02-09-2023, 09:46 PM | #45 | |
Rep 19
It seems RS2.1200 itself has a high level input port (250mV – 8V) and I wonder LOC is necessarily required. But I'm not sure HK BASS outputs below 8V. |
02-10-2023, 10:12 AM | #46 |
Rep 13,011
02-12-2023, 12:07 AM | #47 |
Rep 54
03-19-2023, 11:09 PM | #49 | |
Rep 471
Drives: G20 330i xDrive M-Sport
03-20-2023, 02:51 AM | #50 |
Rep 13,011
03-31-2023, 02:31 PM | #51 |
Rep 2,138
What should we set the internal jumpers to on the Wavtech LOC, 20V or 40V?
Would it see this peak 26V level often? Or can I get away with leaving it in 20V? I have both my LOCs set to 20V currently, but if 40V setting is absolutely ncecessary, I'll go in and change it out. TIA |
04-10-2023, 02:29 AM | #52 |
Rep 793
Does anyone know if it’s worth having a dsp amp to control the trunk sub and underseat woofers
Jl audio do a 5 channel dsp version which could be perfect so it’s is worth paying the extra to have dsp functionality into the underseat woofers and trunk sub |
04-17-2023, 10:11 AM | #53 | |
Rep 19
Just consider the time delay of the trunk sub as set to zero. And set up time delay of the other units. By doing this, you can still achieve proper time alignment, even without direct connection to the trunk sub signal. |
Tags |
bass, h/k |
