02-09-2022, 04:42 AM | #1 |
Rep 417
My BMW App
So I just happened to have a look at the app this morning and saw that it said the car was unlocked and that the boot was open. I wasn’t to worried as the car is garaged, and I had actually been in the boot the day before looking for something.
So I went to close the boot and lock the car only to find that it was all closed and locked. I unlocked the car and locked it again and the app refreshed with the update time, but still says the boot is open and the car is unlocked. I even started the car but it didn’t think the boot was open. I’ve always found it to be very accurate. Are others seeing a similar thing?
Current: G20 330i M Sport
Previous BMW's: F36 420i Gran Coupe M Sport; Z4 Coupe 3.0si M Sport; E46 325i Sport coupe; |
02-09-2022, 04:52 AM | #2 |
Rep 8,083
Mines OK. Does it work if the car is outside the garage?
Ian
02-09-2022, 04:56 AM | #3 |
Rep 3,445
Drives: G22 M440D
My App shows the driver window open after I park it in my underground garage.
Which is correct as my window was open as I entered the garage and lost connectivity. D.
Escort Mk1 RS2000 (2.1 2x44IDFS, BVH, Kent FR32, 5spd, 180 BHP) : M440D ¦ Previously : F32 435D : F32 430D M Sport sDrive, 335D E92 2006
02-09-2022, 05:05 AM | #4 |
Rep 417
02-09-2022, 07:12 AM | #6 | |
Rep 417
The app is updating recording the time time the car was last locked, but it’s telling the wrong information i.e. the boot is open and the car is unlocked. |
02-09-2022, 07:18 AM | #7 |
Rep 1,220
I know I post bolleaux sometimes, but that one is a genuine top-tip.
Flashing your lights establishes momentary contact with the car during which the latest data is exchanged. Then if you do a refresh (pull down in the app) it'll grab this new data from BMW's cloud servers. P. |
02-09-2022, 07:20 AM | #8 | |
Rep 2,176
paulockenden576.50 |
02-09-2022, 11:16 AM | #9 |
Rep 417
Well, I drove the car out of the garage, got out and locked it. The app still said sit was unlocked with the boot open, although the actual car thought otherwise!
I even had the car running and then opened the boot which showed correctly on the dash. I wondered if the boot open/close sensor was playing up, but no, all fine. Very strange.
02-09-2022, 12:45 PM | #10 |
Rep 861
Mine was a bit slow to update this evening. Normally it's pretty good and only has issues when I park underground or in big multi-stories. Said car was unlocked and sunroof open even though it wasn't. Seemed to sort itself out about 30 mins later, so wouldn't he surprised if there's issues server side.
02-09-2022, 04:09 PM | #11 |
Russ_M340i
13
Rep 79
Mines telling me my front right window is open. Just been out to check and it's definitely closed. Also telling me it's on 99% fuel level when it's actually on about 3/4 of a tank. Mines parked in the drive so not a signal issue
02-10-2022, 07:45 AM | #12 |
Rep 71
I checked my app recently as had a feeling I left the rear window down slightly when leaving the car, now on the train it suddenly popped in my mind to check on the app - correct, window open. Thought you'd be able to put it down or the 'lock car button' would replicate holding the lock key from the app considering you can turn the fans on & heating, nope.. pretty stupid oversight really.
So it'll just tell you but nothing you can do about it, ha. Last edited by Ross_; 02-10-2022 at 07:55 AM.. |
02-10-2022, 08:00 AM | #13 | |
Rep 417
02-13-2022, 11:35 AM | #15 |
Rep 173
Drives: BMW M340i xDrive
This has happened to me before too.
In my case I didn't do an iDrive reset, seemed too much of a hassle, so what I did was remove it on the app and then add it back again and it did the trick. |
SilverGrey125.50 |
01-28-2024, 09:16 AM | #17 |
Rep 34
Just bought a new ipad. Unable to sign in on mybmw app. Asking me to get a new password and add my vehicle. The app works fine on my iphone.what should i do.?
