04-24-2022, 02:50 AM | #287 |
Rep 84
04-24-2022, 10:01 AM | #289 | |
Rep 84
I left the MEC analog switch on 8-30v and jumper removed. I still do not understand why this was necessary and wonder if it causes degraded audio performance. Either way the amp is working and I appreciate all the input and help from everyone on this thread. I planned to take install pictures but I always get sidetracked and forget to. |
pneumodoc235.00 1WickedE90199.00 |
04-25-2022, 05:03 AM | #290 | |
Rep 2,180
Max output voltage of the RAM HiFi system is 10V, so the UP 7BMW 3.5V-11V input level setting is correct for the HiFi system.
Input level 8-30V is for the RAM Top HiFi (HK) system - max output voltage of the RAM HK system is 26V. Quote:
04-26-2022, 04:22 PM | #291 | |
Rep 84
Is there any issues with leaving the jumper out and switch on 8-30 volts? I already put everything back together (3m taped the amp) and don’t want to remove anything if there is no negative affect to the current settings. |
04-26-2022, 08:07 PM | #292 | |
Rep 13,013
05-08-2022, 03:11 AM | #293 |
Rep 941
Hi,
Sorry I’m a complete noob when it comes to sound. I pick up my G20 on Tuesday and the print out I have says it’s S0676 sound system. Will this amp be a plug and play for that? Thanks |
05-08-2022, 03:30 AM | #294 | |
Rep 1,009
https://g20.bimmerpost.com/forums/sh...67&postcount=4 https://www.msc-america.com/dealer-locator/ Find a dealer in your area who can help you out.
05-19-2022, 02:01 AM | #295 |
Rep 292
Hey guys, very intersting thread!
I have an 2020 G20 with HK and the Matchup 10DSP with the 1.9 harness. Following problems though: - Audiotech Fischer DSP tune sounds terrible and defaults to the the virtual management. The basic tune has enhancers active which make the bass just vibrate. Any guidance on where/ how to best start the setup? Manual/ fresh file and assigning channels as in manual? I have an Umik 1 for measuring. - Where did you guys place the amp? Next to battery lifts the floor up due to the cables and doesnt look to good - also get the voltage warning, the dealer I bought it from said to ignore. The jumper seems to be set to the lower voltage... Soo first impressions not great :-( |
07-04-2022, 07:21 PM | #296 |
Rep 16
you guys without the RAM units are luckiest BMW owners on earth. Having to piggy back of this pos and be forced to use all the factory BMW crossover points and settings is terrible. Have you measured what they've done at 125Hz? It's literally non-existent. They've filtered it down to -10bd at least and once it's that far gone, it's gone. I've spent the last year trying to get it to sound perfect. UMIK-1 mic and HOURS and HOURS of time. You just can't get it right with the RAM unit, they've made it impossible. Once you get to around 60% of the max factory audio, the bass stays at the same level and the other frequencies are only increased. This means when you're tweaking in the Match DSP software, what sounds good at the max level without distortion will sound super boomy at 50%. There's no way around it.
I would KILL for an optical output from the head unit. Has anyone noticed that when the engine is off when you're at a light the system sounds much more full? Pretty sure the "sound level" setting which also can't be defeated is responsible for this. The guys that designed the audio system for the X3's should be thrown off a bridge. |
SoDiezl35064.00 |
07-08-2022, 01:15 PM | #297 | |
Rep 155
I had no issue getting the system in my F30 sounding amazing (after removing the HiFi amp and the mids/tweeters). I had anticipated on having to boost frequencies to offset the embedded crossovers, but I didn't realize that I'd be contending with what is essentially a loudness button. Thanks! |
07-12-2022, 10:45 PM | #298 |
Rep 44
Hello
I hawe mounted musway m6v3 dsp amplefier to hifi s676 The difference is night and day..No need to change original speakers..The sound with this amp is amazing..the center is not more on,because it has 6 outputs and 6 inputs..i hawe tried also with center, that wass pluged on oem amp, but the sound wass not so god.. https://musway.de/english/m6v3-dsp-amplifier.html The software for dsp is werry easy, the sound is amazing https://www.ebay.at/itm/275042098878...EAAOSwmPJhoLsY |
07-14-2022, 03:42 AM | #299 | |
Rep 310
How good is the sound stage without the center speaker? How is DSP profile configured? Do you just have to load the G20 profile and job done - or there is some manual adjustments needed. |
07-14-2022, 03:57 AM | #300 |
Rep 44
The sound stage is werry good..i hawe dsp profile from match and hawe opened in their program, and then copied same setings to musway program for dsp seetings..whenn you need file i cann send it to you 👌
But you cant only paste it, you hawe to make anithing new,buts the same program like from match, only the pictures are litle different The file i hawe bought from ars24 audio specialist from germany |
07-14-2022, 04:48 AM | #301 | |
Rep 310
07-14-2022, 05:38 AM | #303 |
Rep 310
Sure. I've used the default BMW sedan config file, and then manually adjusted it according to MatchUp instruction manual.
Important to know is that: - My basic system was HiFi (without RAM as I was lucky to get it since it was a summer 2019 production date) - I have replaced all mid-bass and twitters with Eton BMW speakers - I have replaced under-seat woofers with Focal BMW woofers - I am running the system with all speakers (central speaker included) - I have manually adjusted time alignment to get a sound stage that is centered right in front of my head at the level of my eyes/ears. The file is in the attachment: |
07-15-2022, 02:36 PM | #304 | |
Rep 13
I have a Musway M6v3 too. The tuning app can't open the file you've posted. What am I doing wrong? |
07-18-2022, 10:53 AM | #306 |
Rep 310
