05-23-2023, 11:51 PM | #1 |
Rep 11
2023 330e engine noise at low speeds / RPM - whirring?
Loving my 2023 330e, except one major rub: when the battery is fully depleted, driving around the city (at slow speeds, departing from intersections) the engine doesn’t sound great. Even worse if there are other cars / curbs around it providing an echo - it sounds like some whirring. Hard to describe but not a nice sounding engine.
Obviously when the battery has charge, it is nice and smooth with the electric audio. Also have not noticed this at much higher speed/RPM. Any thoughts or similar experiences? |
05-24-2023, 07:21 PM | #3 |
Rep 402
Without hearing your car, I can’t say for sure, especially since I’ve got an M340i. But my car developed a whining/whirring noise that followed the RPMs and it turned out to be the oil pump. After replacement, completely silent. All I hear now is the sweet sound of the exhaust (Active Sound Design turned off).
Are you able to perform an oil level measurement? If not, that could be another sign of a failing oil pump. |
09-20-2023, 11:26 AM | #6 |
Rep 11
Bumping this again. Has no one else experienced this? At low gear/rpm when the battery is out of juice, the motor-only doesn’t sound great at all (especially when getting some echo/sound chamber from adjacent walls or parked cars). Is this normal?
09-21-2023, 06:05 AM | #7 |
Rep 402
Does your car have the electronic oil measurement? If it does, does that feature still work?
10-27-2023, 11:51 AM | #8 |
Rep 140
This is from a F30 330e but is it the same noise?
https://www.youtube.com/shorts/IVlf5iXumWI
'95 M3 Coupe Alpine White
10-29-2023, 05:31 AM | #9 |
Rep 32
Drives: 2023 BMW 330e xDrive
I have the '23 330e and can confirm the whirring noise on a depleted charge. Having owned hybrids in the past, I shrugged it off as the engine increasing revs to charge the battery but now you have me wondering. For me I was more concerned with the loss of power I experienced once with the battery depleted. It felt like the car was sluggish and had to work the accellerator harder than normal driving. Did you have any loss of power issues?
02-22-2024, 06:55 PM | #10 | |
Rep 11
We just moved to a new apartment that no longer has L2 or wall plug so the car is effectively without charge all the time. It really sounds bad at low RPM especially in a garage, tunnel, overpass or driving by parked cars with echo. If you accelerate over a certain speed it eventually goes away. |
02-24-2024, 06:05 PM | #12 |
Rep 11
Thank you! Will stay tuned for your experience. Any others have this similar noise? Happens when the battery is at zero which sounds infrequent for most users given at home charging or a lot of regen opportunities in perhaps more open/suburban driving? Thanks in advance!
02-27-2024, 08:21 AM | #13 |
Rep 3
Hello, just got mine 2 months ago (2nd hand 2019 model) and had the same issue. At low speeds (and engine is cold) I could hear some a "rattling" noise.
Dealership says "it is a normal sound as the exhaust has an metal flexible connection and this makes that noise. After it gets to a good engine temperature it should stop". To be honest, in my case, it really goes almost to a non existing noise when the engine warms up. Although it does not stop 100%. cheers |
02-28-2024, 06:40 AM | #15 |
Rep 3
That is what the dealership told me. I think that most people just uses the car windows closed and that way you don’t hear it that much. After it warms up it tends to disappear.
