed the 03/2022 and 07/2022 OTA updates.
01-01-2023, 05:07 AM | #1470 |
Rep 102
It looks like the latest in US is 2022-03 based on the release notes listed here? https://www.bmwusa.com/explore/conne...html#resources
01-02-2023, 10:35 AM | #1471 |
Rep 6
I recently updated to 07.2022 and immediately after I got "driver assistance reduced" and my sideview mirror turns up instead of down when I reverse. Very odd as everything was fine before the update. I tried resetting the system by pressing the volume knob and it did not resolve the issue. Any other suggestions besides taking it to the dealer?
01-02-2023, 11:41 AM | #1472 | |
Rep 541
01-02-2023, 11:43 AM | #1473 |
Rep 541
That is false. 11/2022 is the latest available for both iDrive 7 and iDrive 8. It’s only available at dealers. 07/2022 is the latest OTA available. Don’t trust what release notes are out because BMW has been notoriously bad for when they actually put out release notes.
